Question about Janome Magnolia 7318 Sewing Machine
Problem with feed dogs
Brand new machine feed dogs wont rise
    Problem Solver:
  • 5 Answers
Did you drop them your self? If you did it may need a little more effort to push the button back into place. If they were down when you got the machine then they are not hooked up and the machine needs to be opened to connect them.
Posted on Apr 02, 2014
SOURCE: feed dogs on my machine wont rise above plate
Open the door infront of the hook race assembly/bobbin carrier and check to the right of that. There is a chrome lever which engages with slots in the plastic casing. The correct position for this is as far to the left as it will go. If it is to the right furthest extent it will disengage the feed dogs. It should disengage automatically but if has not, press the lever down and slide it to the left. Good luck
Posted on Apr 27, 2007
  • 13 Answers
SOURCE: How to Drop Feed Dogs on Sewing Machine...
On many machines you tilt the machine back on its hinges to see the underside and there you will find a thumbscrew to lower the feed dogs...you also need to be sure that your machine is capable of having its feed dogs lowered...not all machines can do this!
Posted on Aug 28, 2009
tunde007
  • 2382 Answers
SOURCE: My brand new Janome 7330
Hi, Turn off the power, remove the needle, presser foot and needle plate.
Clean the feed dogs with an old toothbrush.
Turn the hand wheel - are they moving?
Make sure the stitch length is not set at zero.
Refer to your manual for engaging the feed dogs.
If you still cannot get the feed dogs to feed, the machine will need service by a professional.
Posted on Oct 23, 2010
bargainbox
  • 1388 Answers
SOURCE: I lowered the feed dogs with the drop feed lever,
Flick switch to the UP position.....then....
Turn handwheel one full revolution to reset the feeddog cam
It is on page 26 of your User Manual
Bargain Box
Posted on Feb 13, 2011
  • 1564 Answers
SOURCE: janome 3160 qdc drop feed dogs
Look on the back side for a slide type switch.
Posted on Aug 04, 2012
Singer 4423- brand new. Followed youtube tutorial, lowered feed dogs (buttonhole setting) with no problem; now unable to raise them. Followed suggestions to another user with the same problem- no luck
go google and type in --user manual for singer sewing machine model 4423---and download the pdf version
you could always talk to the singer shop for advice or join a sewing club to get expert tips to get the best out of your machine
Mar 22, 2017 | Singer Sewing Machines
Feed dog on Necchi 681c has drop,how do I fix it?
A lot of machines have a control knob/lever that raises and lowers the feed dogs. However, remember that when the control is activated, the feed dogs will not rise until the machine actually begins to stitch.
If the feed dogs do not rise, then there is most likely a problem and needs to be serviced.
Feb 14, 2017 | Necchi Sewing Machines
Feeddog singer stylist 776 how would the feeddog gt lowered
Consult the owner's manual. There should be instructions for how to darn with your machine. It would require either the feature that lowers/raises the feed dogs or a cover plate that attaches over the feed dogs.
If your machine came with the cover plate accessory, and the feed dogs are not rising to feed the fabric, then I suspect the machine has not been cleaned & oiled in quite some time and perhaps the feed dogs have seized. When you run the machine (remove the needle and presser foot), watch if the feed dogs actually drop below the needle plate, move toward the front of the machine, then rise above the needle plate and move toward the back of the machine. This is a repetitive motion that actually pulls the fabric through the machine. If this is not happening with your machine, it needs service.
Singer Stylist 776 Manual Page 8
Oct 30, 2016 | Singer Sewing Machines
I have a new home excel 23lL sewing machine and the fabric won't advance
check the position of the forward/ reverse setting
near the middle will not advance the material
take it in for a service
Oct 25, 2016 | New Home Sewing Machines
Just wanted to check troubleshooting ideas on the feed dogs. They seem to be engaged but not running fabric through when sewing
Check that the stitch length is set to make ~10 stitches per inch. This stitch is long enough to actually move the fabric. If the stitch length is set too short, the fabric will stay barely move and the needle will stitch almost in place.
Check that the feed dogs have not been dropped for darning or free motion quilting. In this position, they do not rise and are, therefore, unable to contact the fabric to pull it through the machine.
With the presser foot raised and using no fabric, hand rotate the handwheel and watch if the feed dogs actually drop down below the needle plate, move toward the front of the machine, then rise above the needle plate, and move toward the back of the machine. If the feed dogs are moving in this manner, then they are functioning properly.
Is there lint or gunk stuck in the feed dogs? This will restrict the ability of the feed dogs to grip the fabric.
Are the feed dogs worn? Are the little teeth worn so there are no sharp points?
What type fabric are you using? If it is very light-weight or slick fabric, the feed dogs will have a difficult time gripping the fabric. Most machines have a presser foot pressure adjustment so that more pressure is applied between the presser foot and the feed dogs. Consult your Owner's Manual. The adjustment is usually a dial either on the left side of the machine, on the front of the machine located above the needle bar, or on vintage machines it is usually a skrew located under the top lid above the needle bar.
Mar 26, 2016 | Husqvarna Sewing Machines
How to move feed dogs under needle for singer 514
First, make sure the feed dogs are in the up position and NOT dropped for darning.
Second, check that the stitch length is set to at least a 2 or 2.5 to make sure the feed dogs will actually move the fabric a noticeable distance. The closer the stitch length is set to zero, the closer together the stitches will be until it will sew only in one place because the fabric will no longer advance.
The feed dogs need to move. They should actually rise, move toward the back of the machine, drop down, move forward to the position to again rise--this creates one stitch. If the fabric is not moving, then it is possible that your machine has not been cleaned and oiled recently. Old oil will dry and cause the moving parts to seize.
It was working now it seems to be frozen the needle part wont move
Mar 07, 2016 | Singer Sewing Machines
Feed dogs wont rise
when the feed dogs won't come up then they need to be check to see if they need a adjustment or replaced
May 24, 2015 | Janome DC3050 Computerized Sewing Machine
Dog feed wont rise
you said the switch will move , but the feed dogs don't,,sounds like the switch could be broken or loose
Dec 13, 2014 | Sewing Machines
Janome/New HomeHF 2022 How do I raise and lower feed dogs
With the straight stitch set to zero the feed dogs should be down. To use a different number will make the feed dogs rise above the plate.
Oct 23, 2014 | Sewing Machines
Bobbin thread will not pick up nor will dog feed rise
my Brother sewing machine model VX 1120 will not pick up the Bobbin Thread. Machine is fairly new with only several hours use. I have changed needles , tried different bobbins, cleaned the machine. Any suggestions?
Jul 06, 2008 | Sewing Machines
Janome Magnolia 7318 Sewing Machine Logo
102 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
