Question about Sony Cyber-shot DSC-W50 Digital Camera
No memory space, in an empty memory stick..
For some reason the camera says the memory stick has no more space, but it is actually empty. Please help.. Thanks!
  • gallegoara Jun 16, 2009
    Thank you so much , Nick! It works!!!
Go into settings and find the option to "Format" your memory card. If you cannot find it by scrolling through, look in the table of contents in the users manual - look for "format..." if nothing under format, look under "memory stick" and if it doesn't list a sub-topic of format with page # there, just go to the page it lists for memory stick, and go page by page until you find instructions on how to format.
I did a quick search of Kodak's web site and it looks like they don't have a manual posted for your model, or I'd have just copied and pasted instruction specific to your model.
This sometimes happens if you delete the folders on the memory stick or card, other times they can be corrupted temporarily or permanently by inserting/removing the memory while the camera is on. Sometimes you can do that w/o any probs 999 times, and it's only that 1000th time that messes it up. Safest to always power down camera before inserting/removing memory.
If this doesn't work, post again.
There are other things to try if that doesn't fix it, but 99% chance it will.
-Nick
Posted on Jun 15, 2009
  • bointuk
    bointuk Jan 23, 2013
    You saved my life. You are the best!!!!! thank you thank you thank you!!!!
NO space on internal memory
Hi. Actually you justneed to delete or transfer some pictures on the internal memory to your memory stick or you could remove first the memory stick and plugin you digital camera to your computer and copy all the pictures or videos on the internal memory of your digital camera.
Jun 04, 2010 | Sony Cyber-shot DSC-H50 Digital Camera
Sony memory stick PRO duo 4gb card says memory full when empty
I would suggest formating the memory card through the options on your camera. If you reformat the memory card and you still get the same error then you have a bad card. Just like anything else the cards will break down internally over time.
Mar 07, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
My cybershot w120 keeps saying no space on internal memory when i have a new memory card in it which is empty. This happened with my last card so now i am thinkng its more a camera problem rather than the...
in your settings is it set to "shoot without card"? this could cause the camera to not use the memory card installed and rely on internal memory which is limited
Aug 26, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
No memory space in memory stick
Transfer the images from the memory stick to your computer, make sure the transfer has been successful so you don't lose your pictures, then to be safe put the stick back into the camera and delete them once back in the camera. AGAIN, before you delete anything, make sure your pictures have been safely transferred to your pc and you can view them all. Deleting the photos from the stick will make the disc empty again and ready for more shots to be taken.
Jun 08, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
No memory space memory stick
Yes reformat and try again this should take care of the issue, Please rate me I am not compensated to answer free questions I rely on your rating so if you could please rate me accordenly.. Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 15, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
Memory sticks empty and shows no memory available
i have a solution that worked! Notice: save all the needed data on your computer, because Formatting your Memory stick will wipe everything out!
if you have a Sony PSP, or know someone who does, replace the memory stick that says "no memory Space" in to the PSP port, go to "Settings" which is the left-most section of the PSP main screen, then scroll down to "System Settings," select it, Scroll down again to the "Format Memory Stick" selection and press "X" follow on-screen instructions and  SHAZAM!  its ready for action in your camera again!
-Indy
Nov 16, 2008 | SanDisk Memory Media
Sony Memory Stick ProDuo Memory Problem
PLEASE FORMAT AND SCAN IT TO REMOVE ANY THREATS
Oct 16, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
MEMORY STICK EMPTY BUT CAMERA THINKS IT'S FULL
If you have backed up your files/ fotos, then format the memory stick/ card.
Jun 24, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
Please help: readout says "no memory space" but memory stick is empty!
When you copy pictures to your computer you still have the pictures on your camera so there is need to clean them up my reformatting memory stick.   This procedure will leave the memory stick clean and ready for a new set of pictures.  Here is how you reformat the memory stick-:
1.  Insert the memory stick to be cleaned/formatted in the camera
2.  Turn the MODE DIAL to the SETUP position on the camera
3.  Switch on the camera
4.  Select the MEMORY STICK TOOL from the CONTROL BUTTON
5.  Press the centre of the CONTROL BUTTON
6.  Select FORMAT by using the down arrow and up arrow
7. Choose OK by moving the right arrow button
8.  Finally press the centre of the CONTROL BUTTON and this will start reformatting the MEMORY STICK and it will ready for reuse.
Enjoy your new space in your Memory Stick!
Oct 24, 2007 | Sony Cyber-Shot DSC-P200 Digital Camera
Memory Card Problem
Have you (or can you) formated the memory sticks when they're in the camera?
Sep 13, 2005 | Sony Cyber-Shot DSC-P5 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
402 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
