Question about Dell Studio S2340L 23" IPS Widescreen LED Monitor - Black
Ghosting? Red tint on left side of monitor with ghost pixels of previous desktop icons. Picture here, http://s23.postimg.org/9on0exkp7/Photo_01_04_2014_22_17_28.jpg
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 165 Answers
Verify:
1- the backligth is on (is led light)
2- the controller video board on this monitor
from your photo seems to be a problem with the backlight, but this is a LED -> a think you will be force to change the display.
good luck!
Posted on Apr 04, 2014
4 Suggested Answers
  • 55 Answers
SOURCE: Verticle blue lines, left side
Your Display cable (inside your monitor) needs to be replaced.
I would look on ebay to try and find the part and then take it to a local tech to replace it for you as I would not recommend anyone take apart a monitor (LCD OR CRT) if you had never done so before.
OR, Buy a new one.
Posted on Mar 14, 2008
VOTIT
  • 2071 Answers
SOURCE: Ghosting on DELL 2007WFP
Make sure that cable connections are securely fastened to the connectors and try reaseating the connectors. If connecting a device using component cables, make sure all three color-coded cables are connected correctly into the corresponding connectors.
Check the condition and length of the cables. Cables that are longer than 3 meters (10 feet), become more susceptible to promoting signal degredation (small dots "sparkling" on the screen and image ghosting). Cables that have been bent or pinched may also cause picture quality problems. Replace the cable or try a different cable type.
Posted on Jul 24, 2008
  • 732 Answers
SOURCE: screen ghosting & horizonal lines
ulrit, If no warranty, then you too, will need to contact Dell for cash+old unit swapout for refurbished unit or repair/refurbish the power-supply printed circuit board inside unit. Haven't you been to YOUTUBE to see DIY video clips on repair of lcd monitors??? You may even find one for your model among all the videos you can find there!!! Then remember to come back to fixya and do extensive reading and follow the links you find in the PROFILES of "louie12fix" "12fixlouie" "budmrtn" "buddymc".
I hope this response helps you understand problem and guides you to a "fix" for your unit. 12fixlouie Bye for now.
Posted on May 26, 2010
Why am I getting ghosting on my monitor screen
It can be caused by several things, so eliminate the least costly first. If you have added a new peripheral to the PC or other electronic device near by, at about the same time the ghosting started, turn the device off and see if the ghosting goes away. If that is not the trouble try moving your monitor to the extreme right or left side and see if that effects the ghosting. Next try running the internal test on your video card. Next look at your settings in the control panel and set the options to default. If it is still ghosting try reloading the driver. Since you didn't give the make and model of the monitor or PC that is about all I can tell you.
Nov 03, 2014 | Lenovo Computers & Internet
WD 73835 has ghosting images during dark or red scenes
Make sure your contrast isn't set too high. Most ghosting is caused by either contrast, brightness or tint issues. Try adjusting these settings. Also check if there is a Dynamic contrast setting for your TV as well as this can cause ghosting also.
Apr 06, 2014 | Mitsubishi Diamond 835 Wd-73835 73" 1080p...
Vizio M420kd vertical thin white line on left of screen pictures have lots of green ghosting
If you've ruled out that the source you're displaying from is good, I would contact vizio for a warranty repair
Jan 24, 2014 | Vizio Televison & Video
TRYING TO CONNECT TWO MONITORS FOR EXTENDING USE
1) You have to have a graphics card with two monitor ports.
You Cannot use one port on a graphics card, and the VGA, or DVI port on the motherboard of the computer.
BIOS will only let you use the graphics card, or the Integrated Graphics.
2) Using a 'splitter' cable results in very bad graphics on two monitors, or no graphics at all.
3) With a graphics card installed that has two monitor ports on it, connect the monitors to the graphics card.
[ The graphics card can have a VGA port, and a DVI port. Or the graphics card can have two DVI ports.
VGA = Video Graphics Array
Photo of a VGA port,
http://en.wikipedia.org/wiki/File:SVGA_port.jpg
Photo of a VGA cable,
http://en.wikipedia.org/wiki/File:Vga-cable.jpg
DVI = Digital Visual Interface
Information about DVI showing a DVI cable, and connector examples for the DVI port on a graphics card,
http://en.wikipedia.org/wiki/Digital_Visual_Interface ]
4) Turn the two monitors on once they are connected to the graphics card.
Turn on the computer.
5) Windows loaded, right-click on an empty area of the desktop screen.
6) In the list go to the bottom, and click on Properties
7) Click on the Settings tab.
8) You will see two monitor icons.
One icon has a square with a 1 in it.
The other icon has a square with a 2 in it.
The 1 monitor icon is used to represent your Primary monitor.
The one you have been using.
As you can see the 1 monitor icon is sitting to the Left.
This is how your Primary monitor should be sitting on your computer desk.
The 2 monitor icon is used to represent your Secondary monitor.
The one you are going to add.
As you can see the 2 monitor icon is sitting to the Right.
This is how your Secondary monitor should be sitting on your computer desk.
Left-click on the 2 monitor icon.
Go below in the Display Properties window, and view where it states -
Extend my Windows desktop onto this monitor
There is an empty square to the left of it.
Left-click in the empty square.
Now go below to the Right, and click on - Apply
Finally go below to the Left, and click on - OK
Your desktop screen will now be on your Secondary monitor.
Whatever is on your Primary monitor, has to be drug over to the Secondary monitor, when you are on the internet, or a program. (Such as a game)
Go to the blue frame on the Left side of the Windows screen.
When your cursor turns into a double-headed arrow STOP.
You'll find it's a little tricky your first time, keeping your cursor into the position where it turns into a double-headed arrow.
With the cursor in a double-headed arrow, press the left mouse button down, hold it down.
Drag the monitor screen to the Left.
Keep dragging until the window on your Primary monitor is on your Secondary monitor.
It's helpful you'll find to have two of the same size monitors.
I have found occasion where when using the internet on two monitors, that I had to Restore Down the screen, THEN drag it over to the Secondary monitor screen.
(Icons at the top right of the monitor screen.
Minimize ( - ), .......Restore Down/Maximize, ...........Red X
Then I Maximized the screen
For further questions please state in a Comment.
(Believe upper right of your page. - Comment
Nov 02, 2010 | Computers & Internet
Westinghouse LCM-22W2 has "ghosting"
Usually, LCD monitor ghosting appears when the cable isn't tight, the cable is faulty, or low quality. The cable should be less than 8-10 feet long. Try using a different monitor cable (they're mostly interchangable) and see if the problem goes away. I'd put my money on the cable or a loose cable connection.
May 13, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
Dell Studio S2340L 23" IPS Widescreen LED Monitor - Black Logo
mukhtar21 shaikh
mukhtar21 shaikh
