Question about Asko 1375 Dishwasher
Front top panel broken on ASKO model 1375 where can i get a replacement
Its the top panel behind control knobs
  • Asko Master
  • 3,247 Answers
Parts of that type might be hard to get for this model.
Try this site and select the part based on your dishwasher finish.
http://www.repairclinic.com/Shop-For-Parts/a9b126d610738/Model-1375-Asko-Dishwasher-Parts
Posted on Apr 05, 2014
Timon90
  • 126 Answers
SOURCE: dishwasher does not drain after cycle
Check the drain pump and/or drain hose. It may be clogged woth something.
Posted on Jan 27, 2008
SOURCE: asko 1375
kenmore quite wash making loud screaming noise-was told it could be something stuck in impeller. Could this be true and if so how can I check/fix this myself?
Posted on Jun 24, 2008
  • 24 Answers
SOURCE: ASKO D3350 Dishwasher won't work.
possible failure of electronic board expensive to fix. May even be suprresion capacitor. A lot of brands used suppression caps on the ac input to filter out unwanted noise. When these blow they stink and some even arc but one thing is sure they cut the power to the rest of the dwasher may even throw out your power.Make sure it is switched off and unplugged before dismantling it.
Posted on Oct 08, 2008
  • 102 Answers
SOURCE: need upper/lower racks for Asko 1375
An authorized servicer could order them for you but I just priced them and they would cost over $300. You can find a servicer at asko's website.
Posted on Aug 06, 2009
  • 7 Answers
SOURCE: The drain pump motor on my ASKO model 1375
Had a similar scenario on my Asko 1325. I simply removed the unit in preparation to chuck it, but once outside decided to check the inside of the pump/impeller and the electrical connections. Found plastic debris in the pump, and wiggled every electrical connector of its attachment and then re-attached it. Tried the Asko-fiasko outside and it worked.
BTW be prepared for an electrical failure/ meltdown as per the following two photos:e4b01cd.jpg47ce737.jpg
Posted on Sep 01, 2009
ASKO 1375 Dishwasher top rack keeps rolling out
Your dishwasher may have sagged since being level when installed.
May 20, 2016 | Asko 1375 Dishwasher
My ASKO 1375 seems to wash fine but will not drain. We checked the pump, filters and drain hose. All seem to be fine. Suggestions?
It is easy to have insoluble items clog underneath the lower spinner. Take it off and clean the holes thoroughly. Check for bits of glass. If this is not the problem, it could be that the pump is broken.
Dec 30, 2010 | Asko 1375 Dishwasher
Dishwasher begins to fill then stops with no further progress.
Welcome to FixYa.
Based on hoe you`ve described the issue with your Asko, initially it sounds like a faulty inlet/water fill valve...
But, I`d like to clarify the symptom first. Does the unit complete the fill cycle and then do nothing, or it just energizes the fill momentarily then does nothing ?
Also I will ask to verify the model is an Asko 1375 ?
I`l watch for your reply.
Regards,
Macmarkus :)
Sep 02, 2010 | Asko 1375 Dishwasher
My Asko Front load washer model W6021 Prewash
hi you need to replace the inlet valve,take off the top panel and you will see the valve behind the soap drawer with the black hoses.you can get a book from asko.com.au
Jun 15, 2010 | Asko W6021 Front Load Washer
I have an ASKO dishwasher 1375 model in black. Can it be spray painted with bisque appliance paint to match my other appliances?
You can try applianceart.com, they have alot of different color and texture appliance covers.
Oct 20, 2009 | Asko 1375 Dishwasher
The drain pump motor on my ASKO model 1375 dishwasher wont stop running
Jun 22, 2009 | Asko 1375 Dishwasher
Need upper/lower racks for Asko 1375
Jan 02, 2009 | Asko 1375 Dishwasher
Strange odour from dishwasher.
There was a recall of this model for fire hazard - the recall is still in effect
Dec 17, 2008 | Asko 1375 Dishwasher
How do I remove the selector knob on washer
The main selector control know spins off by turning the selector inner knob counterclockwise. The outer ring will then pull off. The other knobs are held on with friction and should just pull off.
The best way to get behind the front panel is by removing the top panel of the machine. There should be 2 gray/solver tabs at the back of the machine near the top if you remove the 2/4 screws from the top then the whole top panel will slide forward then lift off.
Be sure to unplug the machine first.
Aug 02, 2008 | GE WSXH208A Front Load Washer
How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Apr 22, 2008 | Whirlpool LTE6234D Top Load Stacked...
Asko 1375 Dishwasher Logo
96 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
