Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
Our tv made a loud high pitched noise for a few weeks and then the color went green to then shutting off. Now, when we try to turn on the tv, the light blinks and then it just shuts off and keeps repeating until you shut it off manually.
  • 10,594 Answers
Hi, Symptom shows high pitch sound is of color wheel that is not spinning any more so TV stay in protection mode and does not power up. TV requires color wheel replacement.
Posted on Jun 15, 2009
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
Samsung dlp tv HLP5663W makes loud noise
Yes, the set uses a color wheel and the lamp faces it.
The wheel turns at over 8,000 rpm and is well known for this problem=bearings in the tiny motor go bad.
The high pitched or fan like noise (classic description) is this part.
Sooner or later the wheel (plastic colored segments) will shatter and set will shut down lamp and not operate---set monitors the speed of the wheel so if it slows down or stops it knows.
The part is readily available on the internet (Google the model number with "color wheel").
This can be a do it yourself repair and You Tube has video instructions for replacing the wheel by model number.
There are two common pitfalls to avoid which the instructions that come with the replacement part usually do not mention---if you decide to do this repair let me know and I will explain.
SD TECH
May 26, 2012 | Televison & Video
I have Samsung DLP TV 50 inch HL-P5063W
First thing to look at is the color wheel this model uses--usually it will make a high pitched fan like sound but can make a grinding sound also.
If it slows down from the 12,000 or so RPM speed it will cause color issues.
HAVE GRINDING OR HIGH PITCHED SOUND?
Apr 02, 2012 | Samsung Televison & Video
My HD61LPW42 makes a high pitched wirring noise after it is on a few seconds sounds like the fan is rubbing against something but doesn't appear to be. The picture quality is still good and the tv...
this might be a noisy color wheel . this is a motorized wheel that produces the color in the set. it could be something else because of your statement of picture is ok. if it the color wheel the set will eventally shut down. this part used to be avalible and fairly easy to replace. it has got harder to locate. The other possibilites includes a small leaky capacitor in the powers supply but that is more like a whine. a tech would have to take the back off and locate the noise.. i believe this unit might have 2 fans and a color wheel. three moving motors.. anything that moves eventally dosnt
Mar 22, 2011 | RCA HD61LPW42 61" Rear Projection HDTV
When turning on samsung hln467w, lamp light blinks, screen stays dark, can hear audio from tv show, but then a high pitched sound begins for a few seconds. The tv turns on and off for a few cycles with the...
The tv have a colors wheel,have a whinning high pitch sound,mean colors wheel is warping not spinning right any more.The colors wheel is dead,must be replaced.The tv have high pitch sound,shutdown the projection lamp.The projection lamp might be dead or not?Not yet determine dead or just shutdown by the nonfunction of the colors wheel.
Aug 05, 2010 | Samsung HLN467W 46" Rear Projection HDTV
When trying to turn on my tv, the green light blinks a few times then the red light blinks a couple of times then automaticaly the tv shuts off. There is no picture at all. It makes a couple of sounds like...
sounds like the projection bulb went bad. change the bulb and it should work. sometimes they make a high pitch noise when they are trying to turn on. the bulbs seem to last about 2 years for me.
Jun 04, 2010 | Zenith E44W46LCD 44" Rear Projection...
PROTRON 26 TWO YEARS OLD
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com
Jan 20, 2009 | Protron PLTV-26 26 in. HD-Ready LCD...
HL-R6768W not turning on. High pitch spin sound. Bad color wheel?
The high-pitched whine is definitely the color wheel.  The early color wheels had problems and many had to be replaced.  As part of the turn-on process, the TV checks for light and then checks for color wheel sync.  If the bearings are wearing out/dried out, it could cause issues with getting the proper color wheel sync, causing the set to not pass the turn on sequence.
Check Sears or partstore.com for a color wheel.  I like sears for experimental replacements since they allow easy returns.
BTW, mine is an early 61".  My color wheel was replaced when I had to replace my Light Engine.  My in-laws 50" was an early one and theirs went out within 2 years.
Jan 06, 2009 | Samsung HLN5065W 50" Rear Projection...
Toshiba 56HM195 56 in HD DLP Loud Buzzing and color distortion
If the sound, sounds more like a Hum with some vibration chances are the Cooling fan located behind the lamp is going bad, about $20 to repair, if its a high pitch hum most likely the Color Wheel and if thats the case about $30.
Good luck, my fan just went bad now seeing green dots everywhere, so debating on just junking it out or fixing it, with winter coming on might just breakdown and buy LCD and say the heck with DLP from now on.
Good luck to you..
Jan 27, 2008 | Toshiba 56HM195 56" Projection HDTV
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
168 people viewed this question
Jerry Greenberg
Jerry Greenberg
