Question about Troy Bilt Tb20cs 2 Cycle 31cc Gas String Trimmer 17" Cs
Will idle but stalls on acceleration
Needto adjust carb
  • James Shipman
    James Shipman Apr 02, 2014
    how do i adjust the carb ?
    Scholar:
    New Friend:
  • 119 Answers
To much air getting through
being careful not to over tighten or you will crack your inlet manifold
solution: tighten down your carburetor and tune up your carburetor
adjust the outside screw first that is your throttle screw
then once a full revs adjust the inside screw to where you want the max revs to be
Posted on Apr 14, 2014
How to fix a Weber DGV 2 Barrel Carb. I have a Weber Carb on my Model A Ford. It stalls out when accelerating up a hill. Can you help with where to start adjustments?
Sounds like restricted fuel flow...new correct fuel filter? Air/Fuel mixture...while idling...turn each screw clockwise until slight stall...then back out (counter clockwise) one and a half turns to smooth idle...Hope this helps.
Nov 05, 2015 | Cars & Trucks
1985 chevy blazer s10, replaced mechanical fuel pump, still not gettin fuel to carberator
I have a 1984 S-10 Blazer since it was new
almost 29 years ago
Explain how a new fuel pump doesn't work
I only had that once on my 1965 corvette
A new pump had been assembled with the
diaphragm outside on a couple holes,a quick fix
You must have fuel to the carb & thus you need
to take the carb apart & work on that
So far I found that NAPA is the only source for
a carb kit
Oct 03, 2012 | 1985 Chevrolet S-10 Blazer
Weed eater starts and idles after it warms. When I accelerate it sounds like it is choking itself out or it is starved for gas then stalls.restart and it does it all over. Sometimes it stalls when i go to...
Take out carb and spray with carb cleaner through and into all portals. Blow out with air compressor.and reassemble.
Adjust idle and low and high mixture screws according for proper operation.
Aug 31, 2017 | Weedeater Set (Weedeater)
I have a Toro 524 with Tecumseh engine, model 38040 8 0000640. I am rebuilding the carb and would like to know what are basic settings for idle and hi/low speed screws?
The high speed mixture screw is initially set at 1 & 1/2 turns out. Then adjust it to give good acceleration and top speed, while not closing the screw more than you need to. The low speed mixture screw is set at 3/4 of a turn out. Adjust that, to give a smooth idle. The 3rd screw, the idle speed screw, is set to give a low idle speed without stalling.
Jan 14, 2011 | Toro Blowers Rake and Vac - Electric...
Good Morning,,,, 1. What are function of high speed and low speed needle for gas boat.? 2. Which needle shall i set to get higher RPM and how correct step to do it? thanks
Hi and welcome to FixYa. I am Kelly
The L screw is adjusted when your having problems accelerating from idle..i.e sluggisgh acceleration or stalls.
The H screw is adusted at MAX rpm only to get the fastest engine speed. You may have to make minor adjustments on the L screw after adjusting the H screw to smooth out acceleration from idle to MAX speed so that you do not have stalls or sluggish acceleration.
There is one major NO NO when making carb adjustments... NEVER screw the jets tightly closed. The jet tips will jam into the carb body and twist off. If you ever have to close the jets completely... ligtly close them.
Thanks for choosing FixYa,
Kelly
Nov 30, 2010 | RC Tuning Boat
My text is to small i needto find out how to change font
Right click over the desktop area over anywhere except an icon. Select Personalize - a window will open, then select Display Settings. A second window will open - adjust to correct resolution to desired size.
Oct 25, 2010 | Microsoft Windows Vista Home Premium with...
I want to use bell's adjustment inventory for adolesecent students. i needto have it. how can i get it
Sep 11, 2010 | Bell Cocoon Child Carrier
Craftsman 2 cycle blower stalls.
Most Probably the problem lies in the adjustment of the carburettor. There are two needles in the carb one for lowend adjustment and one for high end adjustment. Your lowend adjustment seems fine. The highend needle needs to be adjusted. Following are some very detailed procedures for adjusting these types of carbs
http://tech.flygsw.org/walbro_tuneup.htm
http://www.drystacked.com/Walbro%20Carburetor%20Theory%20ebook1.pdf
If your machine has a carb other than a "Walbro" dont worry the procedures are same. I am sure if your engine has not completed its life span this will solve your problem.
May 19, 2010 | Craftsman Blower Attachment
Serpentine belt adjustments......need to tighten
you cannot adjust the seroentine belt, if it loose then you needto check your belt tensioner defects.
if it make noise then check the belt for glaze, replace belt
Mar 17, 2010 | 2000 Isuzu Rodeo
Slight hesitation when accelerating and when you back off,the revs do not idle back in relation to throttle position straight away.bike has minor exhaust leak at head.bike is used as daily transport to...
sounds like a vacum leak check you carb boots (between carb and motor)make sure there are no cracks if there are they will needto be replaced
Jan 28, 2010 | 1981 Suzuki TS 185
Troy Bilt Tb20cs 2 Cycle 31cc Gas String Trimmer 17" Cs Logo
319 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
