Question about RTO Gas Motor Scooter 150cc
Electric problem on 150cc scooter
When i turn the key in the on poition the gas gauge normally goes up,therefor i cant use my electric start.When i kick start it and the bike is running the gauge goes up
5 Suggested Answers
  • 43 Answers
SOURCE: sym jet 50 , wont kick or electric start
compression may be getting low if this is a progressive problem.
Posted on Dec 31, 2009
SOURCE: I have a problem with my 50cc moped/scooter.
set light to it
Posted on May 12, 2010
SOURCE: ignition bike wont start
i got 2 lifan scooters 1 is a 2005 and the 2008 wont start the problem is no spark at the plug i check the cdi coil the pick up off the flywheel i check the on off switch iput these picese on the 2005 and they all work i took picses off 2005 still no fire to the plug 2005 runs like a top nice battery is new please can somebody help me tony
Posted on Jun 27, 2011
SOURCE: my scooter PanTerra no start, not even turn over
Most scooters have four things that need to be done before they can be started with the electric starter:
  • The ignition has to be turned on
  • The kill switch (usually near the right grip) has to be in the "on" position
  • The rear (left) brake lever has to be squeezed.
  • The starter button must be pressed.
Some scooters may have other interlocks on the front brake or the center stand. Check your owner's manual to make sure that you are doing all you need to to complete the electrical circuit which enables it to start.
If the scooter doesn't turn over when you've done all the required operations, there's an electrical problem with the battery. Make sure the battery is charged. If it is, make sure the fuse hasn't blown. If it hasn't, check to see if you are getting voltage to the starter motor terminals. If you are, the starter motor is likely defective.
If the scooter does turn over but still doesn't start you have to check for a spark and make sure gas is getting to the engine. To check for a spark, remove the spark plug from the cylinder, hold the tip of the plug against the cylinder head and crank the engine. You should see a spark across the gap. If you don't, there's a problem with the ignition. Could be a faulty coil or electronic ignition module which will have to be replaced, or it could just be a lose wire.
Hope this helps.
Posted on Jul 04, 2011
I have a 2008 Titan velocity 150cc scooter and the gas gauge is not working any ideas ?
Hi, Jeff and the usual suspects are:
1. Blown instrument fuse.
2. Faulty sending unit.
3. Faulty wiring between sending unit and gauge.
4. Faulty ground or power connection.
5. Bad fuel gauge.
For more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
My gas gauge doesnt work on my scooter
One way to fix non responsive stuck gas gauge on 50cc gy6
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
https://www.scooterdomain.com/chinese-parts/full-size-scooter-parts/125-150cc-scooter-parts
http://www.49ccscoot.com/manuals/Baja_SC150_Owners_Manual.pdf
Mar 10, 2017 | GAS Motorcycles
Looking to change from vac. fuel pump to elec, pump
Tylon, Go for it, Electric pump may fix some difficult starting issues. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
MC54 250B Replace Fuel Pump Vacuum to Electric
Part 1 Parts you need for electric fuel pump install on your 150cc scooter...
Part 2 Facet electric fuel pump install into Flyscooters il bello 150cc...
Aug 18, 2016 | Cars & Trucks
I have a cpi Oliver city scooter on the starter relay is a black and red wire witch is normal but there is two wires with have been cut and the leccy start won't work but everything else dose
Hi, Nathan for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your CPI, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Scooter Troubleshooting Scooter won start All about Scooters
Scooter electric start doesn work scooters
http://www.scootermasters.com/manuals/CPI%20Cheetah%20XS%20Service%20Manual%202t.pdf
CPI OLIVER CITY Owner Manual
Jun 29, 2016 | Cpi Motorcycles
49cc taotao can't start with electric, only kick start. electric dies when brakes applied
Sounds like your battery is dead. Sometimes they seem ok, or read good on gauge...but just a little load kills it. May also be internal short or connection problem inside battery. Either way, I'd start there.
May 01, 2016 | Electric Health & Beauty
Have no spark to plug found a 2 wire clip with the same colors at the battery area that is not connected to anything. dont know where to connect trouble finding manuals or video
My scooter has no spark how to fix. gy6 chinese ... - YouTube
? 2:29
https://www.youtube.com/watch?v=UU4S0Ov9q4c
Aug 24, 2012 - Uploaded by Rolling Wrench
Purchase our "NO SPARK KIT" click the link below: ... Myscooter has no spark how to fix. gy6 chinese scooter 139qmb qmb139 50cc 150cc .... i have a 2003 panterra fusion scooter with a 49cc motor,i just purchased a new cdi box,new coil wire and a new stator and ... Put gas in it tried it again nothing.Missing: rto
RTO 150cc scooter no spark Questions & Answers - Fixya
www.fixya.com/tags/150cc_scooter_no_spark/browse/rto
Ask your RTO 150cc scooter no spark questions. Get free help, advice & support from top RTO experts. ... no spark. Ad. Question about Gas Motor Scooter 150cc.
Nov 29, 2015 | RTO 150cc Gas Motor Scooter
My 150cc scooter starter motor running as soon as I connect the battery even while the ignition key is off.... I changed the relay but it didn't help.. what is the problem?
The starter solenoid is somehow grounding out.
Something is touching the positive and negative on the solenoid.
Usually you touch the negative and positive on the solenoid and it will start to turn over however it won't start.
Jun 20, 2014 | Sport & Outdoor - Others
How to unlock the seat on 150cc gas scooter.
Look around below the seat, usually on the left side. There's often a lock there and if you insert the key and turn it the seat latch should release. Some scooters unlock the seat latch by turning or pushing the key a certain way in the ignition.
May 06, 2014 | Motorcycles
Gogo elitescooter lights indicate battery fully charged but scooter will not go
Make sure the free-wheel lever is engaged and the charger is unplugged from the scooter before you try to turn the scooter on. If the battery gauge goes up when you turn the scooter on and there are no beeping sounds you should be good to go.If the battery gauge drops to the red when you try to accelerate slowly, your batteries are shot. (Typical replacement in 24-48 months).If there is any beeping when the key is first turned on then there is a problem and the number of beeps indicates the problem found by the computer during the POST. [Power On Self Test]
Dec 26, 2011 | Electric Mobility Mobility Electric Power...
Electric scooter Troubleshooting
A small tip here - bigger is better. The large diameter wheels clear gaps in concrete or pavement that would hang up a skate wheel or a scooter with smaller wheels. Most electric scooters also handle well in gravel and small terrain features. We don't recommend slamming electric scooters into a curb to get over it like some people do with their bike. This could result in damage to the electric scooter. Simply Ollie up a curb and keep going.
Aug 27, 2008 | Drive Medical Mini Phantom Three Wheel...
Electric scooter question
i have lost the key for my shoprider scooter
Aug 27, 2008 | Drive Medical Hawk 3 Wheel Compact Scooter
RTO Gas Motor Scooter 150cc Logo
21 people viewed this question
Top RTO Toys Experts
Timllfixit
The Scrivener
Pete Bruk
Are you a RTO Toy Expert? Answer questions, earn points and help others
