Question about Frigidaire Kitchen Ranges
Which parts to order?
I have used the auto cleaner. Since then the red light for the upper oven (broil?) is not working and the oven does not go aobe 250 degrees. Which parts do I need to order?
  • Official Brand Answer
  • 2,267 Answers
Good Morning carolinerell, this is Z. Thank you for your inquiry!
I see that your oven is not heating properly and that you would like to know which parts you need to repair the issue you are having with your Frigidaire range. May I please have your model number? The serial tag, which lists your model number, is typically located in the storage drawer, on the right side. With this information I can help you narrow the correct parts for you.
However, based on the symptoms you are describing it appears you may have a communication error from the EOC (Electronic Oven Control), faulty bake/broil element(s), or a potential wiring failure. In this regard, because it could be a number of any one of several underlying causes, I would recommend contacting a professional who will be best equipped to pinpoint the problem.
Best regards - Z
Posted on Apr 03, 2014
fridgetech
  • 473 Answers
SOURCE: ge spectra xl44 stove
Most likely the oven ignitor is bad or weak.  You can look at it and see how it compares to the broil ignitor.  If you see a whitish color on the ignitor and if it doesn't fully glow then it needs to be replaced.
Posted on Oct 22, 2007
the dr
  • 447 Answers
SOURCE: GE Electric Range
It is very common for elements to "catch fire" when they fail. It is really electical arching. But to answer your question you shouldnt be concerned if it ever happens to the bottom element immediatly kill the breaker it will stop instantly. dont use a fire extinguisher as it wont stop the arching. And most ovens do use the upper broil element for baking for very short intervals like 10secs on every minute or so to brown the top of product. Some models (especially older builder line ) do not
Posted on Nov 16, 2007
  • 184 Answers
SOURCE: Broiling works but baking does not work
CHECK FOR 240VOLTS AT THE TERMINALS OF THE BAKE ELEMENT. GAIN ACCESS BY REMOVING THE BACK PANEL OF THE RANGE. SOMETIMES THE TERMINAL WILL BURN OFF OF THE WIRE GOING TO THE ELEMENT. THE WIRE WILL JUST BE HANGING THERE. BE SURE TO UNPLUG THE OVEN BEFORE REMOVING BACK PANEL. IF THE WIRE IS BURNT, REPLACE THE TERMINAL AND REATTACH TO THE ELEMENTS TERMINAL. IF THE TERMINAL IS DAMAGED, REPLACE BAKE ELEMENT.
IF THERE IS NO VOLTAGE TO THE ELEMENT, REPLACE CONTROL.
Posted on Apr 04, 2008
  • 126 Answers
SOURCE: Broiler will work, but oven wont
Could be the bake igniter is bad and broil igniter is still good. may need to replace the bake igniter you will need a complete model number off range to determine the part number of the igniteryou may need.
Posted on Jan 07, 2009
  • 1015 Answers
SOURCE: My oven won't heat
First you will need to verify if the igniter is coming on for the oven burner when the oven is turned on. You will need to remove the oven bottom cover. There is usually two screws at the back bottom of the oven compartment that holds the bottom on. If there are no screws then it should just lift out. You may need to slide the bottom away from you then lift from the back. You will need to remove the oven racks to make enough room to lif the bottom out. Once removed you should be able to see the burner(you may also need to remove a heat spreader on the burner). Now turn on the oven and watch for the hot surface igniter to start to glow. If it does then you will need to make sure the gas orfice and venturri for the burner are not plugged with debris. You can use a small can of compressed air to try and dislodge any debris. Then give the oven gas valve a light tap with a screwdriver or a wrench. Oven gas valve is usually located at the bottom of the oven. Remove the bottom storage compartment to reach it. If you tap it and the burner comes on there may have just been debris in the valve and you may have cleared it. Then turn the oven off and back on completely several times. If the burner comes back on you should be ok if it does not then it could be a weak hot surface igniter or a bad olven gas control valve. Now going back to the start if the igniter does not come on you will need to verify if the igniter is getting voltage. If it is then test the igniter with a ohm meter. The reading should usually be between 500 to 700 ohms. A common problem with hot surface igniters is that they will crack. Examine the igniter for any visible cracks. If the igniter is not getting voltage then you will need to verify that all wires are properly connected and none have come loose. Look for any melted wires from the self cleaning process. You may need to dis-assemble the back of the range to see if any wires have come loose or melted. Now I need to stress to you that safety is important. Be very careful performing these procedures. You can get shocked or possible burned.
