Question about Sunbeam SBM1000 Microwave Oven
Microwave won't heat
Microwave turns on and rotates but will not heat
    Problem Solver:
  • 19 Answers
Replace Magnetron..
Posted on Aug 19, 2014
Microwave wont heat
Leave it unplug for a while and then plug it back in , sometimes this will reset it
Jun 27, 2013 | Microwave Ovens
Frigidaire microwave plate won't turn
The motor for the rotator is bad. It has to be replaced.
May 06, 2013 | Frigidaire Microwave Ovens
Turn table won't turn on microwave
There is a motor underneath your microwave that rotates the turntable. It may have failed
Mar 01, 2013 | Jenn-Air JMV8208AAS Microwave Oven
Siemens HF26066GB plate is moving when door closed and not moving when open
Have a shop look at this---there usually is a recessed safety switch inside the jam that will prevent the unit from working with door open--sounds like the problem may be with it.
Nov 03, 2012 | Siemens HF26066GB 1000 Watts Microwave...
Won't heat and rotate.
Typically, a no heat condition is the fault of burned door safety interlock switches. Check the switches with a contuinity meter. The no turning condition may be a belt.
You will have to remove the shell in both cases to make this repair.
Mar 14, 2012 | Microwave Ovens
Microwave lights, clock, and everything works except when you press start, it just counts down like its cooking, but the microwave is actually not on. No hum as usual or plate rotating. It just counts...
Hi, one of the most common reasons why the turntable won't rotate is that the microwave isn't clean. The turntable guide and carousel can get sticky, preventing the turntable from properly moving. If you have built-on food particles or liquids, fill a bowl with 2 or 3 cups of water and 1 tsp. of liquid detergent and lemon. Run the microwave for about 3 minutes. Clean the microwave with a cloth, including the base of the turntable, guide, carousel grooves and microwave base. Your microwave turntable won't rotate if the grooves on the base of the turntable do not sit right on the carousel. Also, check the position of the turntable guide. Place the guide directly under the turntable. Remove the turntable, and then reposition it into the carousel grooves.
Motor The carousel motor is located beneath the base plate of the microwave. If the carousel isn't turning at all, check the motor. Disconnect the microwave from the power source, and remove the turntable, guide and base plate. Try turning the motor to see if it's just stuck. If it doesn't turn freely after a few seconds, examine the motor to see if it's burned out or corroded. Use an ohmmeter to see if the motor has continuity. If not, you must replace the motor.
Bushings The drive bushings are plastic components that sit underneath the cooking plate. Remove the plate, and examine the bushings. Use a magnifying glass if necessary to see if any debris is caught in the plastic. Clean the bushings, and reinsert the plate. Turn the microwave on to see if it rotates. If the bushings are extremely worn or if some of the plastic is broken off, you need to replace it, which is a complicated repair for consumers. Contact a service technician for assistance.
May 07, 2011 | Amana Radarange Microwave Oven
Microwave does not heat
your magnatron tube (what heats the food) is out, if it is not still in warranty it will run 200-300 to fix, might be better to replace sorry
Jun 08, 2010 | GE Adora DVM1850 Microwave Oven
Tray is not rotating and its not heating up
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101;'][][\
Apr 25, 2010 | Amana ACO1860 Microwave Oven
Plate won/t rotate no reheating
PLease open the housing of turn table motor at bottom of the oven and check for the AC input voltages on motor terminals as specified on sticker on motor. for no heating please check fuse between high voltage transformer and high voltage capacitor. Also check high voltage Diode and Magnetron.Please please don't try to measure voltage on terminals of magnetron.
Jul 29, 2007 | Whirlpool MH6141XK Microwave Oven
Sunbeam SBM1000 Microwave Oven Logo
Top Sunbeam Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sunbeam Microwave Oven Expert? Answer questions, earn points and help others
