Question about Brother MFC-7820N Laser Printer
DRUM END SOON mfc7860dw
Just says drum end soon and I would like to reset the drum.... How
  • 624 Answers
SOURCE: How do I reset the Change Drum Soon on the display?
All you should have to do is: -replace the old drum with the new replacement. -with the front door open press the Clear/Back button -press the number 1 button and when ?accepted? appears on the LCD close the front cover. That should do it. Let us know if you have any other questions and please don?t forget to rate this post.
Posted on Mar 01, 2007
  • 1684 Answers
SOURCE: my hl 4040cn says drum ends soon. do I have to
Yes, The drum units have a set number of copies before they need to be replaced. This printer has a drum life of 17000 pages. The part number for the drum is DR110CL Just do a Google search or check your local office supply store.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jan 05, 2010
  • 150 Answers
SOURCE: drum en soon MFC 7340
The drum counter counts to 15000 then says replace drum soon. Just open the front door and press options. Select yes.
Posted on Feb 04, 2010
  • 73 Answers
SOURCE: I have on my Brother HL-4040cn, drum end soon.
Here is a photo of the drum unit and a link to the Brother website for you printer.
http://www.brother-usa.com/support/default.aspx?PGID=1&R3ModelID=HL4040CNaefb82c.gif
Posted on Mar 11, 2010
Jimsta01
  • 405 Answers
SOURCE: Keeps saying drum to end soon.
You need to open the front cover ( where the drum and toner is installed), then press the clear/back button, then will ask if you replaced the drum, chose one for yes, it will says accepted, then close the cover.
Posted on Apr 13, 2010
Drum end soon again
My MFC-7420 began to display the message "Drum end soon" so I quickly went out and purchased a new drum. But I decided not to install it until I needed to. Because what does "drum end soon" mean? I thought it would mean that the print quality would deteriorate enough that I would notice the problem. So I continued to replace toner as needed, and pushed the blue cleaning thing down the wire regularly. This went on for over 3 years until *finally* I started having regular print job production problems. I replaced the drum, and the problems were solved. So,my advice is be prepared, but don't replace the drum until you have to -- the message means very little.
Mar 18, 2014 | Brother MFC-7340 All-In-One Laser Printer
How do i reset ricoh sp 1200s drum unit
why toner life end message keep on showing on sp 1200s prints.
Aug 04, 2012 | Ricoh Office Equipment & Supplies
I still receive the error message "Replace Drum", "Drum End Soon", "Drum Near End", or "Drum Stop" after I replace the drum unit with a new one.
did you do the reset procedure? if not it's in your owners manual under the section "replacing the consumables".
hth,
razors
Nov 29, 2011 | Brother HL 5250DN Laser Printer
The printer screen shows change parts and on the wlan computers connected to it says that the drum end soon and that panics me a lot as i paid a lot for this damn computer
Did you recently replace the drum and the warning is unexpected?
Why does the message "Drum End Soon" continue to appear on the LCD after I replaced the drum?
Description:
This message would continue to appear if the drum unit counter was not reset when you installed a new drum.
To reset the drum unit counter, follow the instructions below:
  1. Press Menu on the Control Panel.
  2. Press the Up or Down Arrow key to select Machine Info..
  3. Press OK.
  4. Press the Up or Down Arrow key to select Reset Menu.
  5. Press OK.
  6. Press the Up or Down Arrow key to select Drum.
  7. Press OK.
  8. Press 1 to reset the drum unit counter.
You can use this procedure to reset a drum in order to continue to use up the remaining 'life' of the drum; recognizing that you will need to replace the drum when you start having print quality issues.
You may find this site very useful.
Trust this is helpful. Please vote.
Dec 31, 2010 | Brother MFC-9840CDW Laser Printer
What does drum end soon mean? Status monitor for my brother MFC-944)CN printer is saying Drum end soon! the file is being sent the status says ready, the paper goes through and comes out blank!
1. replace drum unit
2. after replacing reset the counter - press "3" and "9" button at the same time in the ready state, the reset menu will appear on the LCD, select "DRUM" and press "ok"
resetting without actual drum replacement might damage your printer.
Jun 29, 2010 | Brother MFC-9440CN Laser Printer
I recently noticed a message that said "drum end soon" on the screen portion of my printer. With that I went and replaced the drum and toner. The problem is this: The "drum end soon" message never quit...
  • Press Menu on the Control Panel.
  • Press the Up or Down Arrow key to select Machine Info..
  • Press OK.
  • Press the Up or Down Arrow key to select Reset Menu.
  • Press OK.
  • Press the Up or Down Arrow key to select Drum.
  • Press OK.
  • Press 1 to reset the drum unit counter.
Thank you !!
Jun 09, 2010 | Brother MFC 7840W Printer
Drum end soon, what does that mean
It means that the drum will end soon. The drum is the piece that holds the printer cartridge. It costs about 115+ dollars at the store, but on ebay, you can get it for a good 60 bucks. :)
May 26, 2010 | Brother MFC-7440N Laser Printer
Drum End Soon
You will soon need to replace the drum. Its considered a consumable just like the toner cartridges. You can purchase the drum anywhere that sells brother pruducts.
May 24, 2010 | Brother HL4040CN Laser Printer
Drum en soon MFC 7340
Feb 03, 2010 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-7820N Laser Printer Logo
65 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
