Question about Toro Garden
What does the woodruff key look like on toro 195cc lawn mower
Is it a connection or a open and close switch?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 98 Answers
Not sure what you are asking. Electrical switch? or this, here is a woodruff key that locks a shaft to a gear or wheel etc.What does the woodruff key look like on toro 195cc - 9k=
Posted on Apr 04, 2014
  • 1619 Answers
SOURCE: i need to fix athe pull string on my toro push
remove bolts from cover and remove the cover. Should be able to access the assembly for the pull rope. Go to a local mower repair shop buy some new line. The old line should just be knotted up on the spring loaded wheel in there. You put a new piece on put in a new knot, put some turns on the assembly to basically wing the spring so it snaps back when pulled, put line through whole and attach to pull handle.
Posted on Jul 11, 2009
rwvanlue
  • 486 Answers
SOURCE: Stuck pull cord on Toro 6.5 self-propelled mower
1) Common problem when a mower sits for several weeks at a time between mowing;
check for extra grass debris to be glogged between the blade and the mower shell.
2) If the mower has a 'bail' or 'zone' control handle;
this releases a brake mechanism on the flywheel to allow it to rotate, and after it is running, releasing the lever will 'kill' the engine.
NOTE* when transporting a push mower in the trunk of a car, try to keep the mower as level as possible.
*extra note when mower has been transported in the back of a car;
sometimes the mower is placed in a trunk at such a severe angle that the oil from the crankcase is forced around the rings and sits on top of the piston so that when you try to pull the rope you have a 'hydra' lock. (that is when a liquid is between the piston and the spark plug) You cannot compress a liquid, so the rope appears stuck.
If this happens, remove the spark plug (make sure the loose plug wire is fastened away from any combustable that comes out of the spark plug hole *** AND THERE WILL BE A HUGE STREAM OF OIL AND GASOLINE, SO BE PREPARED TO CLEAN UP A MESS ***
pull as normal until fluid is dispelled from internal engine
clean or replace the spark plug
a few more pulls (no choke required) and you are up and going
Posted on Nov 08, 2009
SOURCE: Our Toro Personal pacer Model 20031 lawn mower will not start;
i turn the key and it grinds
Posted on Dec 06, 2009
barterjoe
  • 344 Answers
SOURCE: my toro lawn mower is hard to start in cold
This is covered by the Warranty. Take it to a local dealer like www.arcolawn.com and have the thermostat replaced.
The first generation thermostats are known for sticking.
Good luck
Joe
Posted on Feb 20, 2011
  • 6468 Answers
SOURCE: how to replace drive belt on self propelled toro commercial push mower
the should be a plastic cover under the engine
Posted on Mar 29, 2012
I have toro 195cc tec carb. Mower runs one.minute then cuts out. Have good spark. Replaced carb. Removing fuel cap doesnt help. Carb jet is clean. Swapped plugs with another toro. What am i missing?
Tankfilter (sludge problem) Gasoline faucetfilter the fuel hose connections , fill up your oil level if in doubt of it after know the right level try to unconnec for only a short time the Oil monitoring cable
May 13, 2017 | Toro Garden
It there a timing mark for a toro lawn mower gts195cc?
Usually there is not. The timing is through the flywheel that connects to the crankshaft and it is permanently set with a woodruff key. When evereything is tight, the timing is good. IF you hit something and cause the blades to stop, the flywheel can move and twist on the shaft and bend the woodruff key. The engine then wont start or will backfire etc. To fix this you need to pull the flywheel off the crankshaft and replace the woodruff key and reinstall it.
Mar 31, 2014 | Toro Garden
Sparkplug gap chart
The most common reason for that is the flywheel that has the magnet inclosed in it, has slipped out of position and affected the timing. Make sure the woodruff key is present and that it is lined up on the shaft and the slot in the flywheel.
Mar 24, 2014 | Toro Garden
Toro gts 195cc
I USE THE PART LIST DIAGRAM TO PUT THINGS BACK TOGETHER.
Jun 27, 2013 | Garden
How to plug a jumper wire to disengage safety switch
Most safety switches or normally closed. Just separate2 wires to open circuit. Tape off or attach wire nut to each wire.
Aug 28, 2012 | Toro TimeCutter Zero Turn Lawn Mower...
I have 1995 toro ridding mower.i got it not working an the battery was not charging so i got a new battery an ones i hooked it up every thing work bu did not start an it just makes a clicking noise when i...
Test the battery with a volt/ohmn meter to ensure it reads at least 12-14 volts. Check all the safety switches located underneath the seat & the mower deck engage handle is disengaged. Check all battery wire connections are soldi, not corroded. Check wiring on starter solenoid from battery & to key switch.
Oct 24, 2010 | Toro Lawn Mower With Toro Power Tools
BROKEN BRAKE PAD UNDER FLYWHEEL ON TORO LAWN MOWER THE ENGINE IS A TECUMSEH MODEL lev120 SPEC 361541b 195cc
If you had replaced the flywheel key & did not engage the saftey bail it would brake the brake. Make sure the bail is engaged befor installing the flywheel.
Sep 23, 2009 | Toro Lawn Mower With Toro Power Tools
I need to fix athe pull string on my toro push behind mower. it has an 195cc tecumseh motor. the string broke and i can't find anything on toro about how to fix it without buying the whole assembly.
Jul 11, 2009 | Garden
Toro 20073 self propeled, walk behind mower-how to replace belt ?
Wait until the mower cools off
1. Remove the drive belt cover from the top of the mower
2. Tip the mower up, being careful to not go too far or the oil and fuels may spill out
3. Remove the mower blade - as I recall the bolt is 5/8" (could be 9/16") You will have to hold the blade from turning (if you have impact tools, this will be much easier)
4. Remove the blade
5. Pull the pulley out or off and remove the belt - be careful to not lose the crankshaft "woodruff" key - it's the little piece of half/moon shaped metal that keeps the pulley from spinning on the crankshaft.
6. Reverse the steps to reinstall
You MUST make sure the blade is tight when you reinstall it. Also, the blade usually fits over a couple of pins - make sure they are lined up properly and the blade is installed right-side up.
Mar 16, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
