Hp compaq nx6320 projector
My Compaq nx6120 upgraded from winXP pro to win7 and now I am not able to work with any projector. My laptop max resolution is 1024 x 768. How to solve this problem and increase the resolution also ?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 145 Answers
U cant thats the maximum resolution u get out of ur laptop
Posted on Apr 01, 2014
3 Suggested Answers
  • 25 Answers
SOURCE: Want to upgrade hp compaq nx6120
To upgrade a HP (Compaq) NX6120 you will require -
  • T8-9 mm screw driver
  • P1 Philips-head screw driver
Q.1. Increase the RAM size. (Can you please guide, what is the maximum size it can support w/o any problems & which make & model to buy)
A.1 To Upgrade the memory you require to purchase a
333 MHz, 200-pin, PC2700, DDR SDRAM SO-DIMM with the Maximum size of 2GB.
The memory can be purchased from any good local computer store as of 27/03/09 the price on Buy.com for 1GB stick was $47.99
Installation
Important Notes
When handling a RAM, all way hold the edge of the RAM, also use care to prevent touching the RAM on the motherboard. Touching the RAM could damage or destroy the RAM.
  1. Turn off the laptop.
  2. Disconnect any USB/Power cables attached.
  3. Slide the battery lock to the unlock position.
  4. Slide and Hold the battery release to the unlock position.
  5. Slide the battery out from the laptop.
  6. Loosen the captive P1 Philips-head screw that secures the memory cover to the bottom of the notebook.
  7. Using you fingers gently lift the memory cover from the edge of the laptop, at the finger groves on the laptop case and remove it.
  8. Push both arms outward simultaneously to release the expansion memory board to the spring tension position.
  9. Grasp the edge of the RAM and pull gently to remove it.
  10. Place the RAM in a static dissipative bag
  11. Take the Ram from the static dissipative bag
  12. Grasp the edge of the RAM and align it to the empty board receptacle.
  13. Gently press the RAM down to latch the arms.
  14. Slide the battery cover back into the clips on the laptop.
  15. Tighten the captive P1 Philips-head screw.
Q.2. Increase the Hard disc capacity. (Can you please guide, what is the maximum capacity of hard disc it can support w/o any problems & which make & model to buy)
A.2 The maximum hard drive all depend on the type of windows you will be installing and the chipset on the Laptop. The standard chipset for the HP NX6120 is Intel 915GM and does not any limit set
To found out what type of chipset is installed open Device Manager using the steps listed for your particular operating system.
  • Windows Vista: click Start » click Control Panel » click System and Maintenance » click Device Manager
  • Windows XP: click Start » click Control Panel »System icon » click the Hardware tab »Device Manager
  • Windows 2000: click the Start button » click Settings »Control Panel » double-click the System icon » click the Hardware tab » click Device Manager
  • Windows 95, Windows 98, Windows 98 SE, and Windows Me: click the Start button » click Settings » click Control Panel » double-click the System icon » click the Device Manager tab
  • Click the + sign to expand the System devices entry.
Look for the chipset name in a string similar to the following: "Intel® 955X Memory Controller Hub - 2774". In this example, the chipset is an Intel® 955X Express Chipset.
If the chipset is in the 800 range please visit Intel website to install Intel® Application Accelerator.
http://www.intel.com/support/chipsets/iaa/sb/cs-009293.htm
I have included a list below of all of the main operating systems with their HDD support
  • Windows Vista - 2TB,
  • Windows XP - 2TB,
  • Windows 2000 - 137,
  • Windows Me - 137,
  • Windows 98 SE - 137,
  • Windows 98 - 80,
If you are install any other Operating Systems please see to OS guide.
To Upgrade the memory you require to purchase a 2.5" (inches) IDE HDD also know as a 2.5" (inches) PATA HDD with the maximum size above.