Posted on Oct 06, 2009
Oven only lights from the bottom
BUTTOM ELEMENT CALLED "BAKE" ELEMENT, UPPER CALLED "BROIL" ELEMENT ---> SO IF YOU USE "BAKE" BUTTOM COMES ON; IF YOU USE "BROIL" , UPPER COMES ON :)
Apr 18, 2014 | Kitchen Ranges
Auto clean problem
You say you checked the thermal fuse but did you check the broil element for continuity. Most ovens use the broil element for the clean function. The thermal fuse will shut off both the bake and the broil element.
Feb 16, 2014 | Whirlpool GBD307PR Electric Double Oven
Whirlpool wgp30801
It is common to have the broil element pulse on or they will send 120 volts to the broil element to even the heat in the oven. Some ovens have a preheat function that will power the broil and bake simultaneously until the oven reaches temperature then the broil element will shut down. If they both stay on red continuously through the entire bake process then something is wrong. Probably a stuck contact on the control.
Feb 12, 2014 | Ovens
The broil unit in the upper oven of a GE double oven does not work. The heating unit has continuity, 17.5 ohms, when connected, but that should be the resistance of the unit itself with all switches off....
the broil element doesn't get 240 volts,it's 120.also you should have the oven unplugged,pull out the element and read it out or at least one wire has to be removed from the part you're checking for continuity
Oct 02, 2010 | GE Ovens
Igniter in oven will try to ignite. Hear gas flow. Can see spark on upper burner assembly but it does not ignite. Use custom broil and it will ignite the upper burner but will not stay lit after ignition...
the ignitor may be faulty and not pulling enough power to keep the as valve open in order to light them oven, even though it is getting red or glowing the power is not enough.try and replace the ignitor
Jan 24, 2010 | Whirlpool GS460 Gas Kitchen Range
The lower oven ignighter does not glow
I had the same problem and swapped the oven igniter with the broiler igniter and the oven now works. This proved the oven igniter itself was the fault, now I have to replace the broiler igniter with a new one(which is much easier to get to).
FYI: An igniter may glow red and still not allow the oven to work. The igniter has to draw a certain amount of electrical current for the main gas valve to open.
Jul 20, 2009 | GE JGRP17 Gas Single Oven
Heating element on upper oven of a wall Thermador Oven
The control switch may be bad on it. If there are 2 elements on the top, they both are not bad at the same time.Check to see if the wires have not burned off the control switch first. Check to see if your breakers are O.K. Turn them both(maybe 3) off and then reset.
Jan 30, 2009 | Thermador Ovens
Bottom Baking element not working
dmiller58
If all your connections are solid then your controller is defective. Did you get any faults before changing the element? Does the broil (one at the top of the oven) work?
Post a response
Regards
Sep 10, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Delonghi range oven
Bake- Normal convection- both upper and lower heating elements.
Conv. Bake- Semi-forced convection- both upper and lower elements, heat is then distributed throughout the oven via the fan.
Broil- radiation- The heat is radiated by the ifrared broil element.
Broil & Fan- Radiation and Ventilation- The radiated heat from the infra-red broiling element is distributed throughout the oven via the fan.
Mar 12, 2008 | DeLonghi DEBIGE 2440 Electric Double Oven
Kitchen Ranges Logo
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
