I just went through the same exact thing you need to go into your Gmail settings your security settings and it will show you your old phone number edit it and put in your new phone number and then it will send your own code to your new number I think it's security settings or something you have to go into
Go to the manufacturer website of the television. They should have the default code or give you instructions on how to reset it. If not, try the first 4 letters of the model number or serial number. Or try 9999 or 0000
well..........can you set another code that will allow you to retrieve voicemail? I think you can replace with another code by the menu....see if this can work? Regards, Meder's tv service and please rate..thak you for using FIxYa
Hi,there are many software available to retrieve the password and if it does not work then try to reset your mobile by master reset code..try wickedunlock to get master reset code for your mobile to reset your mobile..
For security reasons, many games have a code or a serial number to protect their products. But every copy of the software have a special code, that don't match or is very unlikely to match with other copies of the software.
We could give you a serial number but it's almost sure it won't work.
Some companies allow clients to retrieve their codes if they registered, so you could try this way.
Bottom line: if you lost your serial number, you could retrieve it if you registered your product and if the software company allows you. Otherwise, it's very unlikely to get a serial number that will match your copy of the software. thanks , AJ
Remote code A remote code must be entered when operating the answering system remotely. This code prevents unauthorized parties from listening to your messages remotely. Store any 2-digit number (00–99). The default setting is “11”.
1 Press {MENU}. 2 Scroll to “Initial setting” by pressing {V} or {^}, then press {>}. 3 Scroll to “Set answering” by pressing {V} or {^}, then press {>}. 4 Scroll to “Remote code” by pressing {V} or {^}, then press {>}. 5 Select the desired remote code by entering a 2-digit number (00–99). 6 Press {Save}, then press {OFF}.
Note: To confirm the remote code, repeat steps 1 to 4. Press {OFF} when finished.
UnlockMe! is a software that will allow you to recover the Unlock Code actually configured in your mobile phone. You have to install and run the software on the phone and after some minutes it will communicate you the Unlock Code actually configured in the Phone This application lets you retrieve your security/lock code. *Firsty you Go to Options > Unlock!. *Wait for some minutes.
You will see the security/lock code currently set on your phone.
Normal 0 false false false MicrosoftInternetExplorer4
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}table.MsoTableGrid {mso-style-name:"Table Grid"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; border:solid windowtext 1.0pt; mso-border-alt:solid windowtext .5pt; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-border-insideh:.5pt solid windowtext; mso-border-insidev:.5pt solid windowtext; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}Instructions for Retrieving Messages While Away from Home Sony TAM-100 Answering Machine Step I:Set the Remote ID (security code) on themachine itself:
1Press (SET/REC). 2Press (ANSWER ON/OFF).
A voice guide will say: “Pleaseset the security code.To select, pressthe SKIP or REPEAT button.To enter,press the SET button”.
3Set a two-digit number between 00 and 99 bypressing (SKIP/QUICK) or (REPEAT/SLOW).Press (SKIP/QUICK) to increase a number, or (REPEAT/SLOW) to decrease.
Each time you press (SKIP/QUICK)or (REPEAT/SLOW), the answering machine announces a number.
4Press (SET/REC).The remote ID code (security code) is set,and you hear a long confirmation beep.
To change the remote ID code(security code), Enter a new remote ID code (security code).The new code will replace the old one.
Note:If a powerinterruption occurs, the remote ID code will not be erased.
Please See Next Post to Continue (my response exceedsallowable text restriction ;-) ).
no. It is an OBD2 configured control system.First year production with a lot of fuel trim problems. codes can be retrieved with generic obd2 scan tools or ford's star2 tester. These cars are noted for setting oxygen senser codes if started with battery in poor contition.
