Question about Miele Coffee Makers & Espresso Machines
Miele CVA 615 door switch problem
Unit will not power up with door closed but does power up when manually depressing door switch
Ya1da
  • 4 Answers
SOURCE: can you give me the process to descale the miele cva 615 coffee machine?
Here you go just click on this link I put the manual on my site: http://yalda.us/CVA615_us[1].pdf
Posted on Mar 12, 2008
SOURCE: Miele Coffee maker cva 615
Actually, I had done all that and am very good about rinsing machine daily.  Finally, had Miele come out and our problem was the beans.  We had been using Starbucks beans for 4 years and there is just too much oil on the beans even with the cleaning.  The screens were fine, but there was something that I honestly can't remember that was clogged.  The technician had to take apart the brew unit to get it cleaned.  There was so much "gunk" that had built up over the years even with the descaling and rinsing.  We now use Dunkin Donuts coffee and it is amazing how there is no oil on those beans.  Anyway, thanks for the help.
Posted on Oct 20, 2008
espressonist
  • 1711 Answers
SOURCE: HI THERE! I HAVE A MIELE model CVA 615 and no more
You can remove the end tip of the steam pipe and clean it dry milk can block hose. If you litlle steam pressure you can boil water in a glass and keep it allnight long so the dry dirt milk can be soften and the pressure of the same steam can spit all the dirt out so the steam hose can be clean again.
Posted on Feb 13, 2010
  • 177 Answers
SOURCE: where can I buy a Miele CVA 615 Expresso
The only Miele spare parts are direct from Miele or through a Miele service agent. Have a look on the Miele website for your nearest Miele branch or service agent in your country.
I work for Miele and they only sell parts this way. if you call the Miele spare parts number off the website and tell them you have a cva615 they will be able to mail one to you.
Hope this helps.
Posted on Apr 02, 2010
SOURCE: Miele CVA 4075 brew unit locked
Turn your machine off. Close the door. Depress <clear>, holding it down, press <on/off> then let go of both. Then press <clear> 3 times. On 3rd time, hold it until Service menu appears. Select <brew unit> then press left arrow to turn from <off> to <on>. Then press right arrow by <select> This will turn your brew unit drive to the correct position and you should be able to get your brew unit in/out and your waste container back in. Make sure to turn your machine off/on again to get out of Service Menu. I have a picture of how the wire needs to be inserted to get that back on. It's definitely not intuitive, but send another note with your email address and I can send the pics.
Posted on Jun 03, 2010
Miele cva 5060 when i press on shows 'insert boiling unit.' And stucks there any solutions pls .
any chance you could put up a photo of your brew unit ? something has fallen out of mine and i can't figure out where to put it !
Aug 20, 2015 | Miele Coffee Makers & Espresso Machines
Brew unit stuck miele 4062
This has happened to me many times. Just turn off the main power, turn it back on open the door and close it so the brew unit repositions itself. The unit should come out easily now.
Jul 07, 2014 | Miele CVA 4062 Stainless Steel
How to remove the back wall behind brew unit on miele cva 615?
The Brew unit present switch is located on the brew unit drive. On the 615 model not an easy feat - the top and back have to be removed as well as the electronics - the micro switch has an extension arm on it the can fall off if the brew unit hits it the wrong way - I am guessing that is what may of happened here
Jun 19, 2014 | Miele CVA615 Espresso Machine
Miele reset system
I have a Miele CVA 4085 built-in coffee maker. I found a post on how to get into the programming menu, which on the CVA 4085 is this:
  1. Open the door and switch off the power with the rocker switch on the top left.Wait at least 5 seconds.
  2. Switch the rocker on then VERY QUICKLY close the door and hold the clear button for 5 seconds.
  3. With your other finger touch the ON button then pull both fingers away at the same time.
  4. Do 5 rapid presses of the clear button but hold your finger down on the last press and keep holding it down until the programming menu comes up.
  5. Do not press the reset button that you see at the top of the menu (unless your German is quite good or you have access to Google Translate).
  6. Scroll down until you find the reset cleaning button (or whatever you want to reset) and select it. Once you have confirmed you can then exit programming mode by powering off.
It took me quite a while to get to this point, but at least I can now recognize the German word for drip tray.
Sep 07, 2012 | Miele Coffee System
I need to buy a miele cva 615 spare part, where can i get it and also need to identify the part number.
Call PCI parts, they have older units that they use for parts. They might have what you need. 415-401-9966
Jun 05, 2011 | Miele CVA615 Espresso Machine
Apr 13, 2010 | Miele CVA4070 Coffee Maker
Can you give me the process to descale the miele cva 615 coffee machine?
Mar 08, 2008 | Miele CVA615 Espresso Machine
Turn on
Check the power at the outlet make sure you have 208 or 240, if you don't then thats your problem. The CVA 615 will not turn on with 120V. If you have proper power requirements and it still does not turn on it could be the door close switch isn't making contact all the way. If it's still not working call MIELE at 1800-843-7231
Nov 25, 2007 | Miele CVA615 Espresso Machine
Coffee Makers & Espresso Machines Logo
60 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
just-ice
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
