Hp laser jet p2055dn 49err46c081a error how to solve
49err46c081a error
  • 327 Answers
SOURCE: hp laser jet 2840 engine error
its the problem of the spinning wheel which pulls the paper that is called engine and that is either getting blocked by any dust particles or got broken internally and has to be cleaned or replaced to make it proper.
thanks.
Posted on Dec 15, 2008
pdouglasss
  • 125 Answers
SOURCE: error 13.10 paer jam in HP laser jet 5100 DTN
HI ayyasamyr:
This your problem.
13.10 PAPER JAM The event log message for a paper-delay jam in the duplexer is 13.10.
1. Check the duplexer and the rear area of the printer for obstructions or damage.
2. Check PS1701 and PS1703 in the duplexer for correct operation. Replace the
duplexer if a sensor is defective.
Hope this helps
Posted on May 24, 2009
  • 75 Answers
SOURCE: HP Laser Jet 3030 not work
remove scanner glass and use compressed air to blow out the scanner
Posted on Nov 04, 2009
  • 123 Answers
SOURCE: how to solve error is doc. feeder jam in hp laser
Hello Anil_ kuma61!
First thing you need to do will be check the correct postioning of the pick up roller on the automatic document feeder, open up the top cover, you will see a grey roller on the middle, this roller shouldnt be touching the cork a the bottom.
After checking on this, we need to reset the sensors on the printer, to do this follow this steps:
1) Turn the printer off
2) Take out all supplies, including toner and paper
3) With the printer off, press the down arrow and the cancel at the same time (keep the depressed)
4) Turn the printer on while holding those keys and wait until you a message on the display "permanent storage init"
5) release the keys and wait to the printer to come back to ready
Posted on Jul 17, 2010
  • 6 Answers
SOURCE: HP Color laser jet 4700n 49.3048 service error
The problem is usually caused by printing a PDF file with fonts/page size/ page formating errors which will cause the printer to display the 49.3048 error. The only way to use the printer is to POR or recycle the power and delete the print job from the server or spooling device and cancel it on the printer before the offending command is issued to the printer again. You can try updating the firmware to the latest version 46.140.5 from the HP website. MIke L.
Posted on Jul 20, 2010
I have an printer Laser jet HP P2055d the problem is 59.f0 error i need every body help thank you
This is a hardware problem, time for a new printer, below are the causes for this error:
  1. Transfer belt is locked up and cannot rotate.
  2. Sensor SR17 (primary transfer-roller-disengagement) is bad.
  3. Damaged or broken fuser drive gear. Typically, a grinding or clicking noise will be heard during boot up.
Mar 15, 2016 | HP LaserJet P2050 P2055DN Laser Printer -...
Error code b0605
Hi Ekera
Code bo605 Firmware error B0605 on HP LaserJet P2055dn (Printer Troubleshooting)Firmware error B0605 on HP LaserJet P2055dn A common error message on the HP LaserJet P2055dn series is the B0605 Firmware Error. This error basically means the printer's firmware (controlling software) ...Download firmware from HP site & reload basic or updated firmware.
Cheers
Trevor
Jul 13, 2014 | HP Laserjet P2055dn Printer
Hplaserjet p2055dn 49err46c081a error how to solve
The error applies to the embedded jetdirect firmware. I do not think they have a separate firmware update for the jetdirect but it may be included in the firmware upgrade for your printer.
Apr 01, 2014 | HP P2055DN LaserJet Monochrome Printer
IP FOR CONNECTION HP LASER JET P2055DN TO DELL COMPUTER
Hi have digilex DA3016 printer, how to download driver
Feb 10, 2014 | OKI C5400 Laser Printer
51.20 error turn on and off
51.20: Laser error
Could be wrong driver used or the "laser scanner" may have to be replaced.
Dec 19, 2013 | HP LaserJet P2050 P2055DN Laser Printer -...
HP LASER JET P2055dn 10.000 SUPPLY MEMORY ERROR
I have an HP LaserJet P2055dn and I am getting a 10.000 supply memory error. I've checked HP's website and I am not finding anything related to this problem for my printer. What do I need to do?
Thanks,
Mike
Jul 17, 2012 | HP P2055DN LaserJet Monochrome Printer
Hp laserjet p2055dn error 84 1d31
i have hp laserjet 2055 error 84 1d31 .,
how to solve this error,?
What is the posible cause when this problem or error
comes,.,
May 30, 2012 | HP Office Equipment & Supplies
Hello, I have problem with hp Laser Jet P2055dn, It appear 49 Err 3D910C8. Cannot print. Kindly assist. TQ
Go to hp.com.
Download and install the latest firmware.
The instructions are given there.
Sep 21, 2010 | HP Office Equipment & Supplies
Model - HP Laserjet P2055dn. Issue - 49 Err 64003D5, Turn off and then on . Tried many times, keeps showing the same error after turning on.
I had the same problem. The source of this problem, the USB printer port is broken, then I use network configuretion. The poblem is solve.
Dec 20, 2009 | HP P2055DN LaserJet Monochrome Printer
128 people viewed this question
jasbo
jasbo