HDD can be purchased from any good local computer store as of 27/03/09 the price on Amazon for 250 GB was $79.61
Installation
  6. Loosen the captive P1 Philips-head screw that secures the HDD cover to the bottom of the notebook.
  7. Loosen the captive P1 Philips-head screw that secures the HDD.
  8. Grasp the Mylar tab and pull the HDD toward the outside edge of the enclosure.
  9. Lift the HDD out of the bay to remove it.
  10. Place the HDD in a static dissipative bag
  11. Take the HDD from the static dissipative bag
  12. Place the HDD in to the HDD bay with the connectors match up to connectors on the in the enclosure
  13. Gently push the HDD toward the inside of the base enclosure until the connector is seated.
  14. Tighten the captive spring-loaded P1 Philips-head screw that secures the hard disk drive
  15. Slide the battery cover back into the clips on the laptop.
  16. Tighten the two captive P1 Philips-head screw.
Q3. Want to Install DVD writer. (Can you please suggest whether it supports it or not & which make & model to buy)
A3. Yes the HP NX6120 does support DVD write but unlike the another question the DVD drive must be the pre fixed to suit the HP NX6120.
A DVD can only be purchased from HP or at selected online store as of 27/03/09 the price on getpartsonline.com for a
Dual Format Laptop DVD±RW Drive was $99.99
Installation
  8. Remove the T8-9 mm screw that secures the optical drive to the base enclosure.
  9. Insert a paper clip or thin metal rod into the manual release hole on the front bezel of the optical drive and press firmly.
  10. Grasp the side rails of the drive tray to pull the optical drive out and remove.
  11. Push the drive tray back into the optical drive
  12. Insert the optical drive into the base enclosure until the connector is seated.
  13. Replace the T8-9 mm screw that secures the optical drive to the base enclosure.
Posted on Mar 28, 2009
muntejaya
  • 10421 Answers
SOURCE: in my laptop compaq nx6120, my voice is not
Hi, Please get the driver here :
www.hp.com
www.techno-files.com/categories/laptop/531.html
www.opendrivers.com/.../hp-free-driver-download.html
Regards, Jay__bcgvd
Posted on Mar 02, 2011
Compaq nx6320 wifi not working
my nx6320 compaq sound driver is not working plss help me
Sep 22, 2010 | HP 413670-001 - HP Compaq nc6320, nx6310,...
I am trying install winodws7 on HP Compaq 610 having ATI Radeon Catalyst(Current OS winXP Pro SP2). But in the installation window it is showing the CD/DVD driver missing message. So, googled it and found...
Hie there i have installed and reinstall Win 7 Ultimate on Multiple Compaq 610's without any problem.
i once encountered a prob like this one but was lazy so i removed my Hdd and formatted it elsewhere and Walaa my prob was gone. i didn't have to upgrade or downgrade my bios and am still using the same laptop 2day. Just make sure you DVD rom aint damaged.
good luck
Aug 06, 2010 | HP Compaq 610 T5870 156 WH248UTABA...
Laptop hp nx6320 keyboard f2 key is only working. f1 and f10 key is not responding so that I can't save memory upgradation option nor open the setup.
Have you tried "Delete" to enter the "Bios Settings"? If not this must be the shortcut for your laptop, since most compaqs' Bios settings are accessed with "del" key. Actually for Hp compaq laptops, F1, F2, F10 and Delete keys are the shortcuts. (varies with series/models).
If this doesn't help, try Fn+F1, Fn+F2, Fn+F10 etc..
Good luck.
Thanks for using FixYa.
Jul 01, 2010 | HP 413670-001 - HP Compaq nc6320, nx6310,...
Need advice for nx6120
Yes. The HP Compaq nx6120 ships with 256-MB DDR SDRAM, upgradeable to 2048-MB maximum.
You can verify yourself at the following link:
http://h18004.www1.hp.com/products/quickspecs/12136_div/12136_div.PDF
May 15, 2009 | HP 378248-001 keyboard for Compaq nc6110,...
Drivea
Hello
If you want to download drivers and software for HP Compaq NX6120,
then you can download then from the support page
Best regards,
Zizzler
Apr 23, 2009 | Soltek SL-915G Pro-FGR Motherboard
COMPAQ NX6120 LAPTOP DRIVERS FREE DOWNLOAD REQUIRED
Dear Sir,
I definiteky need of this software, i m not getting compaq nx6120 hp laptop for motherboard driver network driver,pci device,usb driver cd can u help me in this
Oct 04, 2008 | HP Compaq nx6115 Notebook
You will find the XP drivers you want here: http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=457952&prodTypeId=321957&prodSeriesId=457951&swLang=8&taskId=135&swEnvOID=228
Oct 04, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
