Question about Black & Decker Coffee Makers & Espresso Machines
When plugged in the clock numbers keep going and I cant turn the pot on or off
The numbers keep going and I cant turn it on and off
    Problem Solver:
  • 5 Answers
You may have one of the buttons depressed /stuck try using a Q tip with vinegar around the buttons make sure to unplug the unit and allowing it to dry for a few hrs befor plugging it back in
Posted on May 05, 2014
What makes a perculator heat?
Hi, If you have a Farberware, Just look into the bottom of the pot. There you will see what looks like a hole in the pot. That is the high heating element, under the pot, when you go to make coffee the pump ( rod) sits into the hole. When you turn it on to make coffee the high heating element that the pump is in gets very hot and starts pushing the water that is in the hole to the top (that is called perking) the hot water goes over the the top and the drops into the coffee, This keeps going on until the thermostat feels it has reached 190 degrees or close to it and turns the high element off. While this is running it's cycle the keep warn is on helping the water to get hot, when the main element is off the keep warm element that runs around the bottom of the pot stays on all the time the pot is plugged in. Should the coffee get to cold the thermostat will turn the main heating element back on until it is back to 190. This system was developed by Farberware and a lot of makers copied it, But Farberware sold the pots and was known for a FAST and HOT cup of coffee. Farberware started making them in China and the pots are having a hard time keeping it up to American standers, and parts are very scarce.Farberware USA pots have been around a long,long time and are still going strong . I hope this helped you to understand how the pot works.
Dec 09, 2010 | Faberware 12-55 Cup Coffee Urn
How do you program?
Hello!
This could help
How to set the time:
1. Plug in the unit. Wait until the hour on the LCD starts blinking
2. Press the CLOCK button to set the correct hour
3. Press the SET button to switch to minutes
4. Press the CLOCK button to set minutes
5. Press the SET button to accept the time
***there is no AM icon, only PM***
How to program delay brewing:
1. Press and hold SET until the hour begins to blink
2. Press PROGRAM until you see the tiny bell icon on the bottom of the screen
3. Press CLOCK until you get to the hour you want to start brewing
4. Press SET to switch to minutes
5. Press CLOCK to get to the minutes you want to start brewing
6. Press SET to finalize
Press PROGRAM to activate. When the little bell is flashing, the coffee pot is set to go on at the desired time. While the coffee pot is on or in warming mode, there are vertical lines on the top of the LCD screen that shows you it is on. If you press the ON/OFF button, you can turn it off before the two hour keep warm cycle is complete.
Please rate this answer. thanks
Nov 24, 2010 | Faberware FCP512S Cordless Electric Kettle
After a few months, the CD player stopped working. It doesn't spin, and it shows "no" in the clock display
Each CD Player has a potentiometer to adjust the laser assembly alignment. The T609t CD player has a tiny pot of 2000 Ohms (2K) about 1/8 x 1/8 of an inch on a tiny printed circuit board right under the laser assembly. I tried adjusting its value with no success. The wiper was not making contact with the carbon layer below it. I removed it and soldered in 2 wires of 6 inches to work out of the box. I attached at the end of the 2 wires a small printed circuit board of 1/2 x1/2 inch to solder a new pot of 1000 Ohms in series with 50 Ohms resistor. I started increasing the pot value until about 700 Ohms and immediately the Player showed 01 on the display and started to play IL DIVO songs. Obviously after each new setting of the pot I had to repeat the same routine: Power off, power on, hit Play, see No CD message on the display until I found the right initial value on the pot. I still had to tweek it up toward 750 Ohms because it was skipping a bit of song number 8. It is working fine now.
I taped my mod, tucked it in the box and closed the whole thing until the next time it will go out of alignment.
The pot I am using is bigger (3/8x3/8x1/4) it takes 44 turns of 180 deg to sweep it from 0 to 1000 Ohms. The old pot is swept from 0 to 2000 Ohms in one turn of 120 deg. The 50 Ohms resistor was for safety in case I hit 0 Ohms on the pot. I kept it in the mod in case I want to hook a scope.
Cheers
Peter
Jan 18, 2010 | Timex T609T Clock Radio
The male plug in the base of the pot has broken
Hi
if you go here
http://www.cuisinart.com/parts_accessories/index.php?cat_id=3
With your model number you should be able to order direct
Good luck
Feb 16, 2009 | Cuisinart Coffeemakers
Programing clock on saeco coffee pot
You can get the instruction manual for your machine at saecooutlet.com, Click on user manuals and then select your machine.
To set the clock, hold the hour or minute button until the display flashes then adjust the time.
Feb 01, 2009 | Saeco TDCM15 Renaissance Stainless Steel...
Digital clock gains time
digital clocks work of the frequency input of the power source so it is possible to have it adjusted by a technician
like fine tuning a radio frequency there may be a pot that can be tuned to mains frequency exactly
talk with technicians in radio or tv shops or possible some jewellers who work on electric clocks may help
Nov 26, 2017 | General Time Corporation Westclox Bell...
Farberware FCP512S coffee pot instructions
Plug the unit in
Hope this helps
Sep 09, 2008 | Mr. Coffee ISX23
Keeps flashing 12:00
I just kept plugging and unplugging the coffee pot. Eventually, the clock stopped blinking, the buttons worked, and all was well.
Jul 19, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
It wont heat up and all the lights just keep blinking
I have the same problem EVERY time I want to use the crock pot. My solution has be patience. I find that if I turn it on, and the light blinks, but when i click it it will blink on 4 hours, then go back to the blinking light. By keeping the crock pot plugged in and off for about 10-15 minutes I was then able to set the crockpot up for cooking. As if the capacitors inside the unit needed power stored in them from the wall.
Dec 21, 2007 | Rival 5865-W 6.5-Quart Slow Cooker
Coffee Makers & Espresso Machines Logo
70 people viewed this question
Top Black & Decker Coffee Makers & Espresso Machines Experts
eyecam
Lyle Siemens
Lyle Siemens
Are you a Black & Decker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
