Question about Poly-Wood Polywood Adirondack Chair Finish: White"
Static electricity from adirondack chairs
Plastic recycled chairs from CP plastics. I get a shock after I sit in them and then touch anything...metal, dog, person.
  • 3,187 Answers
Depending on the feet there can be some rubber feet you can put on these plastic seat's this will stop the static build up in the plastic, also this can help dont leave the seats out in the sun wash them before use (water will remove the static) also dont were any wooly cottons when you use the seat's as the static from you clothes can build up in the seat. hope this helps. other thing you can do is make a grounding copper strip from the seat to the ground but this would not last long as the chair moving and bending.
Posted on Apr 03, 2014
It keeps making a static sound. and it lights up with the sound because there is a small shock that happens ever 10 seconds in the back above the filter
That happens when the electrostatic grid needs to be cleaned. There should be instruction for cleaning the electrostatic grid in the owner's manual.
Nov 05, 2013 | Air Purifiers
Machine doesnt turn on. Is there a reset
Check the screen to make sure the plastic piece is depressing the switch at the bottom...the machine will not activate to on if this switch is not on..and depressed by the plastic piece on the Flair SCREEN.
Apr 29, 2012 | Ecoquest Flair Air Purifier
Why it do not turn on?
You need to check a few things: 1. Is the plug in the back fully seated into the plug receptacle?
2. Is the filter in the back installed correctly so the plastic tab is depressing the safety switch?
3. Do you have a ceramic plate installed in the grooves with the metal tabs touching on both sides?
Erich
Jul 27, 2011 | Alpine Air XL-15 Air Purifier
Ionic Breeze GP S1830 - makes a sizzeling noise
Funny you should post this when you did as I just finished reassembling my S1730.
Mine was making very loud noise, arcing violently, smoking slightly and would give a good shock when you touched the plastic covers(yes dirty plastic will conduct electric current).
1. Unplug the unit
2. Take the plastic covers off, front has four screws and back has snap at bottom, both slide up when loose.
3. Wash the plastic covers
4. take the light out and clean it with windex
5. Vacuum the inside, be careful of the two corona wires
6. Find the bead on each corona wire and while turning them slight so the edges scrapes the wire, move them back and forth to scrap the white power off the wires
7. scrape the cone shape plastic that the corona wires runs into, this build up is the primary culprit of the arcing which is the noise you hear. be careful of the corona wires again. I used an exacto knife and gently scraped it, sandpaper has been suggested elsewhere, once done scrapping, wipe down to clean any residue. The top cones are only part accessible, after cleaning mine the noise still persisted but acceptably lower than before. I think if you completely take apart the unit you can clean this cones better.
8. Reassembly is the same is opposite of disassembling.
Hopes this helps you.
Aug 21, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
Which glue to reattach chromed plastic to plastic?
Use old fashioned model cement. Not the child safe type. The old type will melt the styrene to the styrene. The new stuff only fills the gap but never really makes a good bond.
Mar 10, 2009 | PUR (FM-9500) Air Purifier
Same Problem - "Sparking-then-into-Dry Mode"
Find where the arc is emmitting from on the inside blade put a piece of electrical tape over it and its fixed
Aug 13, 2008 | Sharper Image Hybrid GP (SI724) Air...
We have a Human Touch Sharper image chair purchased online from Sharper image. The remote control has come detatched from the electrical wiring. It has pulled out. Our electrician suggested that we ask if...
There isn't one. The reason why Sharper Image went out of business is because the Ionic Breeze was proven to be ineffective product and harmful to use in some cases based on Consumer Reports data as well as data from the EPA. They sued Consumer Reports, lost the case, and had to pay all the legal bills.
The Consumer Products Safety Commission is going to making decision on all ionizers by the end of the year. It's quite possible that no one will be selling them anymore.
There is thread I left in the Ionic Breeze section about the EPA data on ionizers and the harmful effects of using them as well as a link about what happen to Sharper Image.
This product should have been regulated a long time ago. Orek and few others are going to be pulling the plug on them real soon.
Jul 29, 2008 | Sharper Image Professional Plus Ionic...
Bionaire LC0760 Air Purifier
sorry Thats not my area of expertise.I would try asking one of the other
Mar 23, 2008 | Air Purifiers
Annoying ticking
My air purifier was doing the same thing. The ticking noise you are hearing is caused by dust build up on the ionizer pins. When the ionizer pins collect too much dust, they tend to start making the clicking/ticking sound caused by static electricity. The solution is simple. Take the filter out and clean it real good (follow directions on filter on how to clean). Now, with the filter out, if you look down inside the vent where the filter was, you'll see a white piece of plastic with nine holes in it that are about the size of a silver dollar. Directly in the center of each hole there will be something that looks like a needle, those are the ionizer pins and they will probably have dust built up on them. Next, with the filter out, blow out the air purifier with compressed air to clean all the dust off the ionizer pins. This should take care of the problem, it worked on mine.
Dec 02, 2007 | Kaz Honeywell QuietClean HFD-135 Air...
EcoQuest Flair Air Purifier
get more distance from the two sparking points....with the power disconected, pryde the two metal points apart as mach as possible..to a quarter of an inch!
Nov 14, 2007 | Ecoquest Flair Air Purifier
Poly-Wood Polywood Adirondack Chair Finish: White" Logo
252 people viewed this question
Top Poly-Wood Air Purifiers Experts
Are you a Poly-Wood Air Purifier Expert? Answer questions, earn points and help others
