Question about Frigidaire AGQ6000ES Gas Dryer
My frigidaire gas dryer will not heat
The vent to the gas dryer was plugged. Now the dryer does not heat. How can we find out which part needs to be replaced?
  • MS_WI_3013 Apr 09, 2014
    Margie, What is the model number? with a restricted dryer vent you have a thermal cut out or "safety fuse" that has opened and needs to be replced. They are not resettable, only replaceable.
  • Official Brand Answer
  • 2,267 Answers
Good Morning Margie,
I see that you are having trouble with your Frigidaire gas dryer heating. I also see that the vent is plugged. You definitely do not want that vent plugged. Your dryer needs proper ventilation in order for it to work correctly. The reason it might not be heating is due to the fact that that vent is plugged and is not getting enough ventilation. Unplug that vent, make sure that there is gas going to the appliance, and that the gas supply valve is open.
-Best Regards-
WP
Posted on Apr 04, 2014
    Habit-Forming:
  • 119 Answers
Posted on Apr 09, 2014
JR JR
  • 116 Answers
SOURCE: dryer works but won't heat
2 things ,,no heat whats so ever ,sounds like ignitor,, or little heat possible coils )gas)
Posted on Nov 30, 2008
jumptrout51
  • 3361 Answers
SOURCE: gas dryer won't heat up
The ignitor can glow and still be defective.
Take a volt meter and check for power at the gas valve while calling for heat.
If you have voltage, replace the coils again.
No voltage, replace the ignitor and flame sensor.
Posted on Mar 08, 2009
  • 659 Answers
SOURCE: dryer drum spins but no heat
These units have a limit switch is located near the burner compartment. It is about the size of a dime or penny with 2 wires going to it. In between the wires, there is a small button that you can depress firmly. This should reset the limit. If it trips again, you will need to replace the limit switch. Hope this helps.
Posted on Apr 11, 2009
localwonder
  • 6784 Answers
SOURCE: Turns on but wont heat up
Check the following areas to combat this issue. the most common problem spot will be a blown Thermal fuse.
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Posted on Jul 13, 2009
heatman101
  • 43501 Answers
SOURCE: gas dryer smells like gas heats up a little bit
The most common problem with gas dryers is the ignitor going bad....
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
heatman101
Posted on Apr 06, 2010
Affinity Frigidaire Gas Dryer does not heat
I have some experience, here, and here is what I have found.
You will need to take the dryer completely apart, and clean the lint out of the whole thing, you may be astounded what you will find. I have recently taken 2 full shoe boxes of lint out of a machine on the inside .If that doesn't fix it, you must then take a multimeter or an ohm-meter and find out what internal fuse or thermostat has "popped" and needs replacement. There should be as few as 3 of these, and may be as many as 7.
Be blessed.
Apr 01, 2014 | Frigidaire Washing Machines
Dry will run for 5min then shut down but will run ok in timer mode
Consider a temperature switch that cuts in(turns off) if the dryer gets too hot. Does Timer Mode run with the heat on. Your dryer vent may be plugged causing the dryer to overheat.
Jan 27, 2014 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Have cleaned all vents...gas dryer will not heat on any setting
Hi,If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.if you dryer is gas check out this gas no heat tip....If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 22, 2011 | Frigidaire AGQ6700FS Dryer
My frigidaire LEQ1442ES dryer runs tumbles but would not heat. Cleaned out vent, reset the house fuse not won't turn on, lights flash only.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 29, 2010 | Frigidaire FEQ1442ES Electric Dryer
Frigidaire Gas Dryer, won't heat to dry clothes, we have cleaned the vents , were full, now clear, why won't it heat up. Gas turns on drum turns.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 10, 2010 | Frigidaire AGQ6000ES Gas Dryer
Gas dryer smells like gas heats up a little bit
heatman101
Apr 05, 2010 | Frigidaire FGQ332ES Gas Dryer
Gas Dryer blowing cool air and will not heat up.
Look inside door and get the model number for me. Could be igniter, gas solenoids or temp control switch inside. Let me know, Thanks Sea Breeze
Mar 19, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Dryer is getting hot but clothes are not drying
You have a vent problem. Eliminate all (if possible) flex duct (replacing with ridged aluminum pipe and aluminum elbows). Clean lint out of remaining vent pipe. Make sure vent is not crushed or obstructed, especially behind the dryer. If possible, make sure outside vent termination is not a two inch opening. (you want a full 4 inches)
Nov 10, 2008 | Frigidaire GLGQ2152ES Gas Dryer
Dryers Logo
67 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
