Question about Poulan Garden
How to replace the gas line? - Poulan Garden
  • 1,041 Answers
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
Jim
Posted on Jun 15, 2009
  • Jim Parker
    Jim Parker Jun 18, 2009
    Did this solution solve the problem?
    Jim
Cranking but not starting until second try.gas smell.Gas line replaced.Had spark plugs, fuel filter changed.Still having starting issues and today noticed leakage near gas tank.
Gas line was only repaired, not replaced. I don't repair gas lines because of this problem. The entire line is replaced, both of them, supply and return. From the tank to the injector rail. This is the reason for the long start. Loose of fuel pressure.
Aug 07, 2016 | 2002 Subaru Outback
Gas leak at grommet on gas tank where gas lines enter and leave tank
Yes you should be able to replace the rubber tank seal that the fuel line goes through. Be sure to replace the fuel line(s) when you do.
Apr 01, 2014 | Toro 2-Cycle 25.4 cc Straight Shaft Gas...
I have a toro super cycler gts 5 model 20475 6.0 engine i put new gas in it a new spark plug but if i loosen the gas bowl no gas come out and it wont start what could be wrong
Ensure fresh gas is in tank. Follow gas line from tank to carb. Have locking pliers ready to pinch off gas line or close gas line valve. Remove gas line from carb. observe gas flow to carb. Remove carb bowl from bottom of carb. Attach gas line to carb. Does gas flow to carb. Observe float, float down gas flows, float up no gas flow. If float is bad replace float assembly or carb. Remove float mounting pin and needle metering valve. Use a bread wrapper pealed back an inch so thin wire can clean out port of meter needle. Use wire to clean out center port. Observe bowl screw look for hole thru screw, clean out with wire if preset. Re-assemble carb. Clean replace air filter. Fill oil. 30w. Prime motor, pull rope 10 times to start. No start, replace carb.
Aug 02, 2013 | Snapper 20 HP Lawn Tractor 2690578
Gas line disconnected from fuel block
Yes, the gas line connector needs to be replaced. This is probably why it came disconnected.
Aug 30, 2012 | 2000 Volkswagen Golf
Need diagram of gas lines for a 1998 oldsmobil bravado can you tell me how to replace the gas line to the gas tank of a 1998 oldsmobile bravoda?
Gas tank drop to replace rear lines. Pretty major job all around. If you want a good deal on used lines sets look at ebay "stores" for "s10warehouse". He has several good used line sets cheap.
Feb 12, 2010 | 1998 Oldsmobile Bravada
Replacing gas lines my gas line rusted thru under the driver seat is there an easy way to replace gas line
yes
get some steel line of the same size and 2 compression fittings cut out all the bad section till you have good clean lines on both ends and splice a new piece in.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Nov 13, 2009 | 1991 Chevrolet Lumina
Replacing broken gaslines... were do they go?
the primer bulb draws gas through the carb 'C' and back to the tank'T' leaving a small amount of fresh gas in the carb.to replace the lines from filter to carb & bulb to tank,you may have to remove handle & split the housing halves to find where lines enter tank.look in tank W/ a flashlight.to replace lines cut new line on an angle,feed a piece of # 14 copper wire through hole from inside tank.slide new line over wire,the wire will help align fuel line with hole.use needle-nose pliers to push line into tank,& to pull it through once you can see it.cut off end of hose you beat up with pliers.push filter on hose to carb.drop it back in tank."T' line is the return.dosn't matter which line is through top or bottom hole.
Sep 21, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Need to replace gas line inside mcculloch chain
You need to disassemble the case to get to the fuel tank. Pull out the plug fitting and replace the internals with new factory grade parts.
Jun 30, 2009 | Garden
We just replaced the propane gas line. Our stove is gas and it lights, but neither of our gas water heaters will light. Both water heaters are new and have been working for about 4 months before the...
You have to purge the air from the lines.
At the water heater, take a wrench and loosen the gas line until you smell gas coming from the line. Then tighten the gas line. Check it for leaks with a soapy water solution. Let the gas smell clear, then light the pilot on the heater.
May 25, 2009 | Heating & Cooling
Garden Logo
69 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
