This printer is making an occasional load clicking or clacking sound from the right side of the machine. It sounds like gears slipping over each other. The machine does not make a sound from the manual paper feeder. I've switched the trays and no change. Is there an easy fix for this problem? Thanks!
SOURCE: xerox phaser 8560 DN is
There is mostlikey a scrap of paper that you can not see still in the machine. You can gently walk a thicker piece of paper through the paper path and see if it pushes out the obstruction. Be very careful not to scratch the drum when you try this.
Hope this helps
SOURCE: printer picking wrong tray for print
From the start menue to printers and faxes go to your printer right click and select properties label the 4 drawers as to paper type and select continue, or auto continue to off.
-Carl, please let me know if this helps.
SOURCE: Xerox 6110 problem:
I have the Samsumg version of this printer CLX-3160. Sounds like the paper takeup roller is not able to grab the paper. What does the LCD display say when this happens? I don't know what software came with your printer, but Samsung provides a PC Smart Panel software that gives a better diagnostic capability. If you have not installed it, install it and see what it says the trouble is? Hope this helps.
SOURCE: Xerox 6360dn, Tray 2 makes loud grinding noise
In my experience, it was the registration roller causing the grinding noise. See http://my.brainshark.com/Phaser-6300-6350-6360-Grinding-Noise-795590408 for troubleshooting video.
SOURCE: Xerox Phaser 7700 laser printer problem. Display
If your Xerox phaser 7700 7750 or 7760 is having a Paper Jam at A-Fuser error, this video should help. Good luck
I've also reset the fuser, transfer roller and imaging unit. I've also tried different fuser. This problem started around the time a paper jam occurred. I cleared the paper that I could see. It hasn't jammed since, but the sound starts and stops. It can go 20 pages with no sound and then starts again. Please let me know if you have any experiences like this one. Thanks in advance for the help!
