Question about Rheem Paloma PTG-74PVN / RTG-74PVN Natural Gas Indoor
Running out of hot water
The control shows no error codes at all. just stops putting out hot water after a short time. What could it be?
ER3 error code on amtrol hot water tank
Simply means hot water heater called for heat for 1 hour and never rose in temperature or reach stepping, unit automatically goes into lockout. I would reset power
Feb 14, 2015 | Amtrol WHS-80Z - WHS-80Z 80Gal Hot Wtr...
Tankless water heater model # RTGL74PVN is blinking 38 what does this mean
Copy following link for general troubleshoot and error codes:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Error code 36 does not show in any resource, including 2008 service manual, or 2012 product manual.
Check that remote control display is illustrating the correct number.
For example there is error code 35.
Oct 19, 2012 | Rheem Tankless Hot Water Heater...
Why get a P1 error code on my Rheem tankless RTG-64xp?
1) I cannot find Rheem error code P1
http://www.palomatankless.com/owners/homeowner+trouble.lasso
http://www.palomastore.com/paloma_error_codes.html
2) BOSCH does not show P1 either:
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ESTechSupport/Troubleshooting/tabid/1295/Default.aspx
3) Best I could find is that folks with P1 error code report tankless fires for short period, and then turns off.
This implies air, fuel or vent problem, and can be internal, external or combination.
4) P1 appears frequently on control board descriptors, which might imply the error is control board malfunction.
5) Call Rheem 1-800-432-8373, and then add a comment to this thread and let folks know what you discover.
6) I will also call Rheem when time permits, and post what I discover.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 05, 2011 | Rheem Water Heaters
My water heater cuts of after 30 seconds and shows C2, 11 code
sounds like your gas lines are too small or not enough pressure... or you may have to clean the rods
Jan 13, 2010 | Rheem Paloma PTG-74PVN / RTG-74PVN...
I am having the same problem as posted by jek01 on Aug 1, my Rheem Tankless Hot Water Heater is not powering off, after two years of use with no issues. I also have to turn the breaker off and wait a short...
Remove power source from the unit. If remote control2.gif is installed; remove cover and lift the control wires on the terminal...can be accomplished from either end.
Restore power and see if unit functions normally.
Contact Paloma/Rheem customer (800-432-8373) support and notify them IF you are getting a code "76" error. Rheem has recently extended the warranty on the "Burner Control Assm."; which is your problem. The C4-C8 portion of the error code, is where the unit stops the ignition process...burner fails to light, or gives you intermittent hot water. In either case, contact customer support2.gif.
If this helps, please indicate so.
Mike
jzklipper@aol.com
Oct 11, 2009 | Rheem Tankless Hot Water Heater...
PTG-74PVN Error Code -0 14 and LED on the controller board flashes 4 blinks every 6 seconds. Fan turns on few seconds after power up then stops. No fan, no spark, and no fire when water flows. Where can I...
code 14 is a big deal shut that thing down! you will burn it up if you keep running it, your over heat wrap on the heat exchanger is too hot. call rheem they can walk you through it
Aug 12, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
BOSCH TWH-G1-25 not lighting
Model????? The 635Es, 250SX and 2400E are same. The 2400ES and 2700ES are World 2 heaters. Any error codes as I can't imagine this problem w/o codes. Flow initiated but you have spark. Is there any ignition? If so flame rod may be bad and not reporting ignition. Igniter sets on some early 2400/2700 have proved to be bad. Water pressure has zero to do with this. If you have an EC or EA code you have gas problems (meter, line size/length or gas valve). Also if 3005 or 3007 Software you can pull the last 5-10 error codes from Controller.
You need to call Bosch and get an RSA out there. This is a gas appliance that if you screw up can destroy your house. FYI any water in the gas valve condemns it. It will not dry out and work correctly. Is the fan running at ignition and/or purge? Any Controller errors require replacement. You have 2 years on parts warranty from installation date so don't screw around trying to DIY. Warranty Labor is not covered.
Flue obstruction? If you used the AQ3 installation Kit you have the wrong termination box to prevent freeze up and/or water penetration You need the Z-Vent drop nosed termination. Look for a fine tan dust in the fan intake (brown plastic) the intake throat or in passageway to the gas valve. Call Bosch unless you're a Gas Tech this is beyond you.
Mar 02, 2009 | Bosch AquaStar 2400ES-NG
Rheem Paloma PTG-74PVN /  RTG-74PVN Natural Gas Indoor Logo
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
