Question about Sharp AR-BC320 All-In-One Led Printer
Sharp AR-BC320 with the following errors: H5-01 and Code: DK
  • Sharp Expert
  • 316 Answers
Copy lamp light abnormality
Posted on Jun 13, 2010
How to resolve the code error for Sharp AR C262M
I found this for a different model in the same family. Sharp AR-BC320 it may be the same as your problem.
On page 2 it says E7-21 is:
LED controller initial trouble (Cyan)
On page 4 it gives a couple of things to try to fix the problem.
http://olsonbros.com/sharp/support/pdf_trbl/trbl-arbc320.pdf
Sep 21, 2016 | Sharp Office Equipment & Supplies
Printing from a mac OSX.5.8 to a Sharp copier AR BC320?
You will need to purchase the Post Script Driver for that model. Sharp Copiers require a product key code to enable post script on their copiers. A sharp dealership will have to sell it to you as well as to get the product key code for the postscript driver.
Dec 10, 2009 | Sharp AR-BC320 All-In-One Led Printer
AR BC320 H5-01 error Need to know how to clear it
# * C * in fast sequence. Then enter simulation 14 and press start button. Hit yes to confirm and then the copier will reboot.
Sep 30, 2009 | Sharp AR-BC320 All-In-One Led Printer
How do i clear a F9-00 code for the sharp ar-bc320 copier?
Put the machine in test mode with the following key sequence:
P - * - C - *
then, 14-Start ... Execute ... Yes
CA to reboot the machine. For good measure, shut the power off, wait, and turn it on.
PS. - Get your copier on its' own outlet and share it with Nothing!!
Jun 30, 2009 | Sharp AR-BC320 All-In-One Led Printer
Sharp copier ar-bc320 error code??
the DK message means it is time to replace the black drum unit. the drum unit is called an ARC26DU. open the front cover. remove the toner cartridge/s by lifting the green lever and pulling the toner out. Open the left side door. look at where you just pulled out the toner and there is one screw (facing you) holding each drum in place - loosen the screw and pull the drum unit out towards you....slide in the new drum unit.
to reset drum counter go into SIM mode by pressing the following keys one after the other "P" "*" "C" "*" then 24 and start/copy key then 7 then select the color drum you are replacing and confirm reset. make sure copier restarts afterwards
DO NOT refill these toner cartridges (even if you can find someone to do it) The toner cartridges for these machines have generally had ongoing problems as far as longevity and quality - refilling them will only make it worse.
Apr 20, 2009 | Sharp Office Equipment & Supplies
I have a F2-41 code. What does this code mean?
- Impropercartridge (destination error, life cycle error) Identification error model error type error destination error data abnormality Misc error
Apr 15, 2009 | Sharp AR-BC320 All-In-One Led Printer
SOLID BLACK LINE FROM LEAD EDGE TO TRAIL EDGE
"dk" means the the life black drum is over. You need to replaced the drum and blade. Or you can replaced the whole drum cartridge. The line that you are getting from one of the blades, more likely from the black drum. Pull out all the drum check if there is toner on the drums.
Mar 20, 2009 | Sharp AR-BC320 All-In-One Led Printer
Sharp AR-BC320 Scanner Setup
login to the copiers web interface (the ip address of the printer ex: 192.168.XX.XX) you will see Network Scanning. Here you can change all the scanning e-mail options.
Aug 11, 2008 | Sharp AR-BC320 All-In-One Led Printer
Looking for a reset code for sharp ar-bc320
The default key operator access code on that machine is 00000
with this code you can enter network settings and change ip and subnetmask to your new requirements.
If this doesnt work you can get keyop password by entering simulation mode and get service report which has user code on it.
Apr 12, 2008 | Sharp AR-BC320 All-In-One Led Printer
Sharp AR-BC320 All-In-One Led Printer Logo
199 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
