Question about HP Color LaserJet CM6040f MFP Q3939A Printer
Rooler kit error
Hp 6040 hasa rooler kit error
  • HP Master
  • 783 Answers
1 Turn the printer off.
2 While pressing [- Item] and [- Value] turn the printer on.
RESET MAINTENANCE COUNT appears, followed by INITIALIZING.
After a few seconds READY appears.Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For HP Support
Posted on Apr 01, 2014
2 Suggested Answers
MedManHelp
  • 55 Answers
SOURCE: I HAVE AN HP LASER-JET
60.X ERROR To continue turn off then on The tray specified by X is not lifting correctly. Follow the instructions on the product control panel.
Posted on Aug 02, 2011
Scanner failure 30,0146 hp 6040
"I know I'm a biot late to the party here but I just worked on an M3027 with that same error. It turned out to be the scanner head lock was in the locked state. Tried unlocking with the machine still on which didn't clear the error but after a power-cycle with the head unlocked the error was cleared. Nice simple and free solution!" Read more here: error 30 01 34 scanner failure
Mar 27, 2016 | HP Office Equipment & Supplies
How do l clear error E57.01 on an HP 6040 MFP LaserJet printer
Measure the voltage between
connectors J103-4 and J103-6 on the
DC controller PCA right after the product
is turned on. If the voltage changes from
0V to approximately 24V, replace the
VOC fan. If replacing the fan did not work, then check the connectors on the DC controller, if they are seated then it is possible that the DC controller is bad.
Aug 07, 2015 | HP Office Equipment & Supplies
I have a HP LaserJet 6040 with this error message 59.30
59.30 means that the fuser motor experienced a start up error.
If power cycling the printer won't clear the error you probably need a tech to troubleshoot and/or replace the motor.
Sep 16, 2011 | HP Color LaserJet CM6040f MFP Q3939A...
I HAVE AN HP LASER-JET MFP 6040 WITH AN ERROR CODE 60.03 LIFTING TRAY ERROR
Aug 02, 2011 | HP LaserJet CP6015xh Printer
49.4c06 error on my hp 6040 printer 3 times. how do i fix?
49.4C06 is a firmware error indicating the printer cannot handle the job . This is mainly caused by someone printing a PDF file.
You must first clear the error by disconnecting the network cable and power off the machine allowing it to sit for a couple of minutes before powering on. Use that time to find the person who sent the job to the print queue and have them delete it.
Once the error is clear you need to upgrade the firmware on the printer. Upgrade cane be found here: http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=3687301&prodTypeId=18972&prodSeriesId=3644750&swLang=8&taskId=135&swEnvOID=54
Oct 29, 2010 | HP Color LaserJet CM6040f MFP Q3939A...
I have an hp 4200n that picks up an extra blank page when i print a menu map. the paper (blank page only gets up to the delivery assy past the fuser, no jam error). this happens when i print it from tray...
Hello, you must clean separation roller whit wet cloth or alcohol. Remove Tray 2, look for blue (usualy) cylinder feed rubber on it and clean Good luck. P.S You can clear paper feed roolers too (look at printer bottom after removing Tray 2) using same way!
Oct 15, 2009 | HP LaserJet 4200n Printer
Clc 2400 off register
change your regrestration rooler ie the big black rooler +the belt that is on the rooler and your transfer sheet
Sep 17, 2008 | Canon CLC 2400 Color Copier
Drum front rooler kit
Rollers go in the back
Aug 06, 2008 | Crosley Dryers
Paper will stuk in meddle printing
Probably the page count of your printer exceeds 100k pages. Maybe u will have to change the maintenance kit of your printer. This printer have no HP original maintenace kit, but u can buy the parts one by one.
Fusing assembly
separation pad
feed rooler
Good luck
Dec 15, 2007 | HP LaserJet 1100 Printer
HP Color LaserJet CM6040f MFP Q3939A Printer Logo
87 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
