Question about Cell Phones
My concord wont unlock I have tried the master reset but nothing happens when i tap or hold the home button please help also my lock is a code its a circle on screen and you long press to unlock it
    Scholar:
  • 91 Answers
Just do the process after switch off the phone
There is four simple step to format . just follow it. remember if ur phone memory have important data so u should be aware that i will erase ur data.but there is no other methods so..
1-
Power down your device. Before you begin the reset procedure, you will need to completely power your device off. If it is frozen, you can pull the battery out to turn it off.
2-
Press and hold the recovery buttons. The buttons vary from device to device, so you may need to look up the instructions for your particular phone. You will need to press and hold the buttons for a few seconds. Some of the more common button combinations include:
  • Volume Up + Home + Power
  • Volume Down + Power
  • Home + Power
  • If none of the above work, do a web search for your phone's model plus "recovery mode".
  • 3-
  • Select Factory Reset. Once the recovery menu opens, you can navigate the menu with the volume buttons. You may need to open the Recovery menu to find the Factory Reset mode. Use the Power button, some models use the camera button, to select your menu options.
  • You will be asked to confirm the factory reset.
  • 4--
    Wait for the restore process to compete. After your phone resets, it will be set back to factory defaults and will be like it just came out of the box.
    • thank u!
Posted on Apr 02, 2014
TanyaAD138
  • 77 Answers
SOURCE: I can't check my voicemail...HELP!
There's a setting in your phone called HTMF tones. That needs to be on.
HTMF tones is what converts button presses into information an automated system would understand ... If it gives you an options of either long or short ... short is usually standard.
Hope this helps.
Posted on Mar 26, 2009
AmrSabri
  • 59 Answers
SOURCE: samsung J400 forgot privacy lock code,i want to unlock
Hello lovechat1,
Remove the sim-card and switch on the phone .. and press this code *2767*2878# .. the phone will restore the factory settings.
Thank you for using FixYa.
Posted on Apr 09, 2009
SOURCE: mobile phone master reset
Dial *228 and press 1 to program your phone. This will reset after your programming is finished. This resets the lock code back to the last 4 digits of your phone number. If it doesnt want to program at the moment give it some time and it will do it so call again. Good Luck.
Posted on May 14, 2009
SOURCE: MY iphone won't shut off
Probably the flex cable that connects the button to the mother board is damaged. This part is cheap and easy to install.
You can find the replacement parts here:
http://www.piezas.biz/epages/wwwpiezasbiz.sf/en_GB/?ObjectPath=/Shops/demo132390/Products/%22Piezas%20Iphone%203G%22
Posted on Aug 19, 2009
  • 144 Answers
SOURCE: i need a free code to unlock my blackberry pearl
On all the Blackberries i have seen - the password if you get it wrong ten times it just deletes all the personal data on it and resets it to the operator defaults.
so if you havent had a chance to use it much because its locked out, just keep typing the reset password wrong, type blackberry when it tells you too, and keep trying until it says Wiping Handheld.
Posted on Sep 21, 2009
I can't get in to my phone it locked
Press power button and home button together but you must hold them both until a list appears top left then follow instructions to reboot . hope this helps ....
Dec 21, 2015 | Cell Phones
How to reformat or unlock Samsung Anycall SCH-W850
Hi Arjune,
You may want to try this steps: Perform a Soft Reset
Step 1 Press and hold the power button for 10 to 20 seconds.
Step 2 Release the power button and tap the "Power Off" option under the "Device Options" menu that appears. Tap "OK" to initiate the shutdown.
Step 3 Press the power button again to restart the device.
Perform a Hard (Master) Reset
Step 1 Tap the "Menu" key from the home screen and then tap "Settings."
Step 2 Go to "Privacy" and tap "Factory Data Reset" to review the Factory Data Reset information.
Step 3 Review the Factory Reset options. Place a check next to "Format USB Storage" to clear your device of user data, such as music, pictures and other account settings.
Step 4 Review the disclaimer and verify your changes before tapping "Reset phone."
Step 5 Tap the "Erase Everything" or "Yes" buttons to confirm the reset the phone to factory settings. The device initiates the restoration process to the original factory configuration.
Perform an Alternative Soft Reset
Step 1 Power off the phone. If the phone does not turn off, remove the back cover of the phone and take out the battery. Wait between 10 and 30 seconds and then replace both the battery and the cover to restart the device.
Step 2 Simultaneously hold down the power/lock keys.
Step 3 Release the keys when the Android screen appears.
Tips
Apr 27, 2014 | Cell Phones
Pattern unlock forgot
What exactly did you do? Hard reset set the phone as brand new, and no brand new phone comes with lock pattern. Just pressing the power and volume down key is not hard reset. After pressing theses combinations of keys, and the droid with the exclamation point show up, you must tap the home icon to get to the recovery, and from there scroll down to Wipe Data Factory, to select tap the menu icon, then choose yes and tap the menu icon again to select it. Go back, up to Reboot and tap the menu icon to reboot the phone. There should be no more lock.
Mar 20, 2014 | Cell Phones
Have a nokia 6230i have entered unlock codes but nothing happens phone still ask for security code what next
Try the default security code 0000 or 1234 or 12345 .If these code does not work then use the master reset code to reset your mobile from security lock.Visit the site Unlock-free.com get master reset code for Nokia 6230i.If you want correct network unlock code,you can get the code from that site itself.
Jan 15, 2013 | Cell Phones
How do i reset my lock phone
You can reset the Phone lock using the master reset code,What is Mobile Phone model and brand,It's NOKIA DCT or Alcatel Old Phones means get the master reset code from here Unlock-free.com and reset it.
Dec 26, 2011 | Office Equipment & Supplies
My nokia c6 01 is locked by phone lock code. How to unlock it?
you may visit some master reset code sites........
Jun 11, 2011 | Cell Phones
Bought a electronic deadbolt at Rona (Rona Collection). Installed it and i can open/close it with the remote control or a key. Can't open it by entering a code. I thought the factory code was 1234, but...
Rona Electronic Deadbolt Lock Instructions:
Default Master Code:123
Resetting Master PIN:
  • Remove batteries and put them back. You will hear a long beep and a short beep.
  • Press and hold the 0 button until you hear 3 long beeps and the LED flashes red for 3 seconds. You are now in program mode.
  • Within 10 seconds, key in a new master PIN (up to 12 digits) and press the UNLOCK button.
  • Key in the master PIN again and press the UNLOCK button. The LED will flash green for 1 second and the resetting is complete.
Adding a PIN:
  • Key in master PIN and press UNLOCK button
  • Press and hold 0 button until you hear 2 short beeps and the LED flashes for 3 seconds.
  • Release 0 button and you are in the Add PIN mode
  • Within 10 seconds, enter a new PIN and press the UNLOCK button. You will hear one beep.
  • Key in the new PIN again and press the UNLOCK button twice. When the LED stops flashing the PIN has been added.
Sep 23, 2010 | Deadbolt Locks & Locksmithing
My iphone didnt charge and its not turning on. my laptop charger is open like the inside part to charge it,i use half of my iphone charger to try charge it the battery was almost dead after a couple trys...
Try doing a master reset by holding down the Home button (the button at the bottom with the square), and the power button at the top of the phone down at the same time until the power off command comes on, but keep holding until you see the apple logo come on then let go. This is a master reset. Then try charging it. let me know how that goes.
Feb 17, 2010 | Apple iPhone 3G
Cell Phones Logo
32 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
