Goldstar Model GCV1324M has a blue screen, plays vhs tapes fine, but the video in and adio in jacks ont the back don't work. Any ideas?
Model GCV1324M TV displays a bluescreen. It plays vhs tapes fine. The audio and video "in" jacks dont work when I plug my camcorder in. I don't have the remote control.
  • 473 Answers
SOURCE: Digital camcorder to convert VHS tape to PC for DVD burn
You can't with what you've got I hate to be the bearer of bad news, but in order to play tapes in a vcr and run them through a digital camcorder for output to a computer, the camcorder must have s-video or av inputs. Your camera only has s-video or av outputs, used for sending from the camera to the vcr or tv. Also, some cameras have the inputs but don't support analog to digital pass-through (which is what you are describing). With these cameras you input from the vcr and record it to the tape in the camera, and then output it to the computer. Without the inputs, you can't do either one.
Posted on Sep 05, 2005
SOURCE: VHS has audio but no video
we cannot get the vcr portion to work only the dvd player4.gif works what are we doing wrong?
Have the same problem? Click Here
dc2eb76.jpg MikeNJ1964
Rank:guru_s.gif Guru
Rating: 88%, 431 votes
On some of the DVD/VCR combo units, the VCR output is only available through the RF jack (channel 3), standard video1.gif (yellow) RCA jack and S-VIDEO jack. If you are using the Component jacks, the DVD side will work but the VCR will not. This is because the quality of video recorded on VHS tapes is so much lower than component quality video.
Thank you for rating this solution.
Posted on Jan 01, 2008
welcomejee
  • 10594 Answers
SOURCE: Problems viewing Hi8 tapes
Seems video head of your handy-cam is dirty or clogged. Use good quality video head cleaning tape to clean video head.
Posted on Oct 21, 2008
welcomejee
  • 10594 Answers
SOURCE: Sony Handycam DCR-TRV460 Digital-8
Camera has dirty / clogged video head.
Use good quality video head cleaning cassette.
Posted on Oct 25, 2008
  • 17 Answers
SOURCE: VHS-C tape jumpy when playing back
My apologies, I overlooked the "-C" in your post.
This problem is due to a type ofcopy protection built into vcr's.
"Macrovision" copy-protection is merely a weakening of a particular part of the signal that makes up the picture and was primarily intended to prevent people from copying videotapes. I imagine almost everyone's seen it but probably didn't know what they were seeing: the resulting picture is a little jittery and is in black-and-white or alternates between black-and-white and color. The reason you're seeing a blue screen is because modern televisions, in the absence of a signal or a weak signal, will just show a blue screen instead of snow or a very poor picture. As mentioned above, you can get around Macrovision by inserting into your connections a signal amplifier that specifically amplifies the portion of the signal that Macrovision diminishes.
Posted on Mar 04, 2009
Blue screen on play back of video
clean the heads of your video camera buddy !! use a cotton bud tip, with a touch (NOT SATURATED) of turps......an LCD screen cannot show bad tape speckle or white noise like the old vhs on a tv tube used too....remember when an old VHS Tape needed tracking?...thats what your camera is trying to tell you....but....it needs a clean as the LCD screen cannot show fuzz.....and waits for a good frame to display.....CLEAN THE VIDEO DRUM MATE !!
Jan 04, 2014 | Sony CCD-TRV228E Camcorder
Why won't older Sanyo VCR playback VHS tape on new HD-LCD TV?
The problem is not with your TV. I have had this problem as well and the older the VCR gets the harder it is for it to turn the tape. Does your VCR react the same way with other tapes? Try Fastforwarding the tape about halfway and then test it again.
Jan 06, 2010 | Sanyo Televison & Video
My JVC DR-MV150B plays prerecorded VHS tapes fine.
Try opening the front hatch of the tape by pressing the small, square button on the right or left (short) side of the tape. Check the black tape inside for any marks, dirt, scratches, tears, etc. If the tape is fine then your unit needs to be cleaned with a tape cleaner available at any electronics specialty or retail store. Good luck to you!
Jan 02, 2010 | JVC DR-MV150B DVD Recorder/VCR
Nothing but a blue screen...ugh!
buy a cleaning cassette and play three times it will work well.
Oct 12, 2008 | JVC COMPACT VHS-C CAMCORDER
Gr-fxm40 wont play back
Have you tried playing the tape in a regular vcr with the VHS-C adaptor?
Jun 12, 2008 | JVC GR-FXM40EK Camcorder
Playback *stops* on tapes where I used Aux input to record
It could be that.. you generally want a timebase corrector to properly record from analog tape to some other medium. But maybe not. Most tape-based devices also include a tension sensor, to detect the end-of-tape. If you're using tapes that are too old, cheap, etc. it could be that you're seeing this triggered.
I recommend trying the same VHS recording with a good quality, fresh tape. If it's still kicking off, you at least know it's due to the camcorder having issues with sync or something on the tape. If it works, blame the old tapes.
It's probably camcorder dependent, but I have done tape restorations using Digital8 and DV equipment, and have never known a camcorder to cut itself off due to dropouts or other problems on the tape -- mine just play through. So I think it's at least possible that it's just the tape.
Jan 20, 2008 | Sony Handycam DCR-TRV103 Digital Camcorder
Nov 26, 2007 | Televison & Video
the blue is usually the video, chances are you have no channels tuned into it or its on an av channel. anyway put a tape in and press play.(assuming you have av1 connected to tv by scart lead) failing that try wriggling the scat in the back of the vcr while on play---failing that tune it to an analogue station on the tv via the ariel (rf) leads
Nov 07, 2007 | Philips VR550 VHS VCR
JVC GR-270U Blue screen with playback
a 1394 cable is specified for the GR - D - 270 but the GR - 270 U , not listed ( does your camera use VHS/c , or mini DV tape ? )
Aug 15, 2007 | JVC GR-AXM710 Camcorder
Video image problem- Blue screen?
If your unit is fairly new,your VCR part might be the problem.Take it back!
If you have this unit for awhile,two things:
1. You need a professional A/V repair guy to clean up and check your VCR head.
2. The rental VHS tape is dirty.
Jul 28, 2007 | RCA DRC8335
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
