Question about Suntec A2VA-7116 Single Stage Fuel Pump
Not getting fuel in the filter
Replaced the fuel filer on my oil furnace. Now it is not pumping fuel in the new fiter. There was a lot of sludge so I think it might be the pump or a clough in the line from the tank to the filter.
    Genius:
  • 1,114 Answers
You can use low pressure from an air-compressor to blow out the INTAKE line from the tank to the filter to unclog the line. The fuel pump has a filter screen that may very well be clogged as well. Remove the fuel lines from the pump. Take out the screws that hold the pump face on, and remove the screen. Be careful not to rip the gasket when you remove the pump face. Clean the screen and re-install. While the lines are disconnected you can blow them out. After everytning is re-installed, the system may have to be purged of air. There should be purge valves on the side of the pump for this. As the pump is running, open the purge valve to allow any air in the line to escape. Also for future reference, the INTAKE line should be at least a few inches from the bottom of the tank, so sludge that settles to the bottom is not drawn into the line. It's also a good idea to use a anti sludge additive to the tank.
Hope this helps.
Posted on Apr 06, 2014
Oil is not coming on top of the camfoil
ran across this post not very much info from you but most cars are like this if your oil pump is bad your not going to get oil to the top end and the pump will need to be replaced if your motor is caked up with sludge what i do is drain oil out then refill with diesel fuel then start car but only idle it do not rev up; let it run for about 5 minutes turn off and drain repeat untill the diesel fuel comes out clean then change oil filter and refill with the proper amount of oil yes it works i have 460,000 original miles on my truck and if you look in the ouil filler hole the head looks like new
Jun 15, 2014 | Cars & Trucks
95 dodge stealth oil leak near oil pump
did you replace the seal on the bolt that holds it on
Apr 17, 2012 | Cars & Trucks
Starting problem sometimes 4cly
change the fuel fiter and if that dont work then it the fuel pump
Nov 21, 2009 | 1995 Toyota Camry
Loss of power on acelaration
There's a lot on any car that can cause loss in power.
A few of them are:
Mass air Flow sensor
Bad O2 sensors
Old oil or sludged oil
Bad Gas
Clogged catalytic converter
Loss of cylinder pressure or compression
I would start with the cheapest tests/fixes first
oil: if you haven't already and don't know the condition of your oil, change it. If your oil has sludge in it then you could have a leacking head gasket.
Next up, If your gas is bad fill the tank about half way and use lucus oil octane booster, and for a second half a tank pour in some seafoam engine cleaner. It will clean your fueling system, injectors, and pistons/chambers.
If those too don't help: get a compression test on the cylinders. Not expensive to have done, but could be expensive to fix if there is something wrong or the compression is leaking.
Next, go to a muffler shop and have your catalytic converter checked. A clogged or bad Catalytic converter may trap exhaust and keep it from exiting your exhaust system.
While your there you can have your O2 sensors checked.
If all of that is fine, replace the O2 sensors and the Mass air flow sensor. These components control the air fuel ratio. If they are going out your engine won't ever get the right amounts of gas and air to run properly.
It's a lot, but my general rule of thumb for trouble shooting any issue with a car is to start with the cheapest fix and work your way up.
Jun 03, 2009 | Hyundai Motor 2002 Sonata
Bmw 323 'r' reg e36 engine oil light flashing
your oil pressure switch is a great place to start. since the oil was really thick you could have a horrible oil sludge problem. about 50-100 miles before your next oil change take a bottle of Transmission Fluid and dump in with your oil. and Drive for the remaning 50-100 miles with the Trany fluid still in the oil. The Transmission Fluid is a great Cleaner for sludge.
hope this helped you
Apr 29, 2009 | 1999 BMW 323 Series
Want to do some preventative maintenance on my 2006 Xterra...
FUEL FITER , AIR CLEANER , OIL FUILD AND FITER , TRANS FITER AND FLUILD CHECK REAR END OIL AND BRAKES ALSO TIMING BELT WOULD BE VERY GOOD TO CHANGE OUT
Jan 01, 2009 | 2006 Nissan Xterra
Suntec A2VA-7116 Single Stage Fuel Pump Logo
134 people viewed this question
Top Suntec Plumbing Experts
Donni Steen
Tom Chichester
Are you a Suntec Plumbing Expert? Answer questions, earn points and help others
