Question about Fujitsu FI-6670A MONO CLR DUPL 70PPM/ PERP140IPM ULTRA SCSI A3 600DPI TWAIN
Scanner pauses while scanning and hesitates - Fujitsu FI-6670A MONO CLR DUPL 70PPM/ PERP140IPM ULTRA SCSI A3 600DPI TWAIN
Fujitsu Fi-6130Z is pausing after each page scans. How can we stop this so it is a continuous scan!
The command to scan comes from the host computer when it has recieved the previos scan and is done processing the data such as descew and borders. Faster host computer and or faster network if you are saving to a server. If the first few scans are fast then slows down then this is it. More ram in host will sometimes help.
Feb 12, 2014 | Fujitsu Fi6130z Sheetfed Scanner
Lines on scanned page
Could be the scanner is hesitating as the carriage moves - bad gears perhaps. Hhave you thoroughly cleaned the glass and wiped it dry? Is the scanner level andand fully unlocked? I would try these quick fixes first. If they don't work, scanners are cheap nowadays.
Oct 18, 2012 | Umax Astra 3400 Flatbed Scanner
When scanning with the native scanning software, the scanner runs very fast but file size is huge. When I use Adobe 9 to scan, my files size is much smaller but the scanner pauses after each page. I need...
I would expect the problem with the Capture perfect fike size is down to the compression chosen for the output file. Ideally black and white inahes should be Group 4 TIFFs and Colour or Greyscale should be JPEG. Alternatively you may want to check the scanner is set to 'scan ahead' in the twain settings in Acrobat. If it is set to anything else the scanner will slow down to allow the PC to process every image. With 'Scan Ahead' turned on the scanners memeory buffer the PC speed a little giving you faster scanning.
Jan 25, 2011 | Canon DR-5010C Path-Through Scanner
Canon DR-7580 will scan first 12-14 pages rapidly then pauses, scans a page, pauses, scans a page... I have the exact same scanner hooked to another pc that is exactly the same.. and it flies through the...
Your hard disk must be almost full. Direct the scanning software to send data to a hard Disk location where you have enough space.
S. Mohan, India
Feb 01, 2010 | Canon DR-7580
The scanner pauses half way throught the document
May be the location where it is writing the data is not 'free'. Do a 'deframent' of the drive where you intend saving the data. Ensure there is enough space on the Hard Disk
S. Mohan, Chennai, India
Jan 23, 2009 | Canon DR-2580C Path-Through Scanner
Epson CX4200 scanner
1) In the program you are working from, begin the scanning process. If working in FULL AUTO MODE as the scan begins click PAUSE or CANCEL, then change "Full Auto Mode" to "Home Mode".
2) You will now see all Epson Scan settings displayed. If the scanner has not previewed automatically, click the large preview button to get a visual of what is on the scanner.
3) Ensure the settings on the Epson Scan are correct for what you wish to scan.
Jul 10, 2008 | Epson Stylus CX4200 All-In-One InkJet...
STOP SCANNIMG
press the pause button ( PSE )
Mar 31, 2008 | Radio Shack Pro-97 Handheld Scanner
Why does the scanner hesitate when feeding the paper through the scanner and gives a scanned double image at the top of the page?
Is there a gear grinding noise associated with this? If so, call your local dealer for service. If not:Clean all the rollers you can reach with a cloth dampened with alcohol. Check for any obstructions in the paper path like torn paper, heavy toner buildup on guide plates or the edges of the scanning glass, or any paper guides obviously loose or out of place.
Nov 20, 2007 | Canon DR-3080CII Path-Through Flatbed...
Scanner to Pc File Size and Volume Problems
Hello We have been having this same problem when scanning Black and White as well. We have just played around and have changed one of our settings that has seemed to solved the problem for now. Try Properties (on scan settings) then more then click on - Detect Page Size - Image Width instead of Guide Plates Hope this works for you to
Jan 18, 2007 | Canon DR-9080C Path-Through Scanner
Fujitsu FI-6670A MONO CLR DUPL 70PPM/ PERP140IPM ULTRA SCSI A3 600DPI TWAIN Logo
18 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Tony
Electro Med Services...
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
