Question about GE Refrigerators
No dispensing water...GE refrigerator
There is no water dispensing since i replaced the water filter 4 days ago. I even tried removing it and using the stopper but there is no water dispensing. The refrigerator GE Profile side-by-side door is 7 years old. What could be wrong? Thank you.
    Problem Solver:
  • 22 Answers
There may be an interlock switch on the housing where the filter or dummy stopper is inserted. If this interlock is not satisfied, then the water dispenser won't turn on. This would prevent water from spraying all over the inside of the refrigerator if the filter is not seated properly. Check to make sure the filter or plug is inserted properly.
Posted on Apr 19, 2014
dididsaythat
  • 291 Answers
SOURCE: GE SIDE X SIDE Dispenser problem
Sound like maybe a dispenser board short... you could try taking of the top hidge cap on the freezer side unplug the power to the board there for 30 minustes or so plug back in and see if it can reset to default and try that before u have to change board
Posted on Aug 21, 2007
SOURCE: GE Profile side by side fridge - water dispenser doesn't work
More than likely, your water line is freezing up in the door. You can remove all of the ice cubes and lower the freezer temp to about 3. Leave the freezer door open for about 5 minutes or so and if this does not work, leave the door open a little longer. Also, disconnect the water line at the base of the freezer door, near the floor, and press the dispenser lever. If you have water there, you most likely have a frozen line in the door. Changing the water filter often will help but it is not the answer and is can get quite expensive. By the way, Make sure to hold the dispenser lever forward for at least a couple of minutes each time you test for water flow. If you do not get water at the connector at the base of the door after you have disconnected the line, you have a problem with the valve in the back of the refrigerator.
Posted on Nov 17, 2008
  • 33 Answers
SOURCE: in door ice dispenser does not work but the water dispenser does.
check to make sure there is water or ice in your ice maker tray. If none then problem is usually a water supply issue to the ice maker. Behind the frig are the water supply inlet valves. One is for the water dispenser in the door. THe other is for the ice maker. However when one goes bad they both are replaced as one unit. Also Check position of fingers in ice maker. If not in a vertical position then try to reset the ice maker unit and worse comes to worse, replace it with a new one.
Posted on Nov 30, 2008
MNTECH
  • 1543 Answers
SOURCE: GE Profile Refrigerator with large puddles of water on floor.
First, your most pressing issue: the water on the floor.
Check for a blocked defrost drain. Take the panel off at the back of the freezer section and find the small hole at the very bottom center below the cooling coils. Use hot (but not boiling) water and a turkey baster to flush it out until water runs through it. (it will go into the defrost drain pan, where it will evaporate)
This will prevent water from coming out the freezer door and leaking onto your floor.
Now, for issue #2, your water dispenser: If you take the front grill off, you will see a plastic tube going through the hinge. There is a coupler, usually a insta-push type just before that. If you push on the collar of the fitting toward the center of the fitting while pulling (not real hard) on the tubing, the tube will come off. Now, try the water dispenser to see of any water comes out the disconnected tube. If yes, comment back to me to see how to fix this, if no water comes out, you most likely have a bad water valve. Reconnect the water line by just pushing it back into the fitting. Disconnect the outlet side of the water line at the water valve and try the dispenser again. No water out the valve almost always will be a bad valve. (there are rare exceptions) Water out valve now when dispenser is pressed equals a frozen water tank or water filter in the fresh foods compartment. Issue #3, your uncovered foods: All the cooling for a refrigerator takes place in the freezer compartment, and some of the cold air is circulated into the fresh foods compartment to cool it. As the air is circulated throughout the entire refrig / freezer, air picks up and transfers odors to uncovered items, including ice. Cover foods and use an open box of baking soda to help absorb odors. Issue #4. (was there a #4?) Oh yes,..... why are you dealing with this? Tell the landlord to have a service company come and check it out. You don't pay the service company, you pay the rent. Landlord is responsible for the repairs.
