Question about Dell UltraSharp Computers & Internet
Dell S2340L IPS Monitor
Red tint on left side with ghost pixel appearing on any dark color background.
  • 308 Answers
SOURCE: COLOR
If, when you turn down the color control all the way you have a black and red picture, then your picture tube is most likely weak and it's time to replace the set. If the black and white picture is normal, then the set could have a problem in the chroma circuit. Either way, it would not likely be worth repairing.
Posted on Dec 16, 2006
SOURCE: Samsung plasma PS42D5S
how do you adjust the voltage settings regardss dave
Posted on Jan 27, 2008
  • 55 Answers
SOURCE: Verticle blue lines, left side
Your Display cable (inside your monitor) needs to be replaced.
I would look on ebay to try and find the part and then take it to a local tech to replace it for you as I would not recommend anyone take apart a monitor (LCD OR CRT) if you had never done so before.
OR, Buy a new one.
Posted on Mar 14, 2008
  • 53 Answers
SOURCE: Vertical line
Sorry, you have a defective LCD panel. If your TV is still under warranty, contact Sharp to get the TV exchanged. Otherwise, LCD panels cost more than the TV is worth.
Posted on Mar 26, 2008
SOURCE: Black/Dark Colors Fuzzy w/Red Pixel Outline
I have the same problem too....
Posted on Jun 19, 2008
Ghosting?
Verify:
1- the backligth is on (is led light)
2- the controller video board on this monitor
from your photo seems to be a problem with the backlight, but this is a LED -> a think you will be force to change the display.
good luck!
Apr 01, 2014 | Dell Studio S2340L 23" IPS Widescreen LED...
Tip
Why the white or black spot on LCD Display
Dead and Stuck Pixels <br /> Pixel defects for an LCD monitor are defined as one of two types: dead or stuck. Technically, both types of pixel defects are stuck pixels but it really deals with the electrical currents and the state of each pixel or sub-pixel. <br /> A dead pixel is defined as a pixel or set of sub-pixels that has failed and is permanently in the off position. This condition means that the pixel will not let any light through. This can be observed as a dark or black spot on a brightly colored or white background. <br /> A stuck pixel is defined as a pixel or sub-pixel that has failed and is permanently in the on position. This can be either with a single or multiple sub-pixels for a given pixel and is best observed on a dark or black background. A white pixel means all three sub-pixels have failed while a green, red or blue pixel means one of the sub-pixels has failed. <br /> Hope this helps, if so do rate the Tip
on Jan 16, 2011 | Televison & Video
Lcd monitor pink/green tint
Check the cable going into the back of your monitor and the cable from your monitor into your computer, one of them is most likely loose.
Dec 24, 2013 | HP Computers & Internet
My brand new LG 37' Led/Lcd t.v. had four very light white spots that you can see in the background what causes this?
Hello
Hope this helps, if so do rate the solution
Jan 16, 2011 | LG 37LC7D 37 in. LCD HDTV
Viewsonic VP930b color problem - Red tint
Go to the setup menu on the LCD panel by pressing button 1 on the front. See if there is an option to reset the lcd to factory settings. Reset it and report if it helps not.
Jul 29, 2009 | ViewSonic VP930b 19" LCD Monitor
My display has a red tint to it
Try adjusting the color properties of the monitor using the controls located on the front of the monitor.
If you can't correct the color, then it's a problem in the color circuit. As an ex tv repair guy I can tell you it may cost more than the monitor is worth to fix it unless it's still under warranty.
Jul 13, 2009 | Dell Computers & Internet
LCD Monitor pixels that should be black are white
The contrast of the monitor is very low. reset the monitor settings using the menu button in the monitor.
Apr 17, 2017 | Sony STYLEPRO SDM-S71R/B (Black) 17" LCD...
Shadowing
GOOD DAY ND GOOD LUCK;
TRY THIS, IT WILL CORRECT CONCERN:
50V500 ONLY
GHOST: May be described as "Out of Convergence" but ghost is still attached to main image.
CONDITION:
A "ghost image" appearing to the left or right of images in the picture. Can be varying shades of a primary color (red, green, or blue) as well as gray. Can easily be seen in the 4 x 3 mode, at the edges of the picture.
CORRECTION:
To correct the problem, please do as follows:
  1. Access I2C Menu. (See page 57 of the Service Manual).
  1. To enter the I2C Service Menu, with power off, (on the front control panel) press and hold the INPUT button. Then press the POWER button for two seconds. The following Service Menu will appear.
03b_ghost_image01.gif Figure 1
  1. BEFORE CONTINUING: CONFIRM THAT THE R, G and B DRIVE ARE SET AT 40.
  • Be sure to press SELECT after each change to SAVE the new Data.
  1. Using the Remote Control joy stick, scroll down to next page (see Figure 2) until LCD ADJUST is highlighted.
03b_ghost_image02.gif Figure 2
  1. Move the joy stick to the right to cursor right once. The next page will appear with the word GHOST highlighted.
  2. Cursor right again, and a white screen will appear with a BLACK SQUARE in the center, as in Figure 3. You will see LCD ADJUST, followed by “SHP” and a number (value).
Figure 3
  1. If the unit is out of adjustment, you will see a gray ghost on either side of the black square. Move the joystick to the right or to the left until the ghost disappears. The number values will change up or down.
    • If the ghost adjustment is off with a lower value, there will be a ghost to the left of the square.
    • If the ghost adjustment is off with a higher value, there will be a ghost to the right of the square.
  2. Once you get the square to look good without ghosts, press "SELECT" to save any data values that have been changed.
  3. Press the "EXIT" button three times to return to normal picture.
  4. Adjustment is completed
  5. I HOPE THIS WAS HELPFUL, big IRISH.
Jul 26, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
On the Screen Red pixels comes in the background
hi
if you are see red pixels then your monitor haveing LCD Panel problume.
thanks
Ashok
Jan 14, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Computers & Internet Logo
188 people viewed this question
Alun Cox
