Question about Kenmore Dryers
CAN DRYER SHEETS BE USED IN SMART DRYER
CAN DRYER SHEETS NE USED IN KENMORE SMART DRYER
2 Suggested Answers
  • 314 Answers
SOURCE: can I use dryer balls
Instructions
Things You'll Need:
* Wool yarn
* Scissors
* Crochet hook
* Pantyhose or sock
Make the Core Ball
1.
Wrap some of the yarn around your fingers.
2. Take your fingers out of the loop you created and close the hole by pulling the yarn through it.
3. Wind yarn around the loop until you form a ball about 2 inches in circumference.
4. Cut the yarn attached to the ball using the scissors. Try to leave a little excess yarn dangling from the ball.
5. Grab the excess piece of yarn with the crochet hook and tuck it inside the ball to prevent the ball from unravelling during the felting process.
Primary Felting
6. Put the core ball into the pantyhose or sock, and tie the open end in a knot. (If you are felting more than one core ball at a time, you can separate them within the pantyhose or sock by twisting the fabric in between the balls before tying the knot.)
7. Put the pantyhose or sock containing the core ball into the washing machine with a load of laundry.
8. Remove the ball from the pantyhose or sock when the cycle is complete. It should now be slightly felted. To increase felting, simply repeat this process.
Enlarge the Ball
9. Wrap more yarn around the felted core ball to increase its size. It's all right if you make the dryer ball a little big at first, since it will shrink over time as you use it. A good initial size to make a dryer ball is around 9 inches in circumference.
10. Cut the yarn with the scissors once you have made the ball the appropriate size. Try to leave a little excess yarn dangling from the ball.
11. Tuck the excess yarn inside the ball with the crochet hook. This will prevent it from unravelling when in use.
Secondary Felting
12. Put the dryer ball into the pantyhose or sock, and tie the open end in a knot.
13.Put the pantyhose or sock into the washing machine with a load of laundry.
14. Remove the ball from the pantyhose or sock when the cycle is complete. The dryer ball should now be felted and ready for use the next time you do laundry.
Posted on Feb 28, 2011
Model kenmore smart heat pack4 HE3 getting beep sound after some running
There is a test sheet under the front panel that tells all the diagnostic tests that you can run.
Aug 09, 2015 | Kenmore Dryers
Why do dryer sheets stick to the vent outlet on a Kenmore gas dryer?
The dryer sheets soften during the drying cycle to release the softening material. Air flow through the dryer drum causes the sheets to "glue" themselves to the vent outlet. If you have the dryer disassembled for service, you will find a sticky residue on the back of the vent.
Dec 31, 2014 | Kenmore 73952 Gas Dryer
Are dryer sheets like bounce harmful to the dryer?
I have never heard of dryer sheets being harmful to the machine but I do know that certain individuals are allergic to them and the scents that are added.Some of them are scent free and remove static electricity but do not add any smell to the clothes.
Be sure to remove the left over sheet that is in the dryer when the cycle is finished.
Jul 03, 2012 | Kenmore Dryers
Have a kenmore 67231 dryer replaced element and 3 thermostates still ne heat whats wrong
That leaves the door switch, the timer, and the motor. If the motor runs, check the switch on the motor, it energizes the heater relay.
Sep 24, 2011 | Kenmore 62722 Electric Dryer
Kenmore oasis dryer F-40 error, tech sheet does not explain what this is.
I just got f40 code on my oasis dryer. What does this mean and what can I do to fix it?
Aug 08, 2009 | Kenmore Dryers
My electric Kenmore Dryer (65291) does not get hot anymore
does it still start? if so you may need a ne heat element?
Feb 28, 2009 | Kenmore Dryers
Twisted sheets
dry your sheets separately.
Oct 28, 2008 | Kenmore Elite HE4 Electric Dryer
Lost sheet in Dryer
BUY THE TIME YOU PUT THE MONEY IN IT FOR THE PARTS AND THE HEAD ACHE YOU MAY WANT TO CONSIDER BUYING A USED DRYER THE COST MAY OVER WEIGHT THE MEENS
Oct 04, 2008 | Kenmore 75944 Gas Dryer
Dryers Logo
15 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
