Question about Hayward Navigator Pool Cleaner
Replacing PODS on the Hayward Navagator
I received them from hayward with no instructions. I am having trouble getting them off. Anyone know how?
Remove the plugs with a pair of pliers by prying them off. remove the inset hex-head screws with a socket wrench. Ply the pod away from the main body with a flat head screw diver.
Posted on Jun 20, 2009
Lubricate bearing
i dont know of anyone who sells bearing for motors find someone who sells hayward give them the model and serial number off the pump you need a new motor dont forget you also need new seals
Mar 01, 2014 | Hayward Pool & Spa
I hmy navagator running on its side
With Hayward Navigator pool cleaners, it could be one of several problems making it run on its side. I would first check the shoes and the wings to make sure that they are not damaged or worn. If they are, they should be replaced. Make sure that the throat is not blocked and is free of debris. Check your water flow with the water flow gauge and make sure that it is not turned up too high. Finally, make sure that your hose does not have a bend or other obstruction making it function improperly.
Jan 23, 2011 | Hayward Navigator Pool Cleaner
Does not move even after replacing shoes
The other parts that need replacing about every 12-18 months are the wings, flaps, pods, A-frame, turbine and, not as often, the gearbox. Also, make sure you tighten the screws on the pods all the way or they won't be able to move the cleaner properly.
www.cpo2go.com
Nov 18, 2010 | Hayward Navigator Pool Cleaner
How to remove pods in order to install axv621d replacement
Your pads should come off with just the removal of a screw. Here is a copy of the users manual for these pool cleaners. It will give you detailed pictures and instructions for replacing the pads.
http://www.backyardcitypools.com/images/hayward/Navigator-manual.pdf
Aug 30, 2010 | Hayward Navigator Pool Cleaner
Conversion for Hayward H200 Ing Pool heater from propane to NG
I have a hayward h-2001 natural gas heater that I wish to change to propane. perhaps we can swap parts. dbkohl@prodigy.net 920-324-5652
Jun 01, 2010 | Hayward 100,000 BTU Pool Heater H100ID1 -...
My hayward navigator just moves in a circle. I picked up the navigator and saw that one of the paddles is not moving. When i pressed down on the paddle that was not moving it starts moving but as soon as I...
It wouldn't hurt to replace the pods (paddles). Also, the wings, flaps, A-frame, turbine, feet(shoes) and the gearbox. All of these things wear and should be done about every 12-18 months, as needed. Before you do any of this, though, try tightening the screw on the pod that's not working. These screws need to be very tight.
www.cpo2go.com
May 20, 2010 | Hayward Navigator Pool Cleaner
My navagator pads don't go up & down with the weight of the navagator?
This is probally worn "A" frame bearing. If you take the head to a pool store they will usually work on this for you for just the price of parts.
Apr 17, 2010 | Hayward Navigator Pool Cleaner
Hayward Navigator Moves very slow
check the bearings on the turbine and "a" frames.
also make sure the left and right pods are tightened properly and the pod shoes are in good shape.
Sep 05, 2009 | Hayward Navigator Pool Cleaner
Hayward Navigator Pool Cleaner Will Not Move
The problem is that you have too much play in your drivetrain. You will need to check for movement between the pod and the a-arm and then between the a-arm and turbine. It would also be a good idea to check the turbine bearings. Find the loose fitting, worn part and that is your problem. As far as it not twisting on the end of the hose; this is most likely caused by the screen on the back of the unit being obstructed by debris or the gearbox assembly being jammed by debris that got through the screen or is just worn out. If you have any mechanical abilty you shoud be able to do these repairs yourself with the help of a downloadabe exploded diagram. If not call a pool repairman the parts are not really that expensive compared to the cost of a new unit.
Jan 28, 2009 | Hayward Navigator Pool Cleaner
Hayward Navigator Pool Cleaner Logo
160 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