Posted on May 17, 2009
  • 534 Answers
SOURCE: frost buildup inside freezer door at ice dispenser
you are still not getting a seal on that flap. It sounds as if it may be warped. THe reason the frost and ice is building up is due to the flap not sealing there isn't any other reson for your problem. Good luck on your repairs
Dave
Posted on Oct 06, 2009
Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser quit dispensing 2 days ago
Sounds like the micro switch has gone bad behind the dispenser cover. locate your handle or push button either you will remove the front cover to find the switch sometimes you remove inside the door behind the dispenser. but that sounds like the trouble your having. Maybe I've helped good luck. BB
Jan 21, 2010 | GE GSH25JFR Side by Side Refrigerator
Icemaker/water dispenser not working.
Just had to defrost the water tank inside the fridge for a few minutes. Using a waterproof heating pad with extension cord did the trick. Even a fridge needs a warm blanket from time to time.
Oct 21, 2009 | Jenn-Air JFC2089HE French Door...
Moldy taste from water/ice for GE profile
What kind of external filter did you use ? If you used an $11.00 cut the line and attach on each end of the tube filter , this will not work . Go to home depot and invest in the $50.00 filter which mounts to the wall , where you replace the inner certridge by untwisting with your hand . This filter has replaceable charcoal , calcium , lime ,etc cartridges . You may have to try different cartridges to find the one your happy with .
Aug 30, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE WATER DISPENSER RUNS SLOW AND GIVE WARM WATER
With the refrig , you should have gotten a small bypass piece which fits in place of the inside filter . Install this to see if the filter is good or not . Water faster , replace filter , still slow , possible water valve problem . Also use a connector usually a 1/4 x 1/4 compression fitting , to bypass the outside filter for test purposes only .
Jul 19, 2009 | GE Refrigerators
I have a side by side GE profile Artica refridgerator. The Ice maker is producing, but I cannot get water to come out. When I push the water dispenser, I can hear something happening, but nothing comes...
One of two things. Water solonoid in back defective or water line insideof freezer door is froozen. I just posted a write up about this. Check other response. UJ63
Mar 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water stopped running in the dispenser
I had a simular problem! I tried multiple things to make it work!
- bought new filter
- open back of the fridge... (dual outlet water valve)
Finally, I went to a different forum and found a unique idea.
First at the very bottom of the fridge theres a cover remove the cover and you should see the water hose running to the door from the back. In the middle of the hose there a coupler where the hose was spliced by the manufactuer. Now this valve once you separate it will not work correctly, unless you buy a new coupler (4$)... I'm el cheapo, I bought teflon tape for 50 cents (from previous project)... Wrapped around about half dozen times and made sure it wasnt leaking...
Secondly, when you disconnect the coupler no water should shoot out, until you press the water dispenser arm. If water shoots out of the hose on the bottom then you problem is really, really, really easy. You have simplely ice/ or another item blocking water hose to the actual dispenser.
I turned off the frezzer left the door open for an hour or so. I also used my wife's blow dryer on hot, and put it where the ice comes out of the ice maker. I would press the arm peridocially to see if the ice blockage melted yet. REMEMBER: door must be closed for pressure to push on the ice blockage. Thinking back, I might have been finished sooner... I was thinking the water dispenser would work with the door open.
If this doesnt work, then you have other problems... Bad water dispenser selonoid (you can hear this little motor turning even without water), dual water outlet valve maybe broken... Going outside my knowldege level at this point.... But i guess you computer board maybe going bad. Not sure if this computer has anything to do with water dispensing....
Hope this helps! My wife left me alone for about a day or two while she enjoyed the water dispenser...And she broke the vaccum.
Dec 23, 2008 | GE GSL22JFPBS Side by Side Refrigerator
Water/Ice Dispenser is not working
at the very least replace that water filter.clogged water filter will reduce water pressure to the line.
Feb 24, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
139 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
