Question about Air Conditioning and Heat for Toyota Yaris
Air conditioner not cold
Compressor engages, blower is operational, ambient temp air blows from vents, system is charged with coolant( no leaks ), worked great a couple days ago.
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 115 Answers
What about freon level?
Posted on Apr 01, 2014
  • Luke
    Luke Apr 01, 2014
    Air conditioning system coolant is full
Problem with heating and air conditioning. The driver's side is blowing hot air and the passenger side is blowing cold air
Air Conditioner blows warm air
  1. Air conditioner system is discharged. Have the system evacuated, charged and leak tested by an MVAC certified technician, utilizing approved recovery/recycling equipment. Repair as necessary.
  2. Air conditioner compressor clutch not engaging. Check compressor clutch wiring, electrical connections and compressor clutch, and repair or replace as necessary.
Jun 01, 2011 | 2004 Buick Century
My GMC Sierra's air conditioning works great but the driver side vents will spontaneousely start blasting out hot air. The passenger side continuse to blow cold air. If iI turn the truck off and...
May 24, 2011 | 2005 GMC Sierra
A/c deosnt blow cold on hot days,fre-ion level is good ,and condenser is cold
HI. Here is a complete check list that will help you trouble shot this issue. You will find the problem in one or more of these areas stated below.
1. Check Drive Belts - The air conditioner utilizes a drive belt that supplies power to rotate the compressor, which is basically a refrigerant pump. If the belt fails the compressor has nothing to drive it, inspect and replace as needed to restore operation. If belt is intact proceed to the next step.
2. Check for Compressor Clutch Engagement - Turn the air conditioner to the "on" position and set controls to the coldest setting. Start the engine and allow to idle. Then open the hood and inspect the clutch at the front of the compressor, is it turning? "Engaged" if so, the system has enough refrigerant to activate. If the system is low on refrigerant it will not work properly. In this case an air conditioner recharge kit is needed to recharge the system. If the system is low on refrigerant it could cycle on and off, making a ticking noise. If the compressor clutch is not turning proceed to next step.
3. Inspect for Refrigerant Leaks - If the system has a large leak and no refrigerant remains it will not activate. First test system for a static pressure charge, with the engine off attach an ac gauge to the low side pressure port and check the state of charge. Depending on outside temperature there should be between 50 psi and 80 psi. (Cool and warm). A refrigerant leak detector is needed to inspect for leak, but if you do not have a leak detector there is an alternative method. The air conditioner system is designed to run with oil suspended in the refrigerant to lubricate the system. Check for oily residue outside the system by inspecting all hoses, compressor, condenser, evaporator or receiver drier and replace any component that has failed.
4. Inspect Fuses - Check under dash panel and under hood power distribution center. Replace failed fuses as needed, recheck system. If the new fuse fails when reinstalled a short circuit is present and requires diagnosing with a wiring schematic, follow circuits to locate short, repair as needed and recheck system.
5. Check Temperature Control Vents - The vents inside your car are controlled by a cable, electrical servo or vacuum servo. If the temperature blend door is not functioning properly it will cause warm air from the heater to exit the vents. To check this start the car and allow the engine idle, next turn the blower motor speed on low, switch the temperature control from warm to cold while your ear is close to the vents. You should hear the door move inside the heater box as it swings from open to close. If not, insect for a vacuum leak or a shorted motor in the servo, repair the leak or replace the servo motor.
Aug 29, 2009 | 1993 Ford Probe
Air conditioner not working. Coolant seems to be full.
Check the following areas in order to address this issue.
Aug 13, 2009 | 2006 Dodge Ram 3500 Truck
2001 Passat A/C blowing intermittant cold and
HI. this may be a charge issue and the system should be recharged if this is the case. I recommend going the the below checks so that you may eliminate other causes as well before the recharge.
Aug 06, 2009 | 2001 Volkswagen Passat
2000 ford taurs a/c dont work it blows cold when i power up the compressor.its running 45 lbs on my gage on the low side.
Hi...
Perform the following basic Checks and Information
1. Check Drive Belts,If belt is intact proceed to the next step.
2. Check for Compressor Clutch Engagement - Turn the air conditioner to the "on" position and set controls to the coldest setting. Start the engine and allow to idle. Then open the hood and inspect the clutch at the front of the compressor, is it turning? "Engaged" if so, the system has enough refrigerant to activate. If the system is low on refrigerant it will not work properly. In this case an air conditioner recharge kit is needed to recharge the system. If the compressor clutch is not turning proceed to next step.
4. Check under dash panel and under hood power distribution center
5. Check Temperature Control Vents - The vents inside your car are controlled by a cable, electrical servo or vacuum servo. If the vent door is not functioning properly it will cause warm air from the heater to exit the vents. To check this start the car and allow the engine idle, next turn the blower motor speed on low, switch the temperature control from warm to cold while your ear is close to the vents. You should hear the door move inside the heater box as it swings from open to close. If not, inspect for a vacuum leak or a shorted motor in the servo, repair the leak or replace the servo motor.
Thanks
Smith
Jul 31, 2009 | 2000 Ford Taurus
Air compressor does not kick in unless ambient temp is > 80
Do not operate low fan and maximum temperature as the coils will freeze up stopping air flow.
May 21, 2009 | Whirlpool Electronic Window Air...
Ac works some times
HI. Here is a complete check list that will help you trouble shot thsi issue. You will find the problem in one or more of these areas stated below.
5. Check Temperature Control Vents - The vents inside your car are controlled by a cable, electrical servo or vacuum servo. If the temperature blend door is not functioning properly it will cause warm air from the heater to exit the vents. To check this start the car and allow the engine idle, next turn the blower motor speed on low, switch the temperature control from warm to cold while your ear is close to the vents. You should hear the door move inside the heater box as it swings from open to close. If not, insect for a vacuum leak or a shorted motor in the servo, repair the leak or replace the servo motor...
Apr 20, 2009 | 2001 GMC Sierra C/K3500
When starting the car the AC Compressor wont come on right away
Nov 18, 2008 | 2001 Volkswagen Jetta TDI
A.C.
Aug 31, 2008 | 1999 Oldsmobile Silhouette
Air Conditioning and Heat for Toyota Yaris Logo
232 people viewed this question
Top Toyota Vehicle Parts & Accessories Experts
Randy Ohler
ashburton
Colin Stickland
Colin Stickland
Are you a Toyota Vehicle Part and Accessory Expert? Answer questions, earn points and help others
