Question about Frigidaire GLGQ2152ES Gas Dryer
Affinity Gas Dryer AGQ6000ES4 will not heat
Is there a manual online that will show where the fuse is located. We cannot find one on the vent inside the dryer. What can we do to troubleshoot this dryer.
  • Official Brand Answer
  • 2,267 Answers
Hi Margie, this is JK. I understand that your dryer is not heating. I recommend checking for possible restrictions in the venting or lint filter. Make sure that you have not accidently selected the air fluff or no heat. If you find that these settings are correct do a reset on the dryer by turning off the power for about 10 seconds and return power to the dryer. Turn on the dryer and select the normal cycle. At this time if you find the problem still persists, you may want to consider contacting a professional technician. The concern could be a control board, high-limit thermostat, gas supply, igniter, or the sensor. Hope this helps!
Posted on Apr 15, 2014
Affinity Frigidaire Gas Dryer does not heat
I have some experience, here, and here is what I have found.
You will need to take the dryer completely apart, and clean the lint out of the whole thing, you may be astounded what you will find. I have recently taken 2 full shoe boxes of lint out of a machine on the inside .If that doesn't fix it, you must then take a multimeter or an ohm-meter and find out what internal fuse or thermostat has "popped" and needs replacement. There should be as few as 3 of these, and may be as many as 7.
Be blessed.
Apr 01, 2014 | Frigidaire Washing Machines
Workes fine no heat
the temperature thermostats and or heater are bad, on electricdryers, you can ohm out to see what is defective.
There's no heat dot_lineone.gif 1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
electric dryer
1 Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
2 Thermal fuse
Oct 27, 2009 | Candy CDC266 Dryer
Dyrer runs no heat cannot locate fuses
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
3. Thermal fuse
Jul 20, 2009 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Dryer not heating
If gas, check the following.
1. Gas valve coils
2. Thermal fuse
3. Igniter
If electric, check the following.
2. Heating element
3. Thermal fuse
Jun 25, 2009 | Hotpoint Dryers
No heat
GAS DRYER CHECK LIST
1. Gas valve coils
2. Thermal fuse
3. Igniter
ELECTRIC DRYER CHECK LIST
2. Heating element
3. Thermal fuse
Jun 22, 2009 | Kenmore 63942 Dryer
Kenmore dryer will not heat
If gas, check the following areas.
1. Gas valve coils
2. Thermal fuse
3. Igniter
2. Heating element
3. Thermal fuse
Jun 19, 2009 | Kenmore Dryers
Drier does not dry or blow heat
IF this is a Gas dryer, check the following.
1. Gas valve coils
2. Thermal fuse
3. Igniter
If this is an electric dryer, check the following.
2. Heating element
3. Thermal fuse
Additional Checks.
Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
Jun 06, 2009 | Whirlpool Dryers
NOT HEATING
Ok, you did not state if this dryer is electric or gas so, i will post both solutions for each dryer type.
ELECTRIC--CHECK THE FOLLOWING
2. Heating element
3. Thermal fuse
GAS--CHECK THE FOLLOWING
1. Gas valve coils
2. Thermal fuse
3. Igniter
Jun 01, 2009 | Whirlpool Dryers
Dryer not heating
For a gas dryer, check the following---
1. Gas valve coils
2. Thermal fuse
3. Igniter
For a electrical dryer, check the following---
2. Heating element
3. Thermal fuse
May 31, 2009 | Whirlpool Dryers
My Maytag dryer, about 10 years old, has no heat.
For gas dryers, check the following below.
1. Gas valve coils
2. Thermal fuse
3. Igniter
For Electric dryers, check the following below.
2. Heating element
3. Thermal fuse
May 29, 2009 | Maytag Dryers
Frigidaire GLGQ2152ES Gas Dryer Logo
48 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
