Question about Onkyo TX-DS777
Onky TX-DS777, no sound from speakers
I have an onkyo TX-DS777, I don't get any audio at all through any of my speaker terminals. If I plug in headphones, and turn the volume all the way up, I can faintly hear radio. I didn't try speakers turned all the way up so I guess that may work too. Either way I suspect this means that the amplifier(s) has failed, and that perhaps the other functions work fine. Is this something that can be repaired?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 108 Answers
Are the speakers selected for A or B or AB check the speakers by using a 1.5 volt batter on the cable going to the speakers, if you get a sound from the speaker, you know they are ok, if not, speakers are faulty.
Posted on Apr 03, 2014
3 Suggested Answers
  • 1153 Answers
SOURCE: Onkyo receiver TX-DS777
You have a bad amplifier left or right whichever pops if both sides pops then it both amps
Posted on Dec 25, 2007
dunnbiker
  • 8546 Answers
SOURCE: my onkyo tx-8222 suddenly stopped amplifying on
Never use maximum volume for troubleshooting. The errant switch or control that you eventually find and flip will suddenly release the amp's full power and you'll destroy your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Look for a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead' spot through idleness and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
Posted on Feb 21, 2011
Tx-ds777 no sound from front speakers on a speakers work on b but if I run a and b the center and surround stop working
Hi MJ, If you run your B speakers you will drop your 2 surrounds as the B speakers are meant to be used in a different room. I would suggest that you give us a call so that we can try some troubleshooting, please call our Product Support Team at 800-229-1687, Thanks, JT
Aug 19, 2015 | Onkyo TX-DS777
Can i connect an ipod to my Onkyo tx-ds777?
You should be able to do it with the right adapter cable.
Jul 21, 2014 | Onkyo TX-DS777
Speaker buttons don't function correctly
The Speaker A and Speaker B buttons select pairs of speakers. If you have connected a pair of speakers to the "SPEAKER A" terminals on the rear of your Onkyo receiver, you will hear stereo sound when the Speaker A button is pressed on the front panel. If, for some reason, you wanted to connect a second set of speakers in the same room or perhaps another room you would connect those speakers to the "SPEAKER B" terminals on the rear. Pressing both buttons on the front panel would send sound output to both sets of speakers
Jan 17, 2013 | Onkyo Quartz Synthesized Tuner Amplifier...
Onkyo 545 one channel don't work
Use headphones or Computer Speakers
and plug in to your headphones jack.
If the audio is present on both channel , check your speaker system
or the jack circuits.
If symptoms are the same, follow the troubleshooting on the link
above.
Oct 09, 2012 | Onkyo TX-SV545 Receiver
I have an Onkyo tx ds777 model and I can only get sound to come out of the front speakers on direct mode. Stereo or any type of surround sound produces no sound at all. I have tried with my mp3 player...
You don't say if all speakers work with the setup procedure. THAT is step 1. Then try FM as it doesn't require any cabling. Then move on to more complex sources like external analog, then digital (and make sure to assign the ports).
Aug 22, 2011 | Onkyo TX-DS777
How do I connect my onkyo tx-sr705 to a pyle pro speaker selector? I am "not" using the onkyo for a surround sound, only for music with 3 pairs of speakers in different rooms. (CD, Sirrus...
Hi Mdensonjr, I see that this was posted in 2011 but well the speaker selector would be connected to the Front speaker terminals, Thanks, JT
May 29, 2011 | Onkyo TX-SR705 Receiver
How do I hook up my blue tooth headphones to my onkyo SR 605
You cannot rig up a blue tooth headphones to this receiver with out a blue tooth transmitter ( the Onkyo does not have one built in ). If you have a transmitter it can be plugged into the headphone out socket of the Onkyo ( in front ), just remember that it will cut out the sound from all your speakers when you insert the headphone jack . The advantage though with this connection is you can control the headphone volume using the Onkyo remote.
Mar 12, 2011 | Onkyo TX-DS656 Receiver
Onkyo TX-SR605. Low or no sound output
Does any good sound come through headphones, if you plug any in?
Apr 24, 2017 | Onkyo TX-SR605 Receiver
Onkyo TX-DS777 goes straight to protection mode
Hello.You have shorted audio outputs. One of your channels has shorted output transistors. If your unit uses output ICs then one of them is shorted. Both types ( individual transistors or ICs ) are located on the large finned heat sink. The parts are available from http:\\www.tritronicsinc.com. good luck
barneyluc
Oct 19, 2008 | Onkyo TX-DS777
Onkyo TX-DS777 Logo
239 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
