Question about Hamilton Beach D60012 Coffee Maker
D60012 Shut off mid brew. No lights coming on to either burner. Outlet has power.
Active Smart Control Fridge Freezer E402B.Has just shut down.Going fine than it just shut down.No power.No lights,No compressor,No fans?????The power outlet that provided power to fridge seemed very h
first check the braker in the electrical panel for that line. the braker with the problem will be in the mid posison. reset it by pulling allway back and then all the way on...
Mar 30, 2014 | Refrigerators
How to fix a pressure switch on a goodman Gms807034ana
Since the burners light this eliminates the pressure switch as the problem. Typically when the burners come on and shut off quickly a flame sensor, ground problem or the limit switch tripping are the main reasons. Since the flame sensor has been replaced, check the limit switch
Jan 04, 2013 | Goodman GMS80453ANA Open Flame Mid-Size...
DGB-550BK Filter basket won't stay shut when either brewing ground coffee or grinding beans.. With the ground; the basket pops open mid brew and makes a mess everywhere. When grinding beans, I've noticed...
Not a solution but...
Many folks have reported this, the latching mechanism wears out eventually.
We had the problem but discovered that the door on the basket wasn't getting completely closed. Now I make sure it's closed and haven't had any problem since.
Hope this solves your issue - if not, keep an eye on yard sales, we picked up two at different times for $5 and now have parts to swap out - not much help for a failed latch though.
Glad I never paid full price for it, even though it's a fairly good grinder/brewer.
Jan 19, 2010 | Cuisinart DGB-550BK
Steady Brew Group Light: Old Saeco Magic deluxe
Open the door on the right. The brew unit is the thing with the handle that has the push on it. You need to push on the upper left side of the brew unit until it clicks. There is an outlet spout on the opposite side of where you are pushing. It goes into an intake port that needs to be lubed, so the outlet spout will slide in without pushing back. That should take care of the missing brew unit.
Dec 08, 2009 | Saeco Magic De Luxe Espresso Machine
Que drive not being detected
Sounds like a power issue. Check your power source (cable, plug, outlet) If possible try another power cable, or using a different outlet. It could also be a power adapter issue.
Jun 14, 2009 | QPS Que! USB 2.0 Drive CD-RW Burner
GE Monogram ZGU48N6D- None of the Ignitors "click"
We just had that problem - the igniter is electric - if none of the burners are "clicking" it could be a power problem. unplug the stove and check whether the outlet is working. In our case, the outlet the stove is plugged into has a "GFI outlet with a reset button. So we reset the outlet and that fixed the problem.
Apr 08, 2009 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
My power company shut my power off during the night and the next morning my $100. Cuisinart Grind and Brew 10 cup Coffee Maker- Black, serial #40219C would not work. Is there any hope for me.
what exactly is it doing or not doing ??? any lights come on when you attempt to use it. chances are it just needs to be reset (unplug it for about ten minutes then plug it back in).
Robert
Sep 22, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Brewing stops mid cycle
Sounds like dosage is too high and grind is too fine.
Rule of thumb with any saeco unit.
Do not grind any finer then 2 or your looking for trouble.
Open grinder, clean it out with a vac. Slapped it back on.
The reason it stops is grind is too fine, and the machine doesn't have enough pressure to pass threw the grinds, creates back pressure in the machine and the unit failsafes after a certain amount of time with and pressure.
Back pressure is what blew your boiler.
May 16, 2008 | Saeco Magic De Luxe Espresso Machine
Kenmore Oasis - Lid Locked Shut and No Power
take your outlet pipe and place into a bucket so that it is low to the ground if water comes out then it could be that your pump is faulty when the water has all drained away the pressure switch will reset itself and the lid will now open if no water comes out un-clamp your outlet pipe from your pump if then water comes out then your pipe will be blocked m8
Aug 14, 2007 | Kenmore Oasis HE 27082 Top Load Washer
No power at all
sounds like you have a wire harness problem. Turn off the electric and take off the back panel. The two wires you want to be concerned with are the red and black that are coming off the terminal block. Check for burns or breakage.
May 31, 2007 | Whirlpool RF378 Electric Kitchen Range
Hamilton Beach D60012 Coffee Maker Logo
13 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
Jerry Greenberg
Jerry Greenberg
Greg Cann
Greg Cann
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
