Question about Avaya NTYS05BEE6 Nortel IP Phone 1140E VOIP Phone Graphite W/ Eng
FCC Technical requirements
Please provide staement that the vaya NTYS05BEE6 Nortel IP Phone 1140E VOIP Phone Graphite W/ Eng complies with FCC regulations
NORTEL IP 1140E + BT 2 WIRE ROUTER.
Try a different phone on the same router, does that fix it?
Dec 20, 2013 | Nortel 1140E
Can two way speakerphone be disabled on a 1140E?
Yes - download the opperator manual from net at
http://www.nd.gov/itd/files/services/voice/1140e-user-guide.pdf
You can use the mute feature to block 2 way speech
Jul 05, 2012 | Nortel Avaya / Ip Phone 1140e - Ntys05bce6
Hello, I have a Nortel 1140e with SIP firmware that has been configured to work with my home VOIP system. The basic features work, but the phone doesn't ring on incoming calls and there's an audio delay...
First I will suggest you to upgrade the Firmware....check the ringer tune and volume is OK ... or try pressing Feature key * 6 and Press 1,2,3,4 or next to hear different type of ring types .....Press OK to save it....Now Try....Further result please let us know...Thanks for being with Fixya....Good Luckmoz-screenshot-1.pngmoz-screenshot.png
Nov 08, 2009 | Nortel 1140E
Reset a 1140E IP Phone
If you are running C6E or later firmware, then the following keypad sequence is used to reset all provisioning paramaters to a "factory default":
[*][*][7][3][6][3][9][MAC][#][#]
Where MAC corresponds to the MAC address of the IP Phone which can be found on a label on the back of the IP Phone.
Since a MAC address can contain the letters A-F, then letters A/B/C can be entered via the [2] key on the dialpad, and letters D/E/F can be entered via the [3] key.
For example, an IP Phone with MAC address 00:19:E1:E2:17:12 would be reset to "factory default" when the sequence **73639001931321712## is entered on the keypad.
Apr 08, 2009 | Nortel 1140E
Cannot activate light on feature keys display
You need to use an AC power supply on the base IP Phone 1140E for the backlight on the Expansion Module to work.
Dec 18, 2008 | Nortel 1140E
I have nortel phone ip 2002 i want use for my own carrier i need to reset
1. Reset the phone by disconnecting and re-connecting power.
2. When the Nortel logo appears, press each of the four soft keys in sequence.
3. If no other configuration changes are required, press OK repeatedly until the “PC
Port? 1-ON 0-0FF
” option appears.
4. Press 1 to enable the PC Port or 0 to disable the PC Port.
5. Select OK to confirm the change.
6. Restart the IP Phone.
When the IP Phone is restarted, the firmware sets the PC Port status accordingly
Apr 20, 2008 | Nortel 1140E
1140E phone upgrade
C1B is ancient UNIStim firmware. You cannot downgrade to it. Try converting to a more recent UNIStim version. You can download firmware from www.nortel.com/support.
Mar 17, 2008 | Nortel 1140E
Nortel IP Phones I2004 and 1140e lose connectivity
here you are...
This could be the problem with your signaling server , have you checked it ??
I think it is losing connectivity of T-Lan Network.
Jan 10, 2008 | Nortel 1140E
Starting DHCP screen won't clear
Try using 26567*738 as the default password for the 1120E and 1140E IP phones.
Nov 30, 2007 | Nortel 1140E
Avaya NTYS05BEE6 Nortel IP Phone 1140E VOIP Phone Graphite W/ Eng Logo
27 people viewed this question
Top Avaya Computers & Internet Experts
David Payne
David Payne
PhantomLib
Level 1 Expert
Are you an Avaya Computer and Internet Expert? Answer questions, earn points and help others
