Question about U-Line Kitchen Appliances - Others
U line wcm 45 head unit removal.
I am removing the head unit from my uline wcm 45 ice maker in order to create more space in the box. I am going to use it for cooling only to store bagged ice. Do i need to tie any of the wires together that were going to the head unit in order for the cooling unit to function properly and cycle the cooling function on and off as needed. I damaged the capillary thermostat when trying to remove the head unit, are these still available for purchase? Do i need to remove the back of the box to access the thermostat?
    Sergeant:
  • 446 Answers
The thermostat does come through the back of the unit and pushes into a tube attached to the ice mold , I do belive they are still available
Posted on Apr 07, 2014
  • 1073 Answers
SOURCE: Ice maker leaks water into Ice bend. When it cycles I can watch it drip water from the ice maker.
not familuar with the brand but sounds like one of 2 issues
if it is overfilling making ice cubes larger than normal, adjust the ice maker fill time if it is possible
icemaker fills and cuts off but water valve seeps water after the fill causing the water overfill
one of the 2
Posted on Jun 24, 2008
SOURCE: how to replace the ice maker unit.
I just RR'd mine. Undo the three screws on the bottom of the metal piece that the ice maker sits on, then the two screws that are horizontle above the . Take of the back, withdraw the termocouple from the tube that goes through the foam, clip the wires (5) leaving enough of a pigtail to crimp a **** splice to the new ones. Withdraw the fill tube. Don't lose the clay that seals the holes through the insulation. Withdraw the ice maker by gently twisting and pulling straight out. Replace in reverse order. Getting the screws back in is a little tricky.
Posted on Jul 15, 2008
SOURCE: U-Line BI-98 How to Remove Ice Maker Unit??
i need a manual for an everstar undercounter icemaker hd1m35 by franklin ind.
will not make ice all mode lights lit up
Posted on Oct 16, 2008
  • 10 Answers
SOURCE: Uline ice maker not cool enough to make/keep ice
one of two things
1. fan under unit stopped up or quit
2. small freon leak usually in freeze plate
Posted on Dec 19, 2008
  • 11 Answers
The trough gets refilled on each ice cycle, if it's circulating, then the water supply is adequate.Y
The exact model would be helpful, but you could call 1-800-779-2547 U-Line's tech line
or email OnlineService@U-Line.com for help
http://www.U-Lineservice.com
Posted on Dec 23, 2008
ULine CLR2160S00 was making ice then the icemaking started to slow then none at all had refrigerant replaced last year and everything else seems to be working fine,,, just no ice
Does the ice maker get water? Could the fill line be blocked? I found on my freezer ice had formed at the end of the tube and once I removed the ice it has worked fine since.
Jun 22, 2011 | U-Line ULine CLR2160S00 Echelon Series 15"...
My ice maker gets cold but will not make ice
I assume you have a good water supply ti the unit.
An internal switch of thermostat may have failed inside the ice maker head unit.
A good repair shop should be able to fix it.
If the unit is several years old it may be best to replace the icemaker.
Make sure they are factory authorised to fix uline products.
Jan 16, 2010 | U-Line Icemaker
Our Uline icemaker is not making ice anymore after having to manually defrost the unit. Water doesnt even go into the unit, and now it isnt cooling.
You might of turn it off in mid cycle. You can check the icemaker ejector blade (fingers that push ice out) If thats not at 12 oclock you will have to manually advance it so it will be at 12 oclock position. Remove cover off icemaker. Just pull it off you might need to pry it on the corners to help it along. Becareful that you dont break the cover. When you have it removed you will see 2 gears. the smaller one should have a 5/16 head on it. Turn that counterclockwise to advance the ejectorblade back to 12 oclock. Once you have it in that position turn your unit back on and see what happens.
Aug 10, 2009 | U-Line Icemaker
The bin arm on my Uline Model 402 ice maker broke off. I have a replacement bin arm. I took off the front plate of the ice maker unit, but am unable to thread the bin arm all the way through the bin arm...
1st remove the icemaker from the unit. Then take the faceplate off.You might find that the support housing is fighting you.You should be able to move the arm into place as long as the icemaker is out.
Jul 19, 2009 | U-Line Uline Origins Series...
My under counter Uline refrigerator/ice maker suddenly trips GFI
I here this alot. If you have a compressor on a gfi the compressor after awhile would trip it. The compressor start amps is usually higher than the gfi is rated. So you have 2 choices. Replace the GFI and try to find one with higher amp ratings. Or install a normal outlet for your unit. Your code will usually call for a gfi, If it does then replace with a new gfi.
To explain the start amps on a compressor depending on your model could be 10 amps. This is for a split second. However the gfi can become week after time. You can also try to plug the unit into a normal outlet to make sure everything is good on the unit. I believe it is the gfi
Jun 10, 2009 | U-Line Uline Origins Series...
ULine 2175RF Digital Touch Controller not responding.
Hi
You will need to remove the grill. Unplug the unit, Then on the control board you will see 4 wire with a black connector. Unplug that and plug it in 4 or 5 times. Make sure you dont bend the pins. Then plug the connector back in and plug unit back in. You should have better response on the display. They have a special coating and the pins needs to be cleaned this way.
Jan 18, 2009 | U-Line Refrigerator Ice Maker
Ice maker (Uline) just stopped working, not freezing, no noise.
U-line does make compressors as long as its not a r12 system. As far as the icemachine turn breaker off for a couple of min then try it. If same results then it could be a board.
Dec 23, 2008 | U-Line Icemaker
one of two things
Nov 04, 2008 | U-Line Icemaker
BI-95 ULINE
raritan eng/whirlpool ice maker assembly
Jun 20, 2008 | U-Line Icemaker
Kitchen Appliances - Others Logo
54 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Colin Stickland
Colin Stickland
john h
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
