Question about Frigidaire Washing Machines
Affinity Frigidaire Gas Dryer does not heat
AGQ6000ES4 Gas Dryer will not light and heat. What can we do to repair and find out what the problem is. The vent was plugged when the problem occurred. Thank you.
  • Frigidaire Master
  • 2,524 Answers
I have some experience, here, and here is what I have found.
You will need to take the dryer completely apart, and clean the lint out of the whole thing, you may be astounded what you will find. I have recently taken 2 full shoe boxes of lint out of a machine on the inside .If that doesn't fix it, you must then take a multimeter or an ohm-meter and find out what internal fuse or thermostat has "popped" and needs replacement. There should be as few as 3 of these, and may be as many as 7.
Be blessed.
Posted on Jun 23, 2014
Affinity Gas Dryer AGQ6000ES4 will not heat
Hi Margie, this is JK. I understand that your dryer is not heating. I recommend checking for possible restrictions in the venting or lint filter. Make sure that you have not accidently selected the air fluff or no heat. If you find that these settings are correct do a reset on the dryer by turning off the power for about 10 seconds and return power to the dryer. Turn on the dryer and select the normal cycle. At this time if you find the problem still persists, you may want to consider contacting a professional technician. The concern could be a control board, high-limit thermostat, gas supply, igniter, or the sensor. Hope this helps!
Apr 01, 2014 | Frigidaire GLGQ2152ES Gas Dryer
My affinity electric dryer shuts off after a few minutes, isn't heating, and blinks EA4
That means that the ignitor is most likely failing to start the process to ignite the gas. The ignitor is like a light bulb and can burn out.
Here is a link to the information about that: http://www.managemylife.com/mmh/questions/289969-frigidaire-model-faqg7077ka-error-code-e4a-heat
Aug 14, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
It just doesn't seem like my frigidaire gas affinity dryer is drying as fast as it should
Hey Car Guy,.. there are two factors that determine how fast the clothes will dry:
1- air temperature, Is the gas burner is lighting and heating the air? Just stop the dryer mid-cycle and feel the clothes - if they are hot, then the burner/heating part of the dryer is working ok.
2 - adequate air going through the dryer. This is usually where the problem lies. There is a lint filter at the dryer somewhere, accessed either where the door opens, or on the top of the dryer....there may be an additional lint filter somewhere on the exhaust duct. Check for that, and check your air flow where it exhausts outslde. See that the flappers of the backdraft damper aren't stuck closed etc.
If you have good heat and good air flow, then it's doing all it can.
Mar 22, 2013 | Dryers
Affinity aeq7000eg0 no heat stops after 20 minutes
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 01, 2011 | Frigidaire Affinity AEQ6000WH Dryer
My frigidaire affinity dryer works but does not heat up.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 06, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Frididaire affinity gas dryer that lights up but
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jul 25, 2010 | Frigidaire FGQ1442ES Gas Dryer
Frigidaire AGQB6400FS not hot
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 30, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
My frigidaire affinity dryer is not heating up but still works what is wrong?
heatman101
May 11, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Dryer not heating frigidaire affinity front loader
heatman101
fgssggs
Feb 22, 2010 | Frigidaire Affinity AEQ6000WH Dryer
Washing Machines Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
