Question about Exercise & Fitness
Nordictrack cxt 910- which lubricant should I use?
In the installation instructions it says to use the included teflon lubricant to lubricate the chrome tubes onto which the upper body arms fit. Where do I get that?
  • 38 Answers
Hi Linda- "Teflon" is a DuPont chemical brand name. I checked their website and found the following link for availability.
Happy exercising!
http://www2.dupont.com/Consumer_Lubricants/en_US/assets/downloads/DuPont_Teflon_Lubricants_and_Greases_Product_Availability.pdf
Posted on Apr 01, 2014
4 Suggested Answers
  • 15 Answers
SOURCE: Where can I purchase a teflon spray lubricant for treadmill?
Tunturi.com or accellfitnessna.com should have the lubricant you need. Order it online and they should be able to ship it directly to your house. I service tunturi treadmills, although I haven't come across a teflon lubricated machine, it is very important with these machines you stick with the manufacturer specified lubricants.
Posted on May 27, 2010
SOURCE: My NordicTrack EXP 1000 stops in the middle of a
my nordic track 1000 stops several times during the workout. I can step to the side and the belt may or may not start back up. The display continues to display the set machine. any suggestions?
Posted on Jan 23, 2011
ercupa190
  • 12223 Answers
SOURCE: NordicTrack treadmill squeaks when walking but fine when running.
1) lube the deck belt, and possible the deck is worn must be replace
2) lube the rollers bearing too.
3) test the bearing motor, need replace too.
God bless you
Posted on Jun 20, 2012
Keeps stopping. I turn off power and restart but it stops again after a few seconds. How can I reset it to quit stopping after a few seconds.
Hope the speed sensor have some problem may dust on it or the treadmill need lubrication. Most of the treadmill stop after some kilometres reading indicating that its time to lubricate it. After lubrication you have to reset the counter.
check the link bellow using the search tab find out details of NORDICTRACK A2350. and follow those instruction.
www.electro-medical.blogspot.com
Nov 01, 2015 | Nordic Track NordicTrack A2350 Pro...
How do I lubricate the c 1800s nordictrack
the only lubrication that needs done is between the walking belt and the deck. if a roller is squeaking either front or rear you can try using wd40 on the bearings on either side
Oct 21, 2014 | Nordic Track Nordictrack C 1800s Treadmill...
Lubricate Nordic Track CXT 910 elliptical
A good hardware store should be able to substitute.
Apr 01, 2014 | Exercise & Fitness
There was a problem with teflon sleeve in hp 1020 printer. so i replaced new teflon sleeve. But after i replaced teflon sleeve i faced a new problem. that is, there is a noise just like a drum frictio
Please sure that when you replace teflon sleeve can you lubricate it's base with soilicon or other high quality grease..... if not then do so
other thing is that be sure about noise it is from drum or upper portion of the printer
Apr 01, 2014 | HP LaserJet 1020 Printer
My tanturi treadmill model j620p indicate 51 in the panel. even i press the reset button still the 51 still in there. all keys does not work too. what shoul i do?
I will try to help you:
If any error code appears on the display or there are other
malfunctions, proceed as follows:
1. Turn off the power switch for a minute and then
turn it on again.
2. Insure the tether key is properly inserted.
3. Insure the power cord is properly plugged.
4. Insure the treadmill is properly lubricated (see 4.3.
LUBRICATING THE RUNNING DECK).
5. If the error code does not disappear after the
above mentioned maintenance actions, please
contact your local TUNTURI dealer. Always give
the error code and serial number (see the sticker
at the back of the frame, below the left-hand side
rail).
4.3. LUBRICATING
THE RUNNING DECK
Please apply teflon by using the pressurised can provided
with these instructions.
1. Let the treadmill run at a slow speed and spray
teflon into the lubrication .
2. When teflon is applied for the first time,
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Oct 23, 2011 | Exercise & Fitness
My tanturi treadmill model j620p does not work. thou it has a power n the panel indicate a number 51 even i press the reset button it does not reset and all the key button does not function. what sould i...
Dear Sir:
turn it on again.
rail).
4.3. LUBRICATING
THE RUNNING DECK
Lubrication is the most important service activity for the
treadmill. This is absolutely essential, if the friction of the
running deck increases noticeably or the motor begins to
heat up. Lubrication intervals must under no circumstances
exceed 200 usage kilometres; we recommend relubrication
once a month. During the first 200 km of use, the running
deck must be lubricated at intervals of 50 km. Insufficient
lubrication will cause the belt, running deck and motor to
wear out and break.
NOTE! Before you start to use your treadmill, it must be
carefully lubricated per the lubrication instructions
below! NOTE! If the treadmill is not used for at least
three weeks, it must be carefully lubricated per the
lubrication instructions below!
The need for relubrication depends to a great extent on the
running styles and weight of the user: heavy user weight and
slow speed put particular strain on the device and therefore
demand greater lubrication. Use only the teflon enclosed to
lubricate the treadmill. Contact your local TUNTURI dealer
for further supplies of teflon.
NOTE! The device must under no circumstances be
lubricated with silicone!
instructions on the teflon bottle carefully.
teflon into the lubrication pipe underneath the
treadmill. The pipe is marked with a decal.
2. When teflon is applied for the first time, the
spraying time with the pressurised can should be
approximately 20 seconds. Later, a spraying time of
10 seconds is sufficient.
3. Teflon drops through the holes of the lubrication
pipe to the center of the running belt; the treadmill
is instantly ready for use.
Please ensure after each time that you relubricate your
treadmill that a strip of about 8" wide on the underside of the
running belt becomes moist with teflon oil along its whole
length. If necessary,
If you need further assistance, please reach me, sincerely. God bless you.
E.CUADRA
I have a nordictrack 2500r treadmill and when i run on it the belt sticks to the board underneath. Any assistance would be very much appreciated thanks
hi,
Your treadmill walking belt need lubrication. For lubricating use Teflon silicon lubricant. To know how to lubricate the treadmill belt watch the following video.
OK
Aug 20, 2011 | Exercise & Fitness
Belt is slipping and squeaking when walked upon what type of lubricant should be used
Sounds like the motor belt is slipping. Make sure the belt from the motor to front roller pulley is tight.Once you have that adjusted lube and adjust the walk belt. The squeaking is usually from the motor belt. Many treadmills(Proform, Nordictrack for example) use Silicone lube (lube n walk, or silicone With teflon from Lowes works good) Call the manufacturer to make sure it uses a silicone lube.
Nov 23, 2010 | Cadence Exercise & Fitness
Bought a used nordictrak cxt 970 eliptical, I need some instruction on how the control panel works.Erhick
Go to iconservice.com click on manuals input this info manufacturer NORDIC TRACK M # NTEL9901 you will fill the section that will address the console usage
Jun 09, 2010 | Exercise & Fitness
May 27, 2010 | Tunturi T20 Folding Programmable Treadmill
Exercise & Fitness Logo
140 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
