Question about GE Monogram ZE1660SA Microwave Oven
GE ZE1660SA what product replaces this one?
2 Suggested Answers
  • 248 Answers
SOURCE: My GE ZE1660SA is blown out, and we need to find a
web search-ge monogram ze1660sa demensions-shows demensions ,will have to search for one with similiar diminsions that you like
Posted on Oct 12, 2010
Is this model still available for purchase, if not what is the mdl # that replaced it?
Brenda, according to the GE website, that model is no longer available. They do have other models of similar size though. I have included a link to their website for that size microwave. Products from GE Appliances
Nov 17, 2014 | Microwave Ovens
Tip
Change Light Bulb Monogram zsc1001kss01
I have included a schematic of the interior of the built in Monogram Advantium Microwave oven Model KSC1001. The interior halogen light burned out and had to be replaced. GE service wanted $138 to come out & service it. I tried to find instructions on how to take it apart and remove the bulb & replace it on the WEB but had no luck with the Monogram series so I went to the dealer in Denver, CO and talked with their technicians and they gave me the schematic and sold me 2 bulbs for $11.00. The halogen bulbs can be purchased at Home Depot for about the same price. They are 35 watt with wide metal connectors.
Mine has 2 side trim pieces so these have to be removed first. They have latches on the top that slide behind the sides of the microwave and attach at the top. After removing the 4 screws holding the trim pieces, slide these upwards and then pull out to the sides. 2.) pull the microwave out and set it on a solid surface. 3.) there are approximately 23 screws that need to come out before you can slide & life the cover off the microwave 4.) Then look inside towards the front and left side (looking from the rear forward) for a small metal cover. There are 2 screws that hold it down. 5). Unscrew the 2 screws and gently lift the metal container up. This is the housing for the light bulb. 6.) gently pull the old bulb out and using gloves or a cloth insert the new bulb.You need to keep oils from your fingers from getting on the bulbs. The oils make the bulbs burn out quicker 7.) Put the container back and screw in the 2 screws being careful not to dislodge any wiring 8.) Slide the cover back on and replace all the screws 9.) plug it into an outlet and open the door to make sure the light works 10.) replace the microwave, plug it in and put the trim pieces back on. 11.) go to a movie with the money you just saved
on Feb 17, 2009 | GE Monogram ZE1660SA Microwave Oven
GE JES1290SK microwave magnetron is arcing
I don't know about a recall, but if your unit is under warranty parts and labour are included in most cases.
Sep 03, 2012 | GE Microwave Ovens
I gather from the info that I have read that my GE Monogram microwave diode has gone out. Growling noise, etc. I'm a do it yourself kind of gal. Can I replace that myself?
The voltages in the microwave oven are lethal, there are three common problems, Magnetron, High Voltage diode, or the high voltage capacitor. I highly recommend a professional for sakety sake.
Mar 17, 2012 | GE Monogram ZE1660SA Microwave Oven
Every time I open the door to the microwave, it goes on automatically. Even if I press the button on the door, the microwave goes on. Should I just buy a new one, or is it an easy fix?
most likely the door latch assembly and or the door switch has failed... there are approx. 3 micro switches located where the door closes... these switches all operate items such as the cooling fan,timer, clock assembly etc... sounds like one of these micr switches have failed and will require getting inside to exam with a meter and check contuinity on close and open when switch is open...good luck to you...
Jan 19, 2011 | GE Monogram ZE1660SA Microwave Oven
Our kid put a metal mug in the microwave =now it seems like everything works but it no longer heats-is there an easy fix?
sounds as if the magnetron has burnt out.they are usually covered by a five year warranty and should be replaced by a service tech.
Feb 15, 2010 | GE Monogram ZE1660SA Microwave Oven
Microwave appears to have no power. Display is blank. Checked and found internal fuze blown. Replace the fuze with 20A ceramic fuze. Display works. When try to cook something, microwave runs for about half...
You have a short somewhere. Possible causes, defective interlock switches for the door,shorted capacitor, shorted diode, defective triac. More than likely its one of these.
Oct 01, 2009 | GE Monogram ZE1660SA Microwave Oven
Burned out after 2 years
This may not help your spirit much, but it appears you are not alone:
GE Complaints
And, I would refrain from buying any other GE anythings since they are trying to dump their entire consumer products (appliances) division. I don't doubt some schlock Asian outfit like Funai will be willing to milk the name for a few years and build still more crappy products.
What a pity, still another formerly great American company.
Feb 15, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I want to replace the door
I do not think you can change the door. I can be wrong though. call ge at the number on this link.
http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SPECPAGE&SKU=SCA2001KSS&SITEID=GEA&TABID=3
Good Luck and Please Rate
Jan 07, 2009 | GE Advantium SCA1001SS Convection /...
GE Monogram ZE1660SA Microwave Oven Logo
82 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
