Question about Sharp Aquos Televison & Video
Enable touch screen
When we moved our Aquos Board from one location to another the touch screen somehow disabled. I need it to work again!!
  • Sharp Master
  • 3,320 Answers
Touchscreens work with software . Add the software to the new computer.
Posted on Apr 01, 2014
Q302lamy asus touch scree not working model number
Go to the search bar, type device manager it will be listed under control panel. The touch screen may have been disabled by accident or maybe a driver malfunctioned. under Human Interface Devices it will be one of those, right click on them and see if any say enable go ahead and click enable. If none are disabled try clicking "update driver software" it will be located under the same menu as the disable/ enable feature. i will attach two pictures of what it looks like. Now if neither of these works i would say it's a faulty touch screen.
25143119-o3dodzl4qyaya15qun0b2bn0-2-0.jpg 25143119-o3dodzl4qyaya15qun0b2bn0-2-1.png
Sep 26, 2014 | ASUS 13.3" Touch-Screen Laptop - 4GB...
Touch pad does not work
Locate the "Fn" key in the lower right or left corner of the laptop keyboard. The "Fn" key typically has different colored text on it or the key itself is a different color. Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop. The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it. Press both the "Fn" and touchpad Function key simultaneously to reactive the touchpad on your laptop. Move your finger along the touchpad to verify that it works. Press the combination at any time to disable the touchpad again.
Feb 27, 2013 | Computers & Internet
Laptop touchpad not working
hope this helps
Sep 09, 2012 | Toshiba Computers & Internet
Touchpad not active
hope this helps
Sep 05, 2012 | Computers & Internet
Touch pad not working
hope this helps
Aug 02, 2012 | Computers & Internet
My toshiba sattilite laptop, soft touch cursor is not moving and opening the icons
Hi jilglh...
Try this method
To fix an unresponsive touchpad on your laptop, reactivate it by using the Function key on the keyboard and the Fn key.
This process is different for each computer manufacturer.
If unsure which Function key enables and disables the touchpad, try each one at a time and then
attempt to use the touchpad after each one.
A...Locate the "Fn" key of the laptop keyboard.
The "Fn" key has different colored text or the key is a different color.
B...Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
C...Press both the "Fn" and touchpad Function key at the same time to reactive the touchpad on your laptop.
Note: Mac computers use "F2" to enable and disable the touchpad.
D. Sony Vaio Users: Start>Settings>Control Panel>Double click the Mouse icon.
Look at the top left hand side of the page, at the top and make sure that the "Tapping" box is unchecked, if it is checked then, you will uncheck it.
Please take time to rate me thumbs up
Sep 17, 2011 | Toshiba Computers & Internet
Compaq 730us touch pad not responding
Hi
To fix an unresponsive touchpad on your laptop/desktop XP Home, XPPro:
Reactivate it by using the Function key on the keyboard and the Fn key.
Sep 06, 2011 | HP Compaq Presario 730US Notebook
Touch pad scroll gestures very intermittent.works then doesnt
Hi tommymul6...
Try this solution to your problem
Sep 04, 2011 | Computers & Internet
My mouse pointer not moving if i use touchpad, but if i use usb mouse it works well.
Try to press Fn (locate at the bottom left of the keyboard near CTRL )and at the same time tap F9 (on top of the keyboard), you will see the status if it's enabled or disabled, just tap F9 to make it enabled.
Feb 24, 2011 | Toshiba Satellite L455DS5976
Touch pad on/off utility
Disabling or enabling the TouchPad The TouchPad is enabled by default. To change the enable/ disable the TouchPad setting: 1 Click Start, Control Panel. The Control Panel window appears. 2 Click Printers and Other Hardware. 3 Click Mouse Properties. The Mouse Properties window appears . 4 Click the TouchPAD ON/OFF tab. The TouchPad ON/OFF tab appears. 5 Select Disable or Enable, whichever is appropriate. 6 Click Apply.
7 Click OK. The Mouse Properties window closes. 8 Close the Printers and Other Hardware window . 9 Close the Control Panel window.
Nov 11, 2007 | Toshiba Qosmio G25-AV513 Notebook
Televison & Video Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
