Question about Reebok T 980 Treadmill
Problem with my Reebok S 9.80 Treadmill
The first problem I had was that the unit was constantly beeping and would not work, so I recalibrated it using your instructions. After I followed then instructions : plug in, turn on, pull key out, press stop & speed up button at the same time, while holding both buttons replace key, let go of both buttons and press stop once, press max speed until it hit max speed (11.8), press stop.......Now that I've done that my display starts at the left hand side filling up with columns of tiny boxes filling up the entire display screen, when it fills the entire screen with these tiny columns of boxes, it starts back over on the left hand side removing the tiny columns of boxes. It just keeps doing this over and over again. Oh, and when it is filling the screen all the lights under "cool down - weight loss-aerobic-endurance-performance" light up. When the boxes are being removed the those lights go out. Any Help would be greatly appreciated! Thank you!
glenmann62
  • 91 Answers
SOURCE: I have a Reebok S9.80 that died (I-fit)
this is a board issue that needs to be replaced , their rather expensive also so be prepared , the board has a pin connector inside that controls the computer board lights and fans ,but this part is easily removed and replaced ,all your functions start at the board and the pad does wear out from wear and tear use ,hopefully this helped you , sincerely glenn
Posted on Mar 03, 2009
SOURCE: help, my Reebok 8700 ES treadmill won't work...
I had the same problem happen today!! I called 188-999-3756, they are sending my a new panel for 5.95! Yes, I bet that many owners of this treadmill have had the same thing happen. Mine is only 8 months old! let me know if you get this message.
Posted on Mar 26, 2009
SOURCE: Reebok Vista Treadmill issue
Have a 2 year old Reebok treadmill. Control panel was replaced right after we bought it. Now, again, the upper half of the panel works but we are not allowed to start anything. Does the whole panel need to be replaced again or is there a fuse or something small that we can do.
Posted on Oct 22, 2009
  • 15 Answers
SOURCE: I have a reebok fusion treadmill, been fine until
reset the running timer, for the amount of time you would like to walk run ecsetra
Posted on Oct 25, 2010
SOURCE: Hello - when I turn
Let me know if you find a solution. I am having the same problem and cant figure it out. It turns on and will start but none of the other buttons work. Its so frustrating.
Posted on Sep 13, 2011
Treadmill Reebok ZR9 When machine is switched on display flashes and makes a beeping noise
If you wish to get some details about treadmill repair and service ; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Feb 06, 2017 | Reebok Exercise & Fitness
My Reebok Z8 Treadmill says 'E-02' on the display screen. It is constantly beeping and fails to work, How can I fix this?
Run the software calibration for easy diagnostic, and fix it. The speed sensor, can be dirty or faulty, test with s.calibration. see the diagram attached.Read you owner manual or go HOOD cover motor and follow the instruction.
Oct 23, 2013 | Exercise & Fitness
My Reebok 9500 ES Treadmill is making a very loud klunking sound from the rear roller - right side. The sound is not constant - it comes and goes. Doesn't seem to matter where I position myself on the...
Treadmill Maintenance How To Lubricate Treadmill Belt
Please lube very well Roller front and back with WD-40
if the problem persist replace Roller(s).
LUBE the deck belt as show in the video.
Blessing
cuadra2016@yandex.com
cell+whatsApp: +50588611441
Jan 17, 2018 | Reebok Exercise & Fitness
My reebok treadmill makes only three beeps when you hit the sensor buttons
Plug in power cord, remove key, hold down speed+ and stop buttons, replace key, release buttons, press stop once, press and hold speed + until max. treadmill will run to top speed (s9.80 should read out 11.8 to 12.5.) It took a couple of times to get this to work for mine, but now it is OK. If unit does not run after several attempts then the console is probably bad and will need to be replaced ($410). Get another treadmill ! If it does run the console may still beep - problem is with IFIT card. You can get rid of the beeps by opening the console and unplugging the IFIT cable from the computer card if you want.
Feb 06, 2011 | Sport & Outdoor - Others
My Reebok S 9.80 will turn on but when I push any button on the console it just beeps and does not respond. What does that mean?
yes - had to recalibrate it. Plug it in, remove the key, hold down speed + and the stop button on the console, while holding them down replace the key. release the buttons, then press stop once. then press and hold speed + until speed reaches max. unit should run and speed up to max. console should display max speed (s9.80 should read 11.8 to 12.5). It took me a couple of tries to get running but now it is OK. If after several tries the unit does not run then the console will probably need to be replaced ($410) - so get a new treadmill ! If unit does run then it may still beep. Problem is with the IFit card. You can get rid of the beeping by opening the console (unplug the treadmill first) and removing the cable that connects the IFit card to the mother board. Of course the IFit will not work but it will not be beeping at you. good luck
Nov 21, 2010 | Reebok T 980 Treadmill
Reebok s9.80 rbtl69608 treadmill - console only beeps when any button is pressed, platform will not rise and motor will not run.
So I had the same problem it was just stuck on the main screen. It just went beep beep beep. After much tampering. I Opened the console and unplugged the cable that runs from the I fit to the computer board and now everything else works great.
Aug 08, 2010 | Reebok New York Giants Eli Manning Jersey
Treadmill wont incline all the way
With the key in the console, press one of the incline buttons. While the incline is changing, remove the key. After a few seconds reinsert the key. The treadmill will automatically rise to the maximum incline level and then return to the minimum level. Thi will recalibrate the incline system.
Sep 30, 2009 | Reebok 8050 ES Treadmill
Jun 07, 2009 | Reebok Vista Treadmill - RBTL13305
I have a Reebok Fusion Treadmill, an Oil Can Icon has appeared
I have the same problem. I phoned Reebok Tech Support 01908 512244. It is a timed icon to advise the deck should be lubricated. If you have done so / do this regularly you can ignore it. To remove the icon follow the instructions they emailed me. Hope this works Cheers John Please follow procedure below:
1. Keep power on and remove the safety key
2. Press and hold incline down and speed down, at the same time insert the safety key
3. You can release the “Down” buttons. (you will now hear a beep)
4. Press Speed up
6. Press stop. You will now hear a beep and the icon will disappear
Dec 02, 2008 | Exercise & Fitness
Reebok T 980 Treadmill Logo
101 people viewed this question
Top Reebok Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
