Question about Sony Handycam DCR-DVD108 DVD Camcorder
How do i finalize the disk - Sony Handycam DCR-DVD108 DVD Camcorder
  • 10,594 Answers
Power up camcorder with AC charger and check menu to finalize mini dvd disc.
Posted on Jun 15, 2009
About 5 years ago I transfered some vhs tapes to dvd using a go video vr 3840. I did not finalize the dvd's. I need to buy another vr 3840 to finalize the dvd's. Where can I find one to buy?
You should not need another '3840 to finalize the disks. Finalization just ends the index, makes writing back to the disk near impossible. You should be able to finalize / close the disk using a dvd authoring program (Nero, CD BurnerXP, etc).
The catch may be that the disks that you created are formatted as DVD video, closing a video disk may not be the same.
Another possibility is to use an authoring program (like the above) to copy your un-finalized disks to fresh media, and specify the disks to be finalized (or closed) when completed. I would try this first, the only thing to lose is time, and a disk. Oh, and about 4.7GB of hard disk space to create the image if you only have 1 DVD drive.
Jun 29, 2010 | GoVideo Go Video VR3840 DVD Recorder/VCR
Camera will not allow me to finalize some dvd's
If your camera finalized the same type (+R, +RW, -R, -RW) of disk previously, the problem may be the disk itself. Some 2% of the disks (no-brand and copy-brand disks even higher %-age) are faulty and either do not allow recording at all or fail at some point.
Dec 05, 2009 | Sony DCR-DVD610 DVD Camcorder
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
I want the pictures and video off my DVD-RW on to my computer
Yes, you must finalize to view the dvd in a stand-alone dvd player.
No, battery doesn't have to be charged but the camera does have to be plugged in to do finalizing.
After, finalizing the disk, and you are in fact using DVD-RW (re-writable) disks, yes you can un-finalize them within the Canon camera to record more video.
I have used the same 3 rewritable disks on my Canon over and over again to record many hours of footage.
Apr 30, 2009 | Canon DC210 DVD Camcorder
I had the same problem the manual don't tell you in detail have to finalize the disc . I had to go to this web-site to find out how . What's the purpose of the manual? Very un-happy Canon Customer
Hi, thanks for coming to FixYa.
Here is how to finalize a disk in your camcorder.
1) Plug in the power adapter, and put in the disk you want to finalize.
2) Press the function button. If your disk was recorded in VR mode, then go to step 3. If not, go to step 4.
3) Scroll right to get to menu.
4) Scroll down to get to Disk Functions.
5) Scroll down again to get to Finalize.
6) Scroll down again to Yes.
7) Press the function button.
8) Wait until it's done, then you can play your disk in a DVD player.
Remember, (very important). Don't touch or bump it while it's finalizing a disk. If you disturb it, you can mess up your disk.
Hope that helps you. Don't forget to rate my solution, and enjoy your videos.
Rob
Mar 03, 2009 | Canon DC210 DVD Camcorder
Cannot finalize dvd
Try playing the problem disks on your PC. If they wont play and the "Finalised" disks do then try recording a further brief clip on the problem disk. If that works then attempt to "Finalise" again. Can you play the problem disks in the Camera by the way?
Oct 20, 2008 | Sony Handycam DCR-DVD105 DVD Camcorder
Dvd player
Are you using a DVD+RW disk? Unlike DVD-R, DVD+R and DVD-RW disks you cannot finalize DVD+RW disks on the Magnavox MWR10D6 DVD Recorder. Instead you have to make the disk compatable [Make Edits Compatible], this allows you to close the disk and play it on other DVD players.
go to: Setup ==> Edit Disk ==> Make Edits Compatible ==> Yes
Other than this nothing else comes to mind to troubleshoot this problem. Hope this helps.
Aug 16, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Finalization of Disks
Failing to Finalize and thus making the DVD 'playable' on other DVD Players is most often caused by the media (your blank disk), not the Recorder. Trying another disk, from the same 'stack' or manufacturer will often have the same result. But, it is a 'hit and miss' situation. As you have the recording on the hard drive it can be worth your while connecting another basic DVD Recorder to input the material to a disk in that recorder. Sounds silly perhaps, but I have actually done this - and had the disk finalized in the second unit.
Oct 24, 2007 | JVC SR-MV40 DVD Recorder/VCR
Finalizing vs. not finalizing a DVD-R. DVD-R vs. DVD-RAM?
on standard players. The write all the information that a standard player looks for to read the disk. Nothing is lost if you take the DVD out of the recorder without finalizing it. On a PC, you would tell the software to eject the disk. Later model hardware can usually reopen a disk after it has been finalized. Is this a typo? 'I know that the disc cannot be seen in a DVD player after being finalized'. It should read; I know that the disc can be seen in a DVD player after being finalized
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Sony Handycam  DCR-DVD108 DVD Camcorder Logo
258 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
