Question about HTC Desire Cell Phone
I have a htc desire 601 when i plug headphones in i get low sound but headphones work just fine
Very low sound output when headphones are plugged in but phone seems to work fine
Looking for old Logitech S-100 driver
These are analog speakers and do not need a driver. First, make sure they're plugged into the speaker/headphone jack and not the microphone jack. Second, make sure the computer's sound output is enabled and set the headphone/speaker jack. Third, verify that the sound output is working by plugging in a headphone set or a different pair of speakers. If the computer sound checks out, the speaker cable is bad or the power supply is not working.
Nov 14, 2017 | Dell Computers & Internet
Change main fuse but still not working right
First of all, nothing wrong with the fuse. A fuse is nothing but a short piece of wire with a resistance value. If the unit turns on, fuse is fine. The fact that the headphones you plugged in are working tells you that the music is finding it's way up to that point. You must realize that the speakers themselves have additional circuitry that the headphones don't use. If you could obtain a diagram for the circuitry you might find that a capacitor or a diode or a transistor got "zapped" when the high voltage was applied.
If you have this diagram and you don't know what component is defective, can you post that diagram and I would be glad to help!
Mar 02, 2014 | Bose Audio Players & Recorders
Output distortion from bass amp
The amp is clipping the signal. This could be from the input being too high. The impedance being too low or the finals are damaged.
Dec 11, 2017 | Behringer BXL1800 180W 2-Ch Bass Amp 12In...
Is my sound card damaged? My sound driver is present and i think it's working fine, sound bars are moving also when i drag the slide up and down. But, theres no sound coming from built-in speaker...
Based on the information you have provided, it seems that the issue might be with the Audio Output Jack.
Usually some Computers have an additional Audio Jack on the CPU.
If you have such an option you can try connecting the Speakers and Headphone to that Audio Port and check.
If you do not have an additional Audio port, then it is confirmed that the issue is with Audio Output Port.
It is recommended to replace the Sound Card. You can also check with your favorite Computer Retailer, if only the Audio Output Port can be replaced.
Please let me know if you have further questions or need any assistance.
Suresh....
Jul 29, 2011 | Acer Aspire 5535-5050 Notebook
Sennheiser RS126 headphones/base stopped working
Broken audio cable entering the transmitter or audio jack plug.
Power supply plug loose / faulty power supply.
Nov 10, 2017 | Sennheiser RS 120 Consumer Headphones
Problem with stereo output on Edirol FA-66
Possibly, your adapter of small to big is not a stereo adapter. Seems like a mono adapter.
Jun 15, 2009 | Edirol FA-66 Sound Card
I would like to listen to music/programs/instructions with head phones. I plug in but get no sound through head phones. Can you tell me how to do this? I have a TravelMate 5520-5568 Thank you
From everything I've read and tried over the years it all points to the same thing. Because there is such a big imedence mismatch between standard headphones and laptop output jacks, that they never seem to quite work. I have seen a couple machines that the sound works fine but for the most part the sound is either dull or tiney.
Mar 27, 2009 | Acer TravelMate 5520 Notebook
Sound from headphones is messed
get new head phones same thing happened 2 me
Mar 13, 2008 | RCA H100 MP3 Player
Plugged in headphones for call, now earpiece doesn't work
Same here. I tried many things but cannot ring it back to headset mode. I continuously see the headphone icon shown in the phone, so it seems that the phone thinks that it is still connected to earphones. Sometimes, it works fine, but mostly it does not. If I connect the phone on bluetooth earphones, it works fine.
Any help will be appreciated.
Mar 13, 2008 | Nokia 7370 Cellular Phone
Poor Sound
Audio amplifier IC faulty that why you get very low volume. Else check audio driving circuit to the audio power amplifier. Contact service centre. as there is no rectification process from user part
Nov 19, 2007 | Samsung TXN3245FP 32" TV
HTC Desire Cell Phone Logo
108 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
