Question about Worx "Electric TriVac Blower / Mulcher / Vacuum & Collection System"
Worx Trivac WG500 Electric Blower/Mulcher/Vacuum I own a Worx Trivac Wg500 12amp Allinone Leaf Blower. I need a diagram: Some stuff got stuck and I took it apart. Now unable to fit pieces back toget
Can not find a diagram on Worx site
2 Suggested Answers
  • 4524 Answers
SOURCE: worx trivac WG500 will not turn on
To make the unit light enough to carry but still have adequate power the manufacturers use a series-wound, brush-type motor similar to what is installed in most vacuum cleaners but while a vacuum cleaner is long-lasting and reliable lots of other appliances using that type of motor aren't.
Certainly the power lead and all the connections must be tested as they often suffer from internal breaks and then if all is fine take the unit apart and check the input cable and switch all the way down to the motor.
Lightweight high-powered motors generate a lot of heat and will quickly overheat if there is any reduction or stoppage in the blast of cooling air through them and most appliances intended for domestic use have to be fitted with a safety cut-out, some of which are manually resettable and some reset automatically. Often there is a thermal fuse in close proximity to the motor which will blow if overheating occurs.
I suggest you check the instruction leaflet first.
Posted on Feb 06, 2015
Worx trivac WG500 will not turn on
Feb 06, 2015 | Worx Garden
Worx leaf blower/vac WG500 - tried to use it this season and I plug it in and I get nothing - the extension cord is good, but the Worx doesn't suck or blow. Seems like no power. Any thoughts
Try cleaning the connection prongs on the leaf blower..some times corrosion builds up when not in use..also if you have a multi meter and know how to check continuity you can check the run switch...just use something like tape to hold the switch in the on position..and the with the meter in the ohlms " continuity " position touch the meter wires to the connection prongs..you meter should show continuity if not the switch is not making connection with the power supply..may need cleaned or replaced...if it shows continuity and still Does not work...need to be serviced...
Sep 30, 2014 | Worx WG500 All-In-One Vac Mulcher Blower,...
Clogged worx trivac
I would have to assume your vacuuming wet debris. This is not going to work. I believe they are designed for dried material only
Nov 20, 2013 | Worx Electric Blowervac With Carrying Case...
Manuals
You may download the quick-start guide and the owner's manual from http://www.worx.com/en-US/worx_trivac_wg500.aspx
May 30, 2013 | Worx WG500 All-In-One Vac Mulcher Blower,...
Where can I find a electric cord for the worx trivac wg502
i would buy a extension cord and cut off the other end why not you always need a cord to use it anyway
Aug 01, 2012 | Worx Trivac Wg500 12amp Allinone Leaf...
I need to replace the on/off switch on my WORX grass trimmer do you have a schematic?
usually one side of the switch to the ign. coil and the other to ground or earth. simple mate
Apr 02, 2010 | Worx All-In-One Blower/Vacuum/Mulcher
Black & Decker Blower Vacuum Mulcher 1 Ea Nosie Problem
Sorry. No way to fix this problem. If you have a small yard, electric blowers are the TOPS! I have both, and while the gas blower can go places the electric one can't, I like the electric one FAR better! It is MUCH quieter, and sooooo much lighter, and to top it all off, it blows faster!!! All of this, and better for the environment.
Hope this helps!!
chad
Aug 27, 2008 | Black & Decker Blower Vacuum Mulcher 1 Ea
Worx "Electric TriVac Blower / Mulcher / Vacuum & Collection System" Logo
51 people viewed this question
Top Worx Garden Experts
Tim Whalen
ray gallant
Wayne McNeil
Are you a Worx Garden Expert? Answer questions, earn points and help others
