Need to know who to space bar back on
I can't figure out how to put the wire back under the space bare
    Champion:
    New Friend:
  • 210 Answers
Will the long edge snap into the clips on the base, or the space bar? Place that first. Then aligning the two ends and the post and push down.
Posted on Apr 18, 2014
How to wire qo220 circuit breaker
A QO220 breaker will provide 20 amps of power at 240 volts when connected to #12 copper wires.
Smaller wires can not be connected as it will result in a code violation - and they are not rated for 20 amp loads. Depending on the device to be connected, it will have a total of either 3 or 4 wires. (2) hot black, red or blue wires and (1) ground green wire. Four wire devices provide (1) white neutral wire as well.
Three wire devices will provide a bare or green ground and 2 hot wires. The two hot wires should be black, red or blue - but in the case of building cables like Romex - may simply be a black, a white and bare or green. The black and white in a 3 wire cable used to provide 240V are both hot, and bare or green is ground. There is no neutral in this case. The white wire should be marked with red, black or blue tape, paint, etc. where ever it is visible so that people know it is hot - and not a neutral.
Bring the cable into the panel and locate the ground bar and the neutral bar. The ground bar has only bare and green wires connected to it and the nuetral bar will have only white or gray wires connected to it. Connect your green ground to the ground bar and any white or gray wire to the neutral bar. Most homes with the service disconnect switch inside this panel have only one bar that serves both ground and neutral wires. If your panel has ground and neutral wires mixed together, you can bring the white and green/ bare to any open terminal in the ground / neutral bar. Don't put more than one wire into 1 terminal.
Next, install the QO220 breaker.
The remaining 2 hot wires should be routed and connected to the QO220 - one wire to each of the terminals. It does not matter which terminal gets which wire as long as they are in two different terminals.
That's how it is done. Good luck!
Jul 13, 2012 | Square D Co. QO220 Circuit Breaker
Fuse keeps blowing as soon as my 2000 Ultra is moved, this fuse control's, Brakes,horn,speeddo,cruze control,blinkers. there are NO bare wires under seat this I checked what next?
Check the wiring under the handlebar assembly that controls that side, sometimes if this is taken apart for mod, a wire get pinched under the assembly. Check both sides while your at it. I would put a fuse in and unplug all the connectors, with the bike on, start connecting the connectors back and the fuse should blow, then you know exactly which system your working with. Check ALL the wiring in that system, I bet its a pinched wire up in the handle bars.
Let me know what happens please.
Oct 16, 2011 | 2000 Harley Davidson FLHTCUI Electra Glide...
Paslode impulse 900420 cannot figure out where to put spring for lockout bar follower I know where the lockout bar goes. does not seem to be any space where the spring fits. can you tell me which...
it goes under the large plate, you need to remove the screws holding the nose in place (large black piece with screws on either side) sometimes this is a 2 piece part. Under the plate where the lockout bar sits is a small recess and you will need to start the spring and then push it into place with the lockout. Let me know if you need more assistance.
Aug 10, 2011 | RTO PasLode 900420 Impulse Framing Nailer
My dog knocked over my Compaq keyboard. Now the divided spacebar is opposite what it should be. Instead of spacing on the right spacebar I have to hit the left side. How do I fix this?
Pull the space bar off by using your fingers. Underneath, you'll find a metal rod. Take note on which way it is facing, and how it fits. Make sure nothing in broken under the space bar, then put the space bar back on making sure it hooks in correctly.
Mar 08, 2011 | Compaq Keyboard
What could possibly cause a 1999 Mercury Cougar to lose its' brakes when pulling into a parking space and then, after putting it into park, starts to smoke out from underneath the dashboard area from under...
sounds like electrical to me might be some bare wires under dash that are arcing it could need a new wiring harness especially if it caught on fire
Mar 17, 2010 | 1999 Mercury Cougar
Where is space bar located on address screen?
The space bar on your unit is on the bottom of the keyboard, next to the "M" key. It looks something like this [, but on it's back. Let me know if this helps.
Jan 04, 2010 | Garmin nuvi 200W GPS Receiver
Spacebar on IBM Lenovo ThinkPad X61 came off.
I took mine off to clean under it and had a similar problem. After a bit of struggling I figured it out. I will try to explain it as best as I can, but forgive the non-technical language:
There are two gray plastic pieces on the space bar that must be that must be latched to the two white plastic pieces on the computer. The gray pieces pop off the space bar easily. Take them and put them on the white pieces on the computer so that the white arms lay across (and snap into) the top and bottom of the gray piece. The middle of the gray piece will sit in between the two arms that are not "holding" the gray piece. Then take the space bar and put the metal part into the hole on one side (outside of the plastic pieces) and then push it over so you can put the opposite metal part into the other side. Then push the space bar straight down and it will snap into place.
Apr 12, 2009 | IBM Lenovo ThinkPad T61 Notebook
My spacebar issticking.
Yup! you can do that.. carefully... i repeat, carefully pry-upward the space bar using a hard plastic card (I.D cards are best). Clean the hinge with a brush. Press down till you hear a click to return the key back to its position.
Mar 15, 2009 | Dell Latitude D600 Notebook
HOW DOES THE SPACE BAR CLIP GET REINSTALLED?
Take the wire piece out of the keyboard and attach it to the space bar by snapping the long horizontal section into the notched moldings you will see along one edge of the underside of the spacebar. Now turn the spacebar back over, orient it with the high side toward you and the lower side toward the other keys, fit the retainer ends into the slots in the keyboard, and push the spacebar center pin back into its hole. The wire is not really a retainer; it is there to transfer to the center pin any pressure applied to either end of the bar.
Mar 07, 2009 | Logitech 967437-0403 Keyboard
My son spilled soda on our keyboard.Now the x and s stick. I took it apart and cleaned it, but it still sticks. Also, a wire fell out from the space bar and I cannot figure out how to put it back.Thus the...
You cleaned the rubber under the buttons and the buttons too? All you do is put the metal bars straight down then angle it about 10 degree towards you then put it in like a regular key, but if you lost the wire then.... might need to get a new one, heh.
Dec 22, 2008 | Computers & Internet
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
