Question about Refrigerators
Freezer not cooling
Brand: magic chef The compressor is running and clicking about every minute. It is warm to the touch. The fan is running but the coil is at room temperature. The air coming out of the freezer is just slightly cold. This problem happened suddenly.
    Prodigy:
    An expert who has answered 500 questions.
  • Refrigerators Expert
  • 650 Answers
The clicking you are hearing is probably the compressor trying to run but shuts down after the minute. If your refrigerator has a fan cooling the compressor make sure if is running and the coils are not blocked with lint. A warm compressor is a good sign a hot one is not. The compressor start device or relay could be causing the problem.
Posted on Apr 13, 2014
HVACRH20
  • 237 Answers
SOURCE: refrigerator and freezer
Does the compressor click on and off every minute or so and is hot? That would likely be tripping on a thermal overload due to not being able to start (bad motor starter on the compressor). If the compressor is running normally and warm then you may have a froze up coil. Take the lower rear back sheetmetal cover off the inside freezer section and look at the coil. If it's frozen block of ice basically the defrost cycle is not working and the ice has blocked the air flow through the unit. (could be bad defrost heater, defrost timer or defrost t-stat). If the compressor is running normally and warm and you see no ice or even frost on the coils then you have a sealed system problem that usually means most if not all of the refrigerant has leaked out of the system (or a blockage/restriction in the system). This would be the worst case since it means a whole bunch of money to repair. Let us know what you find out and we can have a better idea on what to recommend.
Posted on Nov 24, 2006
fridgetech
  • 473 Answers
SOURCE: Freezer and Refrigirator not cooling
You didn't say if the compressor is running or not. If it is and all other things you stated are running then it has a sealed system problem. The sealed system comes with a 5 yr warranty in most cases (check owners manual). If the compressor is not running then listen for a click at the compressor. If you hear the click then I would replace the relay on the compressor. If you need further help I will need the complete model # off the sticker inside the fridge section.
Posted on Nov 09, 2007
  • 2920 Answers
SOURCE: Magic Chef refrigerator stop cooling
check the fan relay and the compressor to make sure it is still working...if not there is a capasiter you can replace to get it to work again
Posted on Aug 27, 2008
  • 833 Answers
SOURCE: Fridge running but not cooling
Sounds like you're low on gas...assuming that the condenser coils are clean.
Posted on Nov 20, 2008
peyton32034
  • 410 Answers
SOURCE: Model is GSS25WGMD WW No cooling in freezer or refrigerator
look for ice or forst build up on the rear wall of freezer compartment, sounds like you may have a defrost problem. this will affect temps in freezer and refrig. the most common def problems for GE are bad defrost heaters. these are model specific and fairly easy to replace your self. i got this part number form Sears.com WR51X10055 good luck peyton
Posted on Jan 20, 2009
Magic Chef Fridge & freezer not cold-both fans running-Compressor hot- cleaned drain tube-outside of fridg cold
Is compressor running continuously or is it clicking on and off every couple minutes? Is there any frost buildup on inside back wall of freezer?
Sep 26, 2017 | Magic Chef Refrigerators
Have magic chef mccf5wbx freezer compressor runs but shuts off in 15 seconds
Check condensor not clogged up, fan working etc. If all ok, try new capacitor and relay. If all else fails, replace freezer (compressor replacement is costly)
Aug 07, 2012 | Magic Chef Chest Freezer MCCF5WBX
MCBR240s Magic Chef Fridge does not cool. Compressor gets very hot when plugged in, but no cooling, it also makes clicking noises
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 10, 2011 | Magic Chef MCBR440 Compact Refrigerator
Magic chef compact refrigerater stopped cooling compreser is warm to touch and is makeing clicking noise every few minutes
heatman101
May 09, 2011 | Magic Chef MCBR445B2 (4.4 cu. ft.) Compact...
Magic chef portable freezer not cooling. compressor running
first of all are you sure its running correctly,if its overly hot to the touch is may sound like its running which it may be,but only on the start/run windings and if left this way it will burn out soon,it needs start/run windings to oppose the pressures inside the compressor to get it up to correct operating speeds,then the start winding cuts out of the circuit,this is where the ptc overload comes into play,as it does this sequence switching to make it operate correctly,just unplug it from the compressor and plug in a new one,also you may think you hear the compressor running,but its only the fans in the unit running,a compressor will run warm but shouldn't be overly hot to the touch,then if this isn't your problem,it could be an evaporator core blocked by ice and you cant get cold thru a solid block of ice so iuf its a self defrost model the defrost thermostat or defrost heater might be inopertive too
Dec 26, 2010 | Magic Chef Chest Freezer MCCF5WBX
My Magic Chef 5.5 cubic chest freezer with manual defrost, just quit working. It was a year old this March and it stopped working this July. The power light is on, but run light is not. We unplugged for 5...
Feel compressor to see if running and warm. If not, most likely thermostat control is bad. If it is running, determine if it runs continuously or if it's clicking on and off every couple minutes. If clicking on and off, replace overload and relay that plugs into side of compressor. If running continuously, there is probably a freon leak on blockage. Replace freezer in latter scenario
Oct 30, 2017 | Magic Chef Chest Freezer MCCF5WBX
Magic Chef Fridge not cooling
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
709oy
Jul 07, 2010 | Magic Chef CTB1722 Top Freezer...
My Magic Chef refrigerator model CTB1722GR is blowing nothing but warm air. Compressor failure???
Good day,
Four possibilities.
1. The condenser cooling fan motor located on the bottom back of the machine between the compressor, and box condenser has failed, and needs replaced. It should be running if the fan in the freezer is running.
2. Loss of refrigerant or a restriction in the system. Testing limited to a qualified tech only.
3. The combo relay overload mounted on the compressor( under a cover) has failed. Most appliance parts houses will be glad to test them for you.
4. Locked compressor. Tech only solution.
PS. If the machine is less than 5 years old, the compressor is under warranty. Contact your selling dealer.
Thank you for using FixYa
Dec 27, 2009 | Magic Chef Refrigerators
My magic chef refridgeator/freezer is no longer
You compressor is clicking trying to start. The insides of the compressor have siezed up meaning that they will not let the motor run and turn them. The motor trying to run and not being able to makes it very hot. Unplug it and let it cool down over night, it may go for a while then, but it is probably terminal. Getting the compressor replaced will cost almost as much as new. Is it possibly under warranty?
Nov 12, 2009 | Refrigerators
Refrigerators Logo
43 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
