Question about Avocent DSView 3.0
Communictaions with the dsview server have been lost, the application will exit. I get the proceeding error when trying to use a KVM to a server after I executed a delete browsing history.
How to test TCP ports on ACS48
It sure is. Use a linux distro with NMAP installed, then do nmap-sT -p- -Pn ***.***.***.*-***, replacing the stars with your ip address, and hyphenating the range you wish to scan across.
Aug 03, 2015 | Cyclades Avocent Acs48 Sac 48-port Console...
Error communication btw indoor-outdoor units
The thermostat is the only communication between indoor and outdoor units.
Nov 30, 2013 | Fujitsu 24C1 Air Conditioner
How to connect my lcd kvm and make it display on sreen
You question is unclear. Please specify the makes and model of all devices. I typically use Rackmount Monitor Keyboard combos with integrated KVM Switches for larger server applications. I have used quiet a few units from KVMSwitchTech and they work pretty well.
Jan 18, 2012 | HP TFT7600 Rackmount KVM Switch
I am having problem getting the Web site feature for remote access to the switch.
if the switch doen't display the Web interface, you might have 2 issues.
1) network port 443 is closed on your network... open it and test again.
2) the DSR was part of a DSView setup and has a Security Certificate and the Web Interface is blocked internally. To clear this you will have to access the Console (Comp port) and go into Security and Unbind from DSView, or clear Security Token (Depending on Firmware).
I hope that helps
Mar 17, 2011 | Avocent (DSR4010-AM) 4-port KVM Switch
Fuzzy image on HP GL360 Server
It need'nt be a software issue. If the KVM is fine with other servers in the rack, the the problem could be due to the resolution of the server u mention. Try a remote desltop connection and verify the resolution.
Also try restarting the KVM.
If the KVM is having problem with other servers also, then it is the problem with the KVM itself
Feb 10, 2010 | HP ProLiant DL360 G5 Server
I have a HP eo1010 kvm switch, how do I go about switching from server to server on it?
By default to bring up the On Screen Display press:
CTRL + CTRL
If you flash the firmware to the latest, you can change that key sequence for the OSD to either PrintScrn, CTRL+CTRL or SHIFT + SHIFT.
Jan 08, 2009 | Dell (310-1925) (2R905) KVM Switch
KVM Switch 4110 8 port
so is the KVM (control side, PS2 mouse / kbd>??)
or are all PS2 ports wired to adaptors,? i cant guess this nor what was used before, no history stated.
what was there before, this act?
and what now?
Ill assume worse cases (tossed a coin)
18 (16+2) adapters now. all devices are USB but KVM
ok.?
what mode fails, both the KVM pushbotton switch and or the hot key commands on the kbd?
Oops no manual button as seen on modern KVM.
KVMs are very complex. the hard part is the vast number of different PC.
USB , PS2, VGA, DVI and HDMI.. yah,..
OK 16 +2=18 x ps2, and 9 VGA ports. it is.
NO KVM does it all, ,, old KVM' do NOT work , on new computers, all folks know this , if they tried. or took readings to learn why it fails.
I bet power to the KVM is dead., no LED./
no manual button ,oops.
pin 4 PS2 reads 5vdc and connected up, same?
we use breakout boxes (DIY) to test ports connected.'
that Compaq is very old and no support now, no books.
why not ask at real HP, maybe some old guy there can dig it lost books>
40 KVM? that what you said, really? (or 40/8=5 kvm)?
my guess is the adaptor does not work or power issues
KVM >>PS2>>>ADapt>>> USB.(server) (usb 1,2,or 3 at server?)
The KVM in most cases, here, steals power from PS2 ports but not this KVM , its better.
i'd bet that adaptor cant do that.
(is the caps lock key working on the KBD and laser LED glowing on said mouse?
ask here, real HP.
lets see tests:
1: pin 4 ps2 5vdc?
2: mouse glows?
3: keyboard led , caps lock toggles? (glows)
4: lost the hot key commands (y/n)
one other problem is the BIOS in the server may not like your adaptor at all. When BIOS scans the keyboard. it expects a ID response if missing or grabled, it drops that device port.
https://h30434.www3.hp.com/
btw, one way to cure this, is run headless server software
end KVM for ever.
i run a LAMP server, that comes in the box, no kvm no any thing on ports. it has a web page to go to and do service that way.
port IP+:12321
modern ways work best.
in a server farm, a keyboard/mouse/monitor on rolling cart
for the super sick servers is best...
the other problem is USB only PC or server
does not scan PS2 ports, it has none
so if the adaption fails, at boot time, all is lost.
(BIOS reports connected devices to the OS)(unstated by you)so if the report fails, problems happen
for sure after the boot.
this device is s business device, now ("Enterprise)
the posts on it are like 10 years ago. all links to books now dead.
infact the compaq server that had them is turned off. (grin)
here is my search there. Why not ask them?
https://www.hpe.com/us/en/search-results.html?client=&qt=kvm+4110&search=%EF%98%90&cc=us&charset=utf-8&hpa=http%3A%2F%2Fwww8.hp.com%2Fus%2Fen%2Fhpe%2Fcontact%2Fcontact.html&hpn=Home&hpr=http%3A%2F%2Fh41131.www4.hp.com%2Fus%2Fen&hps=Home&lang=en&qp=url%3Ah41131.www4.hp.com%2Fus%2Fen+url%3ANEW+URL+GOES+HERE
Aug 26, 2017 | Compaq 242695-001 8-port KVM Switch
New to exchange server 2003
Hello there!
First things First!
1) you always going to have problems with exchange servers, or migrations. ** systems are not perfects**
2) You can migrate the emails to the new server, but, if only are in the correct version of Exchange 2003.
3) if backup is damage or fail, you lost everything.
4) try to reinstall the Server, and all utilites, is better, I know takes more time, but is better because you created yourself.
I suggest you to install from scratch!
Good luck
Feb 24, 2008 | Computers & Internet
Computers & Internet Logo
338 people viewed this question
Top Avocent Computers & Internet Experts
gary433
Are you an Avocent Computer and Internet Expert? Answer questions, earn points and help others
