Playing xbmc movies on rasbery pi
I have a sony TV with 3 hdmi ouputs. I have a rasbery pi hooked up to play on my sony TV. While playing a movie the whole system freezes. First I notice the sounds stops then the movie will look like it pauses but really it's the system freezes and I have turn the unit on and off again but then in min it freezes again. When I change to another HDMI port on my TV the unit works fine. Is is possible that particular HDMI port is broken?
  • J ho
    J ho Apr 02, 2014
    So is it my HDMI on my TV that's bad or the Pi? like I mentioned when I change to another HDMI port, the pi unit works fine.
  • 3,324 Answers
That's a buffering issue. pi board may have a bad trace to RAM
Posted on Apr 01, 2014
SOURCE:
  • 149 Answers
SOURCE: playstation 3
Have both the AV cables and hdmi cables hooked up from the tv to the ps3. On the TV Menu goto the av station which is different from the HDMi station...From the ps3 menu screen gotot settings then to video and audio and select hdmi then back to the tv menu and select the hdmi station and the ps3 main menu should be seen and you are all set
Posted on Nov 13, 2008
  • 458 Answers
SOURCE: LG 37LG30 HDMI no sound problem
This is more probably a software fault within the TV. They need instructions for HDMI inputs & a no sound is a related fault. I would get in touch with your dealer to arrange the TV to be updated to cure this problem. Hope this helps.
Posted on Apr 18, 2009
  • 961 Answers
SOURCE: Connected PC to LG with
How do you get HDMI out to tv, through a graphics card? Is Is it HDMI direct out of the card or DVI adaptor? I believe you will get a ping even if the volume is turned down and when playing a movie you would have volume control throuh the DVD player, the computer and the tv. Make sure your volume is turned up on dvd player and right click on your speaker icon in taskbar, at lower right of screen and make sure that volume is up. When you do the ping are you checking a "HD" audio driver. Look in 'device manager" in "sound audio and game controllers" and right click on "HD" devices and make sure they are enabled. Let me know what happens. When you look at devices in device manager you also may see a warning. If so click on the symbol, ? ,!, or triangle and follow proceedure.
Dave
Posted on Apr 06, 2011
SuperTech-11
  • 1591 Answers
SOURCE: My Samsung '40' TV has
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both. In your case, most likely the Power section. Power issues can often just affect one input type. I have a 32" TV that the tuner doesn't work in, but the VGA and HDMI work fine. Since I am using it as a monitor with the VGA input, I haven't bothered repairing it.
In yuor case, Any caps in these sections that look even slightly bulged at the top, or bulged/leaking at the bottom (look for discoloration of the circuit board around the base of the capacitor) need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably stay on, but every time you turn it off, the unit will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for some time and then try again.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and/or inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are SURE it's only doing supply output ripple filtering,
and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
Backlight related video here:
http://www.youtube.com/watch?v=6XoF6QZ1dmw&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors, amplifiers, computer power supplies and motherboards, and other electronic equipment.
The parts are cheap, and skill required is minimal.
A great parts source is Digi-Key, and you can order the parts online at www.digikey.com
They typically cost under a dollar a piece plus a flat shipping rate.
The parts usually arrive one business day later.
If you watch the third video, you will see that even someone with no soldering experience can perform these repairs as demonstrated by the woman in the video.
Posted on Jul 28, 2011
vinceisaac
  • 2432 Answers
SOURCE: HDMI to Sony VAIO Laptop displays vertical colored lines on the TV. How can I resolve so that I can watch Netflix movies on the tv?
tried to replace the cable then making sure no loose connection.
Posted on Aug 31, 2012
How can i connect my tablet
Just going to go through steps.
1. mIni hdmi to to tablet
2. hdmi on other end of cable to a hdmi input on tv.
3. go to input on tv and change input where you plugged in hdmi.
4. start your tablet. what ever is on your tablet will now show up on tv. (home screen, movies, e-mail, etc.)
Just a reminder, you have to switch input on tv each time.
GOOD LUCK
Apr 19, 2014 | Acer Iconia A1-810-L888 7.9 inch MediaTek...
I have a 32 inch RCA LCD TV. when I play a movie, every 2=3 minutes to goes back to the blue screen, and blinks a few times then goes back to the movie. Its with every movie and I dont think it is my dvd...
Probably the Controller unit for the TV. Try hooking it up through a different connection type e.g. HDMI, component. See if that fixes the issue for the time being. If it dies then those ports you used previously are malfunctioning.
Mar 19, 2011 | Televison & Video
Blue rays not playing and screen says no signal
This is blue ray lens failure. this optical Assembly has two separate reading lenses. there is one designated for Cd audio and CD_ROM reading and, the other is blue ray compatible. the blue ray lens in inoperable at this point. you will need to replace this lens assembly.
May 27, 2009 | Sony Playstation 3 (PS3) Console
Very low sound when playing a movie.
You have to let the PS3 automaticly check sound after setting up HDMI. Redo the Video setup and let it do everything automaticly. Might check audio settings on the tv its self.
Mar 14, 2009 | Sony Playstation 3 (PS3) Console
Screen flickers when I play a BD movie on my PS3
Does it do this with all Blu-Ray movies?
Have you tried a different HDMI cable?
Jun 18, 2017 | Sony Playstation 3 (PS3) Console
My new unit will not play Assasins Creed!
hook playstation 3 up to the internet and download newest updates
Jan 19, 2008 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
Ekse
