Question about Electrolux EI27BS26JS Stainless Steel
My Electrolux refrigerator has a slow leak out of the water dispensor
We bought a house in Oct. In December we noticed that was a small dip coming out of the fridge. Repairman came out and replaced the ice maker and noticed that the motor had some freezing. Had us unplug the fridge for 24 hrs. Everything worked fine till this week and now it is happening again. Slowly dripping. We would rather not take everything out of the fridge to de-ice it again (if that is the problem). Any ideas?
    Problem Solver:
  • 11 Answers
Check your drip tray is not blocked in the fridge
Posted on Apr 06, 2014
SOURCE: no water from dispenser
Frig is set too low of temp Water is freezing in tubing chill coil
Posted on Jun 07, 2008
  • 68 Answers
SOURCE: acquired second hand electrolux er3167bn fridge
yep sounds as though it is iceing up after it runs for a couple of days
you may have a defrost heater or defrost timer not working
the fact it didnot have water in the tray, you prob have a blocked drain as well
Posted on May 02, 2009
  • 51 Answers
SOURCE: recently purchyased electrolux 3 door
You have to open the water hose let the water drain for at list 2 to3 minute so you can have the water line free with air package, and close backthe water hose
Posted on Oct 24, 2010
  • 1891 Answers
SOURCE: French Door with bottom freezer Electrolux ice
sounds like the drive in icemker head is bad and not turning the timing wheel . the timing wheel controls the harvest and the water comming in ect . best to replace the icemker with ther kit . come with instructions . mm hope this helps . if more info needed i need the model # and ser of your unit .. feed back pls ..
Posted on Dec 11, 2010
Sea Breeze
  • 4654 Answers
SOURCE: i have an electrolux double door freezer on the
That is simply your dual water control valve found on the back of most refrigerators. If I had your model number I would be able to point out the part number and location. Here is what happens. The water valve begins to slowly leak water that comes to the ice maker when not needed. It moves slow enough that it begins to freeze solid inside the fill tube to ice maker and when the ice maker calls for water there is a big chunk of ice in the way and the water goes everywhere but where it should. Here is a short clip with lots of info, Please Rate and Thanks, Sea Breeze
Posted on Apr 28, 2011
Ge gss25pgmf
Before replacing water valve open open back panel disconnected water line of water dispensser and tell some 1 to press water actuator on dispensor and check water pressure from it. If its slow then it can be valve or it can be filter housing. Repalce both if confuse.
Mar 03, 2014 | General Refrigerators
Electrolux water dispensor won't shut off
hi.this sounds like either your valve is jammed open or micro switch on dispenser. (turn water off)good luck ali
Jul 06, 2012 | Electrolux EI26SS55GS Stainless Steel ...
Hello, lost water in the house, now when it came back on, water dispensor has a slow drip (not sure if related)... the dispensor handle seems to be working fine... it dispenses water when pressed.. doesn't...
remove bottom grill.
look for tube which runs thru freezer door.
follow back towards underneath of machince/ find push fit connector.
remove pipe which run thru door from connector and blow thru quite hard. reconnect and press dispenser paddle to allow water back thru
this shhould solve problem in 9/10 cases if it doesn't then you will need your water inlet valve checked
Jan 27, 2011 | Whirlpool Refrigerators
Hello, lost water in the house, now when came back on, water dispensor has a slow drip... the dispensor handle seems to be working fine... it dispenses water when pressed.. doesn't seem to stay...
If you take the bottom grill off the front of the appliance -1x Philips screw either side- under the freezer door you will see where the water pipe goes through the hinge. follow that pipe back towards the underneath of the machine and you should come across a push-fit connector.
The pipe leading through the freezer door from the connector, and blow down it, re-fit, press dispenser paddle to allow to flow. This stops the drip in 9/10 instances.
If not you may need to have someone check the water valve for slight blockage.
Water dispenser leak all the time how can i fix it?
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
May 10, 2010 | Electrolux 25.9 Cu. Ft. Side-by-Side...
The ice shoot leaks water into the exterior tray
It sounds like the dispensor flap , is not closing , letting warm air into the freezer . Remove the top cover from the freezer door hinge and disconnect the plug . This removes power to the door . Use a small screwdriver , and pry the bottom of the dispensor display board outward . Remove the 3 plugs . Remove the 4 screws on the white dispensor housing ( 1 on each corner ) and slide the housing out . In the top right , inside the dispensor area , you will see a solenoid with a plunger . These 2 parts usually rust , and have to be replaced . Pt # WR62X10055 . Only 3 screws hold this piece on , so it can easily be replaced .
Sep 27, 2009 | GE GSS25SGMBS Side by Side Refrigerator
FRS25R4A side by side. Water drips from the water
Sep 07, 2009 | Frigidaire FRS26R4A Side by Side...
Doors got to hot
Check the warrenty on fridge . Usually you have a 5 year warrenty on the compressor AND sealed system ( parts and labor ) . However , a service call charge may apply . Also check to see if something got sucked into the compressor cooling fan blade causing the noise , after you cleaned the coils .
From the description about dispensor leaking and ice getting stuck , sounds like the water valve needs to be replaced . Small ice cubes ( from not enough water ) will get caught between the rake and fingers . A leaking water dispensor , usually indicates that the water solenoid is not closing completely when letting off the water dispensor arm . Both solenoids come togather as the water valve ( located where the wall waterline connects to refrig ) .
Aug 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
We have a side by side refrigerator/freezer. a water drip runs down the grille on the freezer side. a small amount. we cannot locate where the water comes from. Can you help?? model #ed20tqxfn00 Al...
If you have ice and water in the freezer door it would appear that the water line going to the water dispensor has a leak. First check where the door hindges at the bottom as this is where the line runs from the water container located in the fresh food compartment to the water dispensor in the freezer door.
Jul 07, 2008 | Whirlpool Refrigerators
Electrolux EI27BS26JS Stainless Steel Logo
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
